Since a couple of weeks/months, we are in the process to redo 5 rooms @ home (kids are moving from room to another room) and of course, I would need to redo a bunch of device name and room name in Zway..
Is there an easy way to tell openLuup to completely start over fresh without having to delete/rename them one by one in openLuup ?
I hope this is the correct forum – apologies if not!
I have a Raspberry Pi3 with a Razberry Z-Wave card installed. I have installed the Z-Way software and have successfully included a Fibaro Z-Wave switch on the Z-Wave network. I can toggle the switch on and off successfully from my laptop through port 8083 of the Raspberry Pi3.
On the same Raspberry Pi3 I have installed openLuup on which I have installed the Z-Way plugin. I can access this through port 3480 on the Raspberry Pi3 from my laptop.
Here is where I have come to a dead stop. How do I get access to the Fibaro Z-Wave switch from the openLuup application? I can find no documentation that tells me specifically how to do this.
Any help would be greatly appreciated.
_John.
Master Branch: 2020 Release 4.5
Roll-up of recent changes in development branch.
I have an odd issue which seems to be only for Fibaro wall plugs. They come in to Z-Way with two "electric meter" entrys, one "Power" meter and a couple of alarm entrys. In addition to the switch that is.
One of the "electric meters" is KWh and the other one is seemingly Watts, but it stays at 0/-1w. The "Power" meter shows the Watts used right now.
When these come into openluup, the wrong electric meter is selected for displaying the Watts, is there any way to manipulate which one openLuup uses? I see that the sub channel for power also is transferred, but it isn't in the data Veraflux is transmitting to my influxdb..
Haven't used the watts reading for anything before now, now i want to estimate when my dryer is done based on power usage. 🙂
Having some trouble getting the Fibaro TRV device working with the ZWay bridge. The device works in the ZWay (Zwave.Me) Smart Home GUI, and creates a number of devices in OpenLuup, some of which appear to have the right variables in it. Changing the XML and JSON files makes no difference.
I also tried creating a separate child device for Parameter 67 (using the gui for the ZWay bridge, see below), and setting the XML/JSON types for that device (like I've havd to do for a few other devices). This results in a device that correctly displays the TRV setpoint, but chaning the setpoint in the OpenLuup gui does not result in anything being transmitted to/by ZWay.
20490 49-0 D_ComboDevice1.xml zNode #49-0
49-0-113-8-12-A
49-0-113-8-13-A
49-0-113-8-14-A
49-0-113-8-15-A
49-0-113-9-3-A
49-0-64
49-0-67-1
20491 49-1 D_ComboDevice1.xml zNode #49-1
49-1-113-8-12-A
49-1-113-8-13-A
49-1-113-8-14-A
49-1-113-8-15-A
49-1-113-9-3-A
49-1-64
25031 49-1-67-1 D_Heater1.xml Radiator Bedroom
20492 49-2 D_ComboDevice1.xml multi #49-2
49-2-113-8-10-A
49-2-113-8-11-A
25030 49-2-49-1 D_TemperatureSensor1.xml Radiator Bedroom
I expect this document to be dynamic based on inputs from people who try but did not want to completely rewrite it here:
https://github.com/rafale77/Z-Way/blob/master/README.mdNearly there with the migration ..
Is it ok to use older device files or do they get updated from time to time?
Now that a fresh openLuup is up and running and connected to Zway where's the best place to source device files without vera? I probably have them on another openLuup install but not 100% which ones to copy over.
One of my wall plugs died yesterday, so i had to delete it without exclusion. When I did this, the openluup device switched to this:
And some .js issues arrived at the bottom of the screen:
What to do?
I've finally gotten the stuff to work together. Now - before I migrate all the vera devices, how do i use this?
How does the variables NameDevices and CloneRooms work? (is there a manual or description of the plugin?)
CloneRooms seems obvious, but is that the best way to go when I have more bridges?
I have an old Z-wave.me wall controller that I still use for turning the espresso machine on and off. The controller controls an Aeotec Micro Switch that for the moment is still on my Vera.
