  4. MSR Docs Corrections -- Post here
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
8 Posts 2 Posters 1.2k Views 2 Watching
    Dunno if I already mentioned this other typo, nor whether Patrick specifically invoke a moratorium on 'bug' reports of this nature, but here goes anyway:
    The MSR docs (http://<msr_running_ip>/docs/Getting-Started/) reference "reaction.yaml" where "reactor.yaml" is intended.
      Oh, I'll take it, I just don't want to clog up Mantis with every spell check and grammar miss. I've opened up this thread for it. Let's keep 'em in here for the time being.
        Such is my life. I proofread 1000-page reports for the Army Corps of Engineers and book authors all the time. Nothing gets past me.
          Want a job? 🙂
            Prolly! So long as it's unpaid. I'm retired and enjoying my tax bracket.
              It just occurred to me. Among the many things that MESHENE (cannot say that word with a straight face) will never have are:
              • LuaXP;
              • Expressions (and probably variables of any kind);
              • Robust restrictions;
              • 'Exit' tasks;
              • Backup/transfer/restore facility;
              • Device monitor;
              • Interface/API to other services (e.g. speech, SMTP, etc.);
              • Operational prototype pre-Q4 '21
              My money's on your pony all the way.
                Thank you! I... can't even take that name seriously. He's going to be really disappointed when he figures out that Hubitat already beat him to market, anyway. It's just not a unique idea. Not that it may not be valuable, but it's nothing new (and for clarity, as I've said, neither is Reactor for Vera or MSR -- the value is entirely in its utility, not in its uniqueness or any claim of ingenuity). The big issue I see is that it could be unsupportable. How are they going to support and troubleshoot issues in the field? Something that complex, operating in real time (when customer support most assuredly does not), with as many variables as it presents on its own, let alone the customer environment? They barely manage with one hub per customer. I wish him luck.
                  FEATURE REQUEST
                  Include link to lexpjs documentation in MSR docs for easy access. Not everyone will be aware of the underlying engine at work, nor its bounteous capabilities.
                  • Next Release?
