  4. Expression value trigger not working ?
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
5 Posts 3 Posters 1.1k Views 3 Watching
    This trigger is not working for me and I don't know why ?
    It worked once the very first time and it has not worked since.
    I read what @LibraSun said here about setting up a rule to grab your current WAN IP and add that in to a Global variable named "ip"
    I have that rule all setup and working fine. This second rule should trigger when the value of "ip" changes and then alert me.
    However the trigger isn't working properly for some reason.
    LibraSunL 1 Reply Last reply
      I just unchecked the box that says "ignore case" and saved the rule and now the trigger seems to be working each time OK.
        @cw-kid said in Expression value trigger not working ?:
        I've had mixed results triggering Rules off of [ Expression Value ] [ changes ], to the point where I sometimes recreate the variable locally and/or just test the value directly with [ Entity Attribute ].
        My problem could be psychological? Anyway, the remedy would not apply to your case. Glad you got it sorted.
        But if the issue does return and is repeatable, maybe take it up with @toggledbits as a possible PR ticket?
          I've seen one case recently where a rule condition with a "changes" operator and no operands had incorrect data stored for the condition (wrong data type, with an error to this effect in the logs). But, this rule was imported from RFV via the importer, and indeed, the importer was not making the necessary translation. I have not been able to reproduce that issue in rules that originate from the UI, and in fact the UI will repair the condition if you make any change to it (changing the case checkbox would be enough, but whether it's set or not is irrelevant). But if you can originate a broken condition from the UI and you can reproduce it with a set of steps, I'd love to know. And remember:
          Always look at the logs when something doesn't work as expected.
            I just edited the rule and ticked "ignore case" again and saved and the rule is still working and triggering, so that was a red herring as you say.
              162.9k
