  4. Low battery Alert using Dynamic Group Controller
2 Posts 1 Posters 964 Views 1 Watching
    Good morning,
    I'm running userauth-24137-57b41335 on Fedora 39, bare metal installation.
    ZWaveJSController 0.1.23254
    Home Assistant:
    • Core, 2024.5.3
    • Supervisor, 2024.05.1
    • Operating System, 12.3
    • Frontend, 20240501.1
    I'm trying to troubleshoot a Dynamic Group Controller and notification alert that I've set up for low battery level.
    In my Reactor.config, I have the following lines:
        name: "Dynamic Group Controller"
        implementation: DynamicGroupController
        config:
          groups:
            "zwavejs_dead":
                - include_group: "zwavejs"
              filter_expression: "entity?.attributes?.zwave_device?.status == 3"
              group_actions: true
            "low_battery":
                - include_capability: battery_power
              filter_expression: >
                entity.attributes.battery_power.level < 0.35
    The idea here is that I should only have members of this group that have a battery level below 35%. When I go into Entities, I show a whole slew of devices, none of which have a battery level below the threshold.
    I also tried setting up a rule to generate a push notification once a day, but with all of the group members, I've had to disable the rule. I believe I have it set up correctly, but I'm not 100% sure. I want the notification to tell me the battery level for that device as well.
    ce24a76e-6865-40bd-bd85-632e54d315a8-image.png dc837424-deb5-4ef7-8f0d-3676f1769535-image.png
    Can anyone point to me what I may have misconfigured to get these results?
    I should also note I'm only interested in ZWaveJS devices. It's showing me battery status for my iPad and car as well, which I don't need it to send me.
      Solved: Figured it out myself. I needed to add - include_group: "zwavejs" into the yaml file. This took out most of the extraneous entries that are battery powered.
      I still had a couple of ghost zwavejs nodes that I needed to manually remove. I may have to try and reset the zwavejs db somehow and get a clean reading of all the devices.
