Reactor stable-23344-5aad7754 app 23344 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.516Z <app:null> Reactor build stable-23344-5aad7754 starting on v16.15.1 [stable-23344]2024-02-28T21:57:49.517Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [stable-23344]2024-02-28T21:57:49.517Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [stable-23344]2024-02-28T21:57:49.517Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.696Z <Structure:null> Module Structure v23172 [stable-23344]2024-02-28T21:57:49.698Z <Capabilities:null> Module Capabilities v23331 [stable-23344]2024-02-28T21:57:49.780Z <Plugin:null> Module Plugin v22300 [stable-23344]2024-02-28T21:57:49.790Z <TimerBroker:null> Module TimerBroker v22283 [stable-23344]2024-02-28T21:57:49.794Z <Entity:null> Module Entity v22353 [stable-23344]2024-02-28T21:57:49.866Z <Controller:null> Module Controller v23069 [stable-23344]2024-02-28T21:57:50.030Z <default:null> Module Ruleset v22293 [stable-23344]2024-02-28T21:57:50.031Z <default:null> Module Rulesets v22146 [stable-23344]2024-02-28T21:57:50.066Z <GlobalExpression:null> Module GlobalExpression v23211 [stable-23344]2024-02-28T21:57:50.581Z <Predicate:null> Module Predicate v23093 [stable-23344]2024-02-28T21:57:50.595Z <AlertManager:null> Module AlertManager v22283 [stable-23344]2024-02-28T21:57:50.600Z <Rule:null> Module Rule v23107 [stable-23344]2024-02-28T21:57:50.614Z <GlobalReaction:null> Module GlobalReaction v22324 [stable-23344]2024-02-28T21:57:50.617Z <Engine:null> Module Engine v23339 [stable-23344]2024-02-28T21:57:50.635Z <httpapi:null> Module httpapi v23058 [stable-23344]2024-02-28T21:57:50.680Z <wsapi:null> Module wsapi v23172 [stable-23344]2024-02-28T21:57:50.789Z <TaskQueue:null> Module TaskQueue 21351 [stable-23344]2024-02-28T21:57:50.790Z <VeraController:null> Module VeraController v23109 [stable-23344]2024-02-28T21:57:50.971Z <HassController:null> Module HassController v23344 [stable-23344]2024-02-28T21:57:51.716Z <DynamicGroupController:null> Module DynamicGroupController v22313 [stable-23344]2024-02-28T21:57:52.253Z <SystemController:null> Module SystemController v23331 i18n: missing en-US language string: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. [stable-23344]2024-02-28T21:57:52.256Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:42) at new SystemController (/opt/reactor/server/lib/SystemController.js:29:9) at /opt/reactor/server/lib/Controller.js:101:37 Trace: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at /opt/reactor/app.js:381:140 [stable-23344]2024-02-28T21:57:59.313Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:114:54) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:87:50) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:67) at Function.getInstance (/opt/reactor/server/lib/Data.js:37:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:507:100) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:538:47) at new Rule (/opt/reactor/server/lib/Rule.js:378:47) at Function.getInstance (/opt/reactor/server/lib/Rule.js:387:36) at /opt/reactor/server/lib/Engine.js:263:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1117:370 at processTicksAndRejections (node:internal/process/task_queues:96:5)I’ve tried using “latest-amd64” and it does not work either. The logs show similar json input error.
Reactor latest-24057-e9add9f5 app 24052 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.466Z <app:null> Reactor build latest-24057-e9add9f5 starting on v20.10.0 [latest-24057]2024-02-28T22:27:30.522Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [latest-24057]2024-02-28T22:27:30.522Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-24057]2024-02-28T22:27:30.522Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.667Z <Structure:null> Module Structure v23172 [latest-24057]2024-02-28T22:27:30.673Z <Capabilities:null> Module Capabilities v23331 [latest-24057]2024-02-28T22:27:30.780Z <Plugin:null> Module Plugin v22300 [latest-24057]2024-02-28T22:27:30.787Z <TimerBroker:null> Module TimerBroker v22283 [latest-24057]2024-02-28T22:27:30.791Z <Entity:null> Module Entity v22353 [latest-24057]2024-02-28T22:27:30.796Z <Controller:null> Module Controller v23069 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Ruleset v22293 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Rulesets v22146 [latest-24057]2024-02-28T22:27:30.821Z <GlobalExpression:null> Module GlobalExpression v23211 [latest-24057]2024-02-28T22:27:30.890Z <Predicate:null> Module Predicate v23093 [latest-24057]2024-02-28T22:27:30.958Z <AlertManager:null> Module AlertManager v22283 [latest-24057]2024-02-28T22:27:31.027Z <Rule:null> Module Rule v24057 [latest-24057]2024-02-28T22:27:31.033Z <GlobalReaction:null> Module GlobalReaction v22324 [latest-24057]2024-02-28T22:27:31.036Z <Engine:null> Module Engine v24023 [latest-24057]2024-02-28T22:27:31.042Z <httpapi:null> Module httpapi v24057 [latest-24057]2024-02-28T22:27:31.216Z <wsapi:null> Module wsapi v24057 [latest-24057]2024-02-28T22:27:31.296Z <TaskQueue:null> Module TaskQueue 21351 [latest-24057]2024-02-28T22:27:31.297Z <VeraController:null> Module VeraController v24050 [latest-24057]2024-02-28T22:27:31.365Z <HassController:null> Module HassController v24048 [latest-24057]2024-02-28T22:27:31.659Z <DynamicGroupController:null> Module DynamicGroupController v22313 [latest-24057]2024-02-28T22:27:31.668Z <SystemController:null> Module SystemController v23331 [latest-24057]2024-02-28T22:27:31.673Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:43) at new SystemController (/opt/reactor/server/lib/SystemController.js:237:9) at /opt/reactor/server/lib/Controller.js:101:37 [latest-24057]2024-02-28T22:27:38.845Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:51:45) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:89:49) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:65) at Data.getInstance (/opt/reactor/server/lib/Data.js:45:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:515:101) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:546:47) at new Rule (/opt/reactor/server/lib/Rule.js:371:47) at Rule.getInstance (/opt/reactor/server/lib/Rule.js:380:36) at /opt/reactor/server/lib/Engine.js:828:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:614:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:128:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1133:374 at process.processTicksAndRejections (node:internal/process/task_queues:95:5)How do I fix this?
