  3. New to the forum
Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
New to the forum
81 Posts 6 Posters 53.8k Views 6 Watching
  • Q Quixote
    Ok, this is getting ridiculous.
    I uninstalled Kali as a Windows app, installed Ubuntu 20.04 LTS instead, reinstalled Lua 5.1 and all dependencies, reinstalled openLuup.
    After all that, I try to open http://172.22.154.28:3480 as prompted and get nothing but "No handler for data_request?id=lr_ALTUI_Handler" at the top of the page.
    aaaarrrrgh!!! No idea what I could be doing wrong here.
    @quixote just try a reinstall. I think it’ll fix it and download files again.
    Q 1 Reply Last reply
      Q Offline
      Q Offline
      Quixote
      @therealdb but that's literally what I just did. What would be the changing factor?
        What is in the logs?
        You can also try the request:
        http://IP:3480/data_request?id=altui
        Let it run for a couple of minutes (without giving a response as it downloads) then check the log and try the AltUI page again.
        What is in the log?
        • Q Quixote
          @quixote if my memory is not failing me, I had once to reinstall it again. I just looked at my notes and I fixed with the command reported by @akbooer. So give it a try.
          I'll also suggest you to use Windows Terminal. WSL distros are automatically added.
          • Q Offline
            Q Offline
            Quixote
            #67
            Welp, I'm not getting anywhere with this. I tried installing over my previous install once again and then navigating to the address provided (http://172.31.206.111:3480/data_request?id=altui ). If anything, things are getting worse. The openLuup page is no longer formatted properly and lacks the graphic element that was there the first time around.
            Here's my latest log:
            2020-12-14 01:54:34.563   :: openLuup LOG ROTATION :: (runtime 0.0 days)
            2020-12-14 01:54:34.563   openLuup.init:: init phase completed
            2020-12-14 01:54:34.563   openLuup.io.server:: starting HTTP:3480 server on port: 3480 tcp{server}: 0x557ccbcb5a68
            2020-12-14 01:54:34.563   openLuup.io.server:: starting SMTP server on port: 2525 tcp{server}: 0x557ccbd381c8
            2020-12-14 01:54:34.563   openLuup.io.server:: starting POP3 server on port: 11011 tcp{server}: 0x557ccbd141c8
            2020-12-14 01:54:34.563   openLuup.historian:: starting data historian
            2020-12-14 01:54:34.563   openLuup.historian:: using memory cache size (per-variable): 1024
            2020-12-14 01:54:34.563   openLuup.scheduler:: starting
            2020-12-14 01:54:34.563   openLuup.scheduler:: [2]     openLuup device startup
            2020-12-14 01:54:34.563   luup_log:2: v20.5.22
            2020-12-14 01:54:34.563   luup_log:2: sync in 85.4 s
            2020-12-14 01:54:34.563   luup.variable_watch:: callback=housemode_watcher, watching=2.openLuup.HouseMode
            2020-12-14 01:54:34.563   luup.register_handler:: global_function_name=openLuup_email, request=openLuup@openLuup.local
            2020-12-14 01:54:34.563   luup.register_handler:: global_function_name=openLuup_images, request=images@openLuup.local
            2020-12-14 01:54:34.564   luup.register_handler:: global_function_name=openLuup_events, request=events@openLuup.local
            2020-12-14 01:54:34.564   luup.register_handler:: global_function_name=openLuup_mailbox, request=mail@openLuup.local
            2020-12-14 01:54:34.564   luup.chdev.append:: [AltAppStore] Alternate App Store
            2020-12-14 01:54:34.564   luup.chdev.sync:: [2]     openLuup, syncing children
            2020-12-14 01:54:34.564   luup_log:2: 1Mb, 0%cpu, 0.0days
            2020-12-14 01:54:34.564   openLuup.scheduler:: [2]     openLuup device startup completed: status=true, msg=sync in 85.4 s, name=L_openLuup
            2020-12-14 01:54:34.564   openLuup.scheduler:: [3] Alternate App Store device startup
            2020-12-14 01:54:34.564   luup_log:3: AltAppStore : starting...
