ZWaveJSController 0.1.23254
Home Assistant:
Core 2024.2.5 Supervisor 2024.02.1 Operating System 12.0Expressions and LuaXP Functions
Meanwhile, I seem to have dug another small hole in the VARIABLE SUBSTITUTION workflow, and it's been vexing me for over an hour. This action
keeps sending a literal${{houseModeTxt}}
to its target, instead of the substituted value:
houseModeTxt := away (string)
Did not want to post this as a PR, since I think it's unique to me. Took me a while to even notice that Vera was throwing a bright blue error on her Dashboard, with the ecobee plugin complaining of being sent an out-of-range parameter (expects one of "home", "away", "sleep" or "smart1").
Thoughts? Am I having a fatal stroke here?
Have you looked in reactor.log to see if any errors are logged? Also, is this a global reaction, or rule-based? Is the variable global, or rule-based?
This yanked from the REACTOR.LOG, showing latest attempt:
2021-03-15T00:24:20.517Z <VeraController:null> VeraController#vera enqueue task for Entity#vera>device_97 action x_vera_svc_ecobee_com_Ecobee1.SetClimateHold: task { "HoldClimateRef": "${{houseModeTxt}}", "DeviceNum": "97", "id": "action", "serviceId": "urn:ecobee-com:serviceId:Ecobee1", "action": "SetClimateHold" } 2021-03-15T00:24:21.231Z <VeraController:ERR> [VeraController:performOnEntity] action request failed 2021-03-15T00:24:21.232Z <VeraController:CRIT> Error: Request failed: 501 Error Error: Request failed: 501 Error at /opt/reactor/server/lib/Controller.js:445:37 at runMicrotasks (<anonymous>) at processTicksAndRejections (node:internal/process/task_queues:94:5)
OK, but before that.
A one-step play of an action will not do variable substitution. The variable substitution is only done by the Engine when running the full reaction.
I may have to re-route how that function works. Right now, it sends the request via the websocket to the WSAPI, which asks the entity to perform the action on itself. It will take a bit of plumbing, but I can probably redirect that process to the Engine, where the sub can take place. The trick is rule-based, because they set up context very differently from global, and the rule sets up context for the engine (so if I'm asking the engine to do something for the rule, the context hasn't been established... yeah, going to take some noodling...).
◄— this guy effed up
I was entirely mistaken about MSR not substituting variables correctly in my workflow. The problem, alas, was entirely of my own making (e.g. not grasping that running internal portions of a Rule manually would NOT invoke substitution(s) the way I had surmised). Secondly, I had crafted entirely too complex a workflow for a simple task; namely, instructing Vera to match the A/C "Mode" to the current House Mode, and vice versa.My crazy construct involved arrays and indexes (to prevent illegal Mode values), lookup tables (to cross-reference integers (2) with words ("away")), time delays (to ward off bouncing/throttling), Global Expressions (to track device states and act as Triggers), boolean flags (to test parity and serve as a Constraint in Rules), etc., etc.
Think I'll stick with a simpler set of Rules, one for each case (Home on Vera ► Home on A/C; Away on A/C ► Away on Vera, etc.) and be done with it. MSR gives you so much more breathing room than the Vera environment, why not utilize it?
Sorry @rigpapa for the unnecessary back-and-forth above, and for not having the time required for ME to diagnose my own issue(s) last night.
Well, I think you hit on an important issue, which is that the "trial run" (of an individual action in a reaction) doesn't run in full context (the trial run of the full reaction, however, does). It may be that it can't (I can't imagine, it's really just a matter of if the squeeze is worth the juice), but I'm completely on board with the idea that it should. So I'll be looking into that today.
I honestly can't wrap my head around what you are telling me. It sounds as if you think the values
home
,away
, etc. are different from the strings "home", "away", etc. and somehow that's a problem, but all parameters in Vera are strings, even the numbers. There is no such construct as a "keyword" and no non-string special values forhome
oraway
etc. If you want to sendaway
to the Ecobee thermostat on the Vera, the only way to do it is by sending it a string.It sounds to me like you need to (a) look at the MSR log to see what MSR is sending to the Vera, and (b) look at the Vera LuaUPnP log to see what is being received and what it's doing with it.
No problem at all... but please, do look at the log file on MSR to see what it is sending, because right now, I have ALL actions being logged on all platforms, regardless of log level settings, for just this very reason. If what's being sent makes sense, then just look on the Vera side to see what it is getting, which is hopefully the same, but that is literally looking at one side and the other of one function call (to do the HTTP request), so there should be parity. But, there can always be a case where something about the value isn't kosher... an extra space before or after? Something sneaking in that doesn't immediately jump out. Logs. Always the logs.