Preview of Multi-System Reactor
There are no reactions on groups in MSR. Reactor for Vera allowed you to create activities (its equivalent to reactions) on any group in your ReactorSensor.
So, if you are creating a rule with subgroups in MSR, and you decide that the subgroup needs to perform some actions, you have export that subgroup to a Rule of its own. There is a button for that. If you click that button on a group (to the right of the group name), it will export the group to a Rule, and replace the group with a "Rule" condition for the new rule so the logic remains intact in the current rule.
@toggledbits@toggledbits Ok Then I understand but I cant find the button... I have Button,rename and collapse and then som shaded row...
Skärmavbild 2021-03-17 kl. 18.58.28.png -
Are you on 21075? Version number in the upper-right corner.
@toggledbits yes... Sorry... will update asap My bad!
@toggledbits On 21075 now and it works (button found) Thanx! Lets rock on!
FEATURE REQUEST
Consider Including
CallMeBot
among the Notification classes, with the following parameters available for editing in notification.yaml:base_url=http://api2.callmebot.com/start.php source=vera user=@<user_name> text=<default_msg> lang=en-US-Standard-C rpt=2"
Of course, the
text
parameter can be overridden in Reactions and probably should not have a default setting come to think of it. IIRC, usernames correspond to the user's Telegram account nickname. -
Just finished porting ALL of my Reactor recipes over to MSR Rules, and feel very accomplished for having done so. Only took me about a week, which included a TON of A/B testing.
With very few exceptions, my workflows are working swiftly and as expected. Any obvious glitches I've reported using Bug Tracker.
And the remaining one or two head scratchers (notably me pressing a button on my NodOn Soft Remote and Vera frustratingly ignoring me!) deserve deeper exploration before I submit a trouble ticket.The MSR learning curve has been refreshingly low, and I suspect it will be even for staunch PLEG users as well.
The Nodons are among the "scene controllers" that use non-standard variables (well, according to the UPnP device and service definitions). It seems that half of the scene controllers Vera supports use LastSceneID, and the half use either sl_SceneActivated/Deactivated or sl_CentralScene, and I've scene (see what I did there?) one case recently where a device uses both (the former consistently and the latter inconsistently). Vera doing Vera things.
Delved deeper... turns out Vera had attempted to set a bogus Configuration Setting (device > details > Device Options)... Variable 1 = <empty>
Deleted that, did Save Changes, and voilà... not only did
sl_CentralScene
,sl_CentralSceneAttr
andsl_SceneActivated
spring back to life...
...so did the blinking LED in the center of the NodOn remote which, alas, had stopped working correctly last week. Guess how that's governed!? Yep, a Config Var (8, 1d, 3 IIRC).Vera, Vera, Vera. Will your wonders never cease? Please? Pretty please?
Plus one for native CallMebot support. I am currently just sending a HTTP request.
Likewise for Telegram messenger push notifications, I am currently just sending a HTTP request.
Which is fine I guess, but anything that makes things easier for users is cool also.
CallMeBot will be in today's build.
The Telegram plugin for Vera is supported through entity actions, no HTTP request needed.
@toggledbits Like Christmas for a kid the search entity function just popped up over night,when I woke up in a crispy Sunny Sweden it just was there.... Super great work P!
@toggledbits said in Preview of Multi-System Reactor:
I'm not using the Telegram plugin for Vera currently. Didn't see the point of installing another plugin, when I can just send a HTTP request directly to the Telegram API.
Just tested the new CallMeBot integration which is working for me.
In the notification.yaml file I just had to specify my username in the quotes:
user: "@user_name"
I also specified this language for proper English.
lang: "en-GB-Standard-A"
And the number of repeats I wanted:
rpt: "2"
When I press the Play button on the "Set Reaction" in my test rule, my phone receives a phone call saying "This is a test" twice.
My phone is Android Pie version 9. If anyone knows how to make this CallMeBot phone call ring out aloud even when my phone is in vibrate or silent mode I would really like to know how ?
@cw-kid said in Preview of Multi-System Reactor:
Sounds like a job for Tasker. Best Android phone automation tool around. Basically Reactor for Android!
Among its many built-in variables is one for detecting the incoming phone number. That can become the basis for a "Profile" (trigger), which would run when CallMeBot phones you. And that profile can run a Task (reaction) which turns up your ringer volume and/or vibration.
Tasker even resets (some) changed States (attributes) automatically once the Profile goes inactive (false).
I am familiar with Tasker I do use it for some things already.
I was looking in all the various Android sound settings and notification settings etc, I thought I should be able to just exclude Telegram / CallMeBot so that when that particular app makes a notification sound or rings etc then it can do so, even if the phone is in silent or vibrate sound mode.
I spent ages looking around the settings but could not find anyway to do this.