            2020-12-14 01:54:34.564   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DisplayLine1 was: EMPTY now: AltAppStore #hooks:0
            2020-12-14 01:54:34.564   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DisplayLine2 was: EMPTY now:  #hooks:0
            2020-12-14 01:54:34.564   luup.variable_set:: 3.urn:upnp-org:serviceId:AltAppStore1.Version was: EMPTY now: v20.3.30 #hooks:0
            2020-12-14 01:54:34.564   luup_log:3: AltAppStore : v20.3.30
            2020-12-14 01:54:34.564   luup.set_failure:: status = 0
            2020-12-14 01:54:34.564   luup.variable_set:: 3.urn:micasaverde-com:serviceId:HaDevice1.CommFailure was: EMPTY now: 0 #hooks:0
            2020-12-14 01:54:34.564   luup.variable_set:: 3.urn:micasaverde-com:serviceId:HaDevice1.CommFailureTime was: EMPTY now: 0 #hooks:0
            2020-12-14 01:54:34.564   openLuup.scheduler:: [3] Alternate App Store device startup completed: status=true, msg=OK, name=AltAppStore
            2020-12-14 01:56:00.050   luup_log:2: synchronising to on-the-minute
            2020-12-14 01:56:00.050   luup.call_timer:: interval: time=2m, days={}
            2020-12-14 01:56:00.050   luup_log:2: 2 minute timer launched
            2020-12-14 01:56:00.050   luup_log:2: 2Mb, 0%cpu, 0.0days
            2020-12-14 01:57:09.812   openLuup.io.server:: HTTP:3480 connection from 172.31.192.1 tcp{client}: 0x557ccbe5faf8
            2020-12-14 01:57:09.814   openLuup.server:: GET / HTTP/1.1 tcp{client}: 0x557ccbe5faf8
            2020-12-14 01:57:09.814   openLuup.server:: request completed (194 bytes, 0 chunks, 0 ms) tcp{client}: 0x557ccbe5faf8
            2020-12-14 01:57:10.466   openLuup.server:: GET /data_request?id=lr_ALTUI_Handler&command=home HTTP/1.1 tcp{client}: 0x557ccbe5faf8
            2020-12-14 01:57:10.466   openLuup.servlet:: No handler for data_request?id=lr_ALTUI_Handler
            2020-12-14 01:57:10.466   openLuup.server:: request completed (153 bytes, 0 chunks, 0 ms) tcp{client}: 0x557ccbe5faf8
            2020-12-14 01:57:10.524   openLuup.server:: GET /favicon.ico HTTP/1.1 tcp{client}: 0x557ccbe5faf8
            2020-12-14 01:57:10.524   openLuup.servlet:: file not found:favicon.ico
            2020-12-14 01:57:10.525   openLuup.server:: request completed (126 bytes, 0 chunks, 0 ms) tcp{client}: 0x557ccbe5faf8
            2020-12-14 01:58:00.133   luup_log:0: 2Mb, 0%cpu, 0.0days
            2020-12-14 01:58:24.472   openLuup.server:: GET /data_request?id=altui HTTP/1.1 tcp{client}: 0x557ccbe5faf8
            2020-12-14 01:58:24.473   luup.call_action:: 3.urn:upnp-org:serviceId:AltAppStore1.update_plugin
            2020-12-14 01:58:24.473   luup_log:3: AltAppStore : starting <run> phase...
            2020-12-14 01:58:24.473   luup_log:3: AltAppStore : downloading amg0/ALTUI [master] to trash/AltAppStore/
            2020-12-14 01:58:24.473   luup_log:3: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents?ref=master
            2020-12-14 01:58:25.268   luup_log:3: AltAppStore : GitHub request: https://api.github.com/repos/amg0/ALTUI/contents/blockly?ref=master
            2020-12-14 01:58:25.678   luup_log:3: AltAppStore : getting contents of version: master
            2020-12-14 01:58:25.678   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DisplayLine1 was: AltAppStore now: Downloading... #hooks:0
            2020-12-14 01:58:25.678   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DisplayLine2 was:  now: Alternate UI #hooks:0
            2020-12-14 01:58:25.678   luup_log:3: AltAppStore : scheduling <job> phase...
