  4. How do I "else"
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
How do I "else"
10 Posts 4 Posters 1.6k Views 3 Watching
    Matteburk
    MSR is a bit different then the Reactor.
    Trigger :
    A changes
    Constraints :
    A is true
    Reaction:
    Close window shade
    How do i " Else if A is false ! then Open shades
    In old reactor it was easy but cant get it with msr....
    /Mattias
    • MatohlM Offline
      MatohlM Offline
      Matohl
        I honestly thought that's what the "Reset Reaction" section is for. Of course, I haven't actually used MSR yet because I'm waiting for a clear path of importing my old Reactors from Vera into the Docker-ized version of MSR that I've installed, and that process isn't officially viable yet.
        But have you tried using "Reset Reaction" to accomplish what you're after in MSR?
        MatohlM 1 Reply Last reply
          Set and Reset are to MSR what the "is TRUE" and "is FALSE" activities are to Reactor for Vera root groups.
            MatohlM Offline
            MatohlM Offline
            Matohl
            @librasun I have actually moved most of my Reactor rules (3/4) by making new ones MSR were I could iron out some of the conceptual mistakes I made when I stated to use Reactor in Vera. MSR is rather stable now but I understand that you want to wait for how to import. My next step is to integrate it with InfluxdB.
              It's really just me being lazy. Fact is, even my "simple" rules in Reactor tended to be quite involved (I love long Expressions, for example), so rather than risk a typo, I've been holding off waiting for the Backup/Restore process to work in the Docker environment. Fully acknowledging that this is at least a couple steps later in MSR's roadmap.
              As for InfluxDB, which I presume you'll be using for variable persistence(?) among heterogeneous endpoints... isn't that something you could effectively achieve with MSR itself? I can't help wondering if MSR (as-is or with some extra, purpose-built feature added) could reasonable serve as a sort of IFTTT / Apilio / DB handler. After all, it's always-on and capable of managing variables already.
              Or am I talking nonsense?
              • MatohlM Offline
                MatohlM Offline
                Matohl
                I want my sensors to be stored in a database for further analysis/joy (Temp, Watts what ever). I guess you are right that it could be done with some additional functionality in MSR but I think @toggledbits bits in some post that it is not in the roadmap. Thinking ...
                  Patrick is wise not to reinvent the wheel when he doesn't have to. 😉
                  • MatohlM Matohl
                    @matohl said in How do I "else":
                    This is an area about which I know relatively little, but have a great deal of interest. MSR has both a WebSocket and HTTP API. It is very much on the roadmap to integrate with InfluxDB and Grafana, but I do not yet have in mind how I will do that. I need to pull those packages and start playing with them to get a feel for how they work, and then I'll understand better how to use them with MSR. I would, however, like it to be as simple as a basic configuration addition to say "these are here and this is what you need to know about them", and have them usable if present standalone (on either the local system or a remote), or as an add-on package that is integrated seamlessly within the UI.
                    But very much on the roadmap. The utility of this is not at all lost on me, and it's a high priority.
                    • MatohlM Offline
                      MatohlM Offline
                      Matohl
                      Working on to get the values into, InfluxDB, not there yet. Will continue tomorrow.
                      • Next Release?
