  4. ARM61 Supported?
ARM61 Supported?
2 Posts 2 Posters 768 Views
  • Black CatB Offline
    Black CatB Offline
    Black Cat
    I had an issue loading MSR on the same machine as I had HS4 running, subsequently I deleted what I had running and loaded it on a new machine running the latest Buster but on an older ARM61 machine.
    One lesson learnt is that older version of Buster do not have a Documents folder....this created a lot of difficulties yesterday looking for a folder that didn't exist.
    Next problem I now have is where do you install nodejs, in the root directory as SUDO or in the home directory, the install instruction aren't specific?
    I also found that it can't be installed as non root user, which seems contrary to the instructions to log in as a non root user.
    So I'm stuck, could the older ARM61 machine be the problem?
    aka Zedrally
      I don't even see a binary for ARM61 for node.js in a current supported version. I think that's a non-starter.
        145.5k