            2020-12-14 01:58:25.678   openLuup.requests::
            2020-12-14 01:58:25.678   openLuup.server:: request completed (0 bytes, 0 chunks, 1205 ms) tcp{client}: 0x557ccbe5faf8
            2020-12-14 01:58:30.958   luup_log:3: AltAppStore : starting <job> phase...
            2020-12-14 01:58:30.958   luup_log:3: AltAppStore : download failed, status: wantread
            2020-12-14 01:58:30.958   luup.variable_set:: 3.urn:upnp-org:serviceId:altui1.DisplayLine2 was: Alternate UI now: Alternate UI failed #hooks:0
            2020-12-14 01:59:56.243   openLuup.io.server:: HTTP:3480 connection closed EXPIRED tcp{client}: 0x557ccbe5faf8
            2020-12-14 02:00:00.051   luup_log:0: 2Mb, 0.1%cpu, 0.0days
            2020-12-14 02:02:00.110   luup_log:0: 2Mb, 0%cpu, 0.0days
            2020-12-14 02:04:00.062   luup_log:0: 3Mb, 0%cpu, 0.0days
            2020-12-14 02:06:00.116   luup_log:0: 2Mb, 0%cpu, 0.0days
            2020-12-14 02:07:33.504   openLuup.io.server:: HTTP:3480 connection from 172.31.192.1 tcp{client}: 0x557ccbe8a1f8
            2020-12-14 02:07:33.504   openLuup.server:: GET / HTTP/1.1 tcp{client}: 0x557ccbe8a1f8
            2020-12-14 02:07:33.504   openLuup.server:: request completed (194 bytes, 0 chunks, 0 ms) tcp{client}: 0x557ccbe8a1f8
            2020-12-14 02:07:33.575   openLuup.server:: GET /data_request?id=lr_ALTUI_Handler&command=home HTTP/1.1 tcp{client}: 0x557ccbe8a1f8
            2020-12-14 02:07:33.576   openLuup.servlet:: No handler for data_request?id=lr_ALTUI_Handler
            2020-12-14 02:07:33.576   openLuup.server:: request completed (153 bytes, 0 chunks, 0 ms) tcp{client}: 0x557ccbe8a1f8
            2020-12-14 02:07:33.647   openLuup.server:: GET /favicon.ico HTTP/1.1 tcp{client}: 0x557ccbe8a1f8
            2020-12-14 02:07:33.647   openLuup.servlet:: file not found:favicon.ico
            2020-12-14 02:07:33.647   openLuup.server:: request completed (126 bytes, 0 chunks, 0 ms) tcp{client}: 0x557ccbe8a1f8
            2020-12-14 02:07:33.647   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557ccbe8a1f8
            2020-12-14 02:08:00.103   luup_log:0: 2Mb, 0%cpu, 0.0days
            2020-12-14 02:08:01.193   openLuup.io.server:: HTTP:3480 connection from 172.31.192.1 tcp{client}: 0x557ccbe949c8
            2020-12-14 02:08:01.194   openLuup.server:: GET /openLuup HTTP/1.1 tcp{client}: 0x557ccbe949c8
            2020-12-14 02:08:01.194   openLuup.wsapi:: using openLuup/console.lua for openLuup
            2020-12-14 02:08:01.196   openLuup.wsapi:: using REQUIRE to load CGI openLuup/console.lua
            2020-12-14 02:08:01.206   openLuup.server:: request completed (8063 bytes, 0 chunks, 12 ms) tcp{client}: 0x557ccbe949c8
            2020-12-14 02:08:01.819   openLuup.server:: GET /w3.css HTTP/1.1 tcp{client}: 0x557ccbe949c8
            2020-12-14 02:08:01.819   openLuup.server:: request completed (0 bytes, 0 chunks, 0 ms) tcp{client}: 0x557ccbe949c8
            2020-12-14 02:08:01.821   openLuup.server:: GET /icons/openLuup.svg HTTP/1.1 tcp{client}: 0x557ccbe949c8
            2020-12-14 02:08:01.821   openLuup.server:: request completed (458 bytes, 0 chunks, 0 ms) tcp{client}: 0x557ccbe949c8
            2020-12-14 02:08:01.821   openLuup.io.server:: HTTP:3480 connection from 172.31.192.1 tcp{client}: 0x557ccbeddd88
            2020-12-14 02:08:06.822   openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x557ccbeddd88
            2020-12-14 02:08:13.090   openLuup.server:: GET /openLuup?page=log HTTP/1.1 tcp{client}: 0x557ccbe949c8
            @therealdb What is the difference between Windows Terminal and PowerShell? Are you suggesting that I type my commands into Terminal instead of Ubuntu Bash?