The wall controller has always been a bit tricky to work with on Vera. On my old UI5 VeraLite I managed to get it associated to the switch.
On the UI7 Vera I never got that to work, instead I could use it as a trigger in Reactor to detect when sl_SceneActivated was 1 or 0.
I have moved the wall controller to Z-way and there it is included as it should.
Compared to when it was connected to the Vera it has proper on/off buttons so that it can be controlled from the Z-way GUI.
The command classes are the following:
In OpenLuup it still shows up as it did in the Vera, i.e. only showing battery.
Is it possible to change device type so that it get the right properties in OpenLuup?
At the moment it does not have any useful properties except for battery level. It e.g. lacks the sl_SceneActivated variable.
Another step would then be to move the Aeotec switch to Z-way and to then associate the wall controller to the switch in Z-way. It seems as if this can be done in the ExpertUI.
//ArcherS
Just finished migrating to Zway, Although there are some devices that are being detected as a dimmer when in fact are Shutters.
What would be the best route to properly change how this devices are being detected by the ZWay plugin on openluup?
Hi AK,
I must be missing something but I am having now some devices fail on the bridge due to them running out of battery. Upon battery replacement, they function properly on z-way-server but the failure remains over the bridge. The failure shows up on the parent device and it says that a specific command class has failed. Looking at the return API json, it should not return any command class level failure however so I am not sure where the bridge gets its failed state from...
edit: Nevermind, I figured it out. It is a gap in data alignment between the different z-way APIs. The zwave and JS API got the update that the device recovered but not the smarthome API. Pausing and restarting the zwave app on z-way fixed it.
So I started experimenting by moving some of my wallplugs and power switch zwave devices over from VeraPlus to Z-Way.
In Z-Way this results in different elements for switching, Watts and kWh. Some even have Volts which I never saw on Vera.
But using the Z-Way plugin in openLuup only the Switch element is visible and all other elements of the zwave node are not.
I don't really know to much about Z-Way or the plugin, but am trying to learn on the run.
Maybe someone can give me some pointers what and where to look for to solve this?
Haha... yeah hard to beat that. ok when I get a little bit of time I will look at fixing the greenwave multiswitch. Just to be sure could you get a print screen of all the devices and command classes from this device? As of what you show it doesn't appear to be sending power monitoring info.
@iRobot, It helps but the cgi @akbooer is asking for would be better.
@akbooer Could you please provide the lua script to delete the bridge devices so as to recreate the devices. I get the feeling they were previously created and are not numbered right. I could rewrite it but am typo prone without testing... -
Maybe brute force would be to delete the z-way bridge device, openluup will reload, check if the child devices are still there, if they are, delete them (was not an option to do manually for me as I had several hundreds) and then re-add the bridge device. All the child devices would be recreated then.
Deleted the ZWay plugin and removed the CGI and L_ZWay files, checked all child devices are deleted also and checked room 101.
After installing the ZWay plugin the CGI file is missing in /etc/cmh-ludl/cgi.
I retried several times using the appstore from both ALTUI and openLuup console.
To make sure its not some linux or user rights problem I even set /etc/cmh-ludl to 777.I just set my VM back from a snapshot and will be trying again tomorrow. Time to go to bed now
It's working.
Thanks to @akbooer and @rafale77 for helping!After experimenting again this morning it's working.
The CGI is showing information now and the Greenwave is including power monitoring in openLuup.
Basically I did what was follow the instructions from last night and this morning.
- Deleting the ZWay plugin and all of it's children.
- Deleting the /etc/cmh-ludl/cgi/zway_cgi.lua and /etc/cmh-ludl/L_ZWay.lua and L_ZWay2.lua files.
- Reloading the Luup engine (this I probably forgot to do last night)
- Setting ownership on folder /cmh-ludl/cgi and all it's children to my username instead of root (not sure this is necessary)
- Installed the plugin from AltAppStore
- Downloaded the ZWay_cgi.lua from github and placed is in /etc/cmh-ludl/cgi
- Configured the IP and logon information of my ZWay