            • Q Quixote
              #68
              @quixote said in New to the forum:
              It's a multi-window terminal. No differences, besides side-by-side window, colors, and much more.
              mattwojo
              An overview on Windows Terminal
              Learn about Windows Terminal and how it can improve your command line workflow.
              So, it's not able to download AltUI. Have you tried running sudo ./openLuup_reload?
                mattwojo
                @therealdb said in New to the forum:
                That's a really good suggestion.
                • Q Offline
                  Q Offline
                  Quixote
                  Yes, multiple times. Like, multi multi times.
                    #71
                    Have you tried Alpine, next? We seem to have two examples of that working already...
                    ...although I do still wonder whether if isn’t a more fundamental Windows issue, but it would be good to try.
                      Q Offline
                      Q Offline
                      Quixote
                      #72
                      @akbooer
                      alt text Can't even get a f*****g image to display here. I think I'm about done here.
                      • Q Quixote
                        @akbooer
                        @quixote
                        You can't do it in 'Quick Reply', but just using 'Reply' gives you a menu or drag-and-drop:
                        ...it would help if you had spelled openLuup correctly.
                          @quixote
                          Q Offline
                          Q Offline
                          Quixote
                          @akbooer Sorry... I'm just kind of at the end of my rope here, other stuff included. My apologies.
                          So please explain to me how I misspelled openLuup when I've been meticulously spelling it over and over like literally hundreds of times in the last week or two. I must be losing it. Perhaps a sign for me to take up another hobby? 😕
                          • Q Offline
                            Q Offline
                            Quixote
                            #75
                            ah shit. I see it now.
                            Think I'm just worn down at this point. That''s embarrassing.
                            • Q Quixote
                              No, that's fine. Quite understand.
                              This has not gone smoothly for you, despite others chipping in to try and help.
                              If you want to leave it here, that's OK, of course. If you want to come back to it on a better day, then just ask.
                              Good luck.
                              • Q Offline
                                Q Offline
                                Quixote
                                #77
                                I'm not an idiot, and I've installed and worked on several complicated systems, both hard and software related, but it seems that I have some sort of technological curse. I'm not even kidding -- I can follow directions to the tee without a single deviation, it will fuck up. Ok, so I misspelled "openLuup" once, but I assure you, I've been super attentive to every instruction and somehow things just aren't gelling. I understand case-sensitive commands, etc.
                                I wish I were a Linux nerd. Too bad gaming pulled me into Micro$oft Winblows as a kid. It is what it is.
                                So, I've literally followed "the idiot proof" instructions, changed my Linux distribution according to instruction, reinstalled multiple times, ... I guess that's it then?
                                I'm sorry for taking up so much of you guys' time. 😞
                                  Well, OK. Sorry for taking your time...
                                  ...but I did think it was worth one last time with Alpine:
                                  https://smarthome.community/topic/276/openluup-windows-subsystem-for-linux-wsl
                                  • Q Offline
                                    Q Offline
                                    Quixote
                                    I had no idea you had put so much effort into this. I'll give it one last try.
                                    You didn't take my time -- I took my own. We were trying something unconventional and I knew that even before attempting this, so don't worry about it. Sorry if I was snarky but it seems like everything I've been trying relating to HA in the last year or so has gone dreadfully wrong.
                                    I'll try it out when I feel up to it and let you know how things go.
                                    • Q Quixote
                                      As I said, I'm runing openLuup in WSL since 2+ years. It's my development instance. So, nothing really unconventional, because it's a linux VM, after all.
                                      • Q Offline
                                        Q Offline
                                        Quixote
                                        Well, that may be true for you, but as we've seen with the Cyberpunk 2077 launch, different systems seem to yield different results. 😉
                                          165.2k
