Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
126 Posts 5 Posters 107.6k Views 5 Watching
    Yes, will happen. It raises priority on another "to-do" item for the parser, which has rather "blunt" string lexing at the moment. I've got a more formal version working now, but I want to play with it a little more before I commit it to MSR.
      You make it, I break it.
        @toggledbits I can't seem to concoct a meaningful example of DO .. DONE, since I'm probably not grasping its intended function within the MSR framework.
        Does it have a use here, and if so, how would such a statement look? Thanks!
          #56
          do...done is intended to help the first and each statements (but can be used anywhere, really).
          1. the each and first statements operate only on a single expression;
          2. do...done encapsulates multiple expressions (separated by comma), but looks like a single expression to each and first;
          3. The result of a do...done statement is the value of the last expression executed within it.
          Here from my own configuration is an example:
          each detector in leak_detectors:
          do
            d=getEntity(detector),
            d.attributes.arming.state && d.attributes.binary_sensor.state ? d.id : null
          done
          There's a separate expression called leak_detectors that provides an array of leak detector entity IDs (canonical, across controllers, of course). The each statement iterates over each of them. The do...done encapsulates two expressions: the fetch of the entity stored to a local variable in the first, and then uses that local variable twice in the second expression. The result of the do...done is the result of the last expression, which is the detector's ID if it is armed and tripped, or null otherwise. With an each expression, any nulls do not appear in the final array.
          The idea should be familiar from RFV, although the construction is a little different: it's a loop over a list of known leak detectors and builds an array of those that are armed and in alarm (if any, hopefully not).
            For a lark, I defined a test variable as:
            testObj = { a:5, b:2, c:"cat"},
            each num in values(testObj):
            r = isNaN(num) ? " That's all!" : "Libra owns " + num + " cats"
            which spits out:
             ["Libra owns 5 cats","Libra owns 2 cats","Libra owns cat cats"]
            while I had actually expected (due to the NaN:
             ["Libra owns 5 cats","Libra owns 2 cats"," That's all!"]
            Also, am noticing that the Expression 'value' windows always contract to their initial (1.25-line tall) height, rather than remember what the user enlarged them to.
            Are both of these "expected behaviors" in MSR??
              #58
              The isNaN() is a yes... unlike JavaScript, the lexpjs isNaN() literally tests to see if the argument is NaN, which "cat" is not. You'd need to write your test as r = isNaN( int( num ) ) ? ...etc.
              I can't store your selected/custom field sizes. I haven't poked harder into getting it to auto-size. I've done that before, but for some reason it isn't working and I haven't bothered to track it down yet.
                I'm back with another whopper. Variables allow multiple comma-separated statements, like:
                b = 3, c = b + 2 // yields 5
                but go bonkers when you try:
                testArr = [1,2,3], testArr[1] = 5 // parsing error (similar result with Objects)
                By design?
                  Yes, assignment to simple variables only; the left side of an assignment can only be an identifier (right now).
                    #61
                    This one's got me stumped now:
                    testCalc =
                    each num in [4,5,6]:
                    do
                    [num, num+1, num+2]
                    done
                    yields:
                    [[4,5,6],[4,5,6],[4,5,6]]
                    instead of:
                    [[4,5,6],[5,6,7],[6,7,8]]
                    Or have I stumbled again? (I do realize the DO..DONE is a red herring, but removing it doesn't change the result.)
                      Nope, that's clearly wrong. Not hard to fix. I found a spot where the executive was rewriting a variable rather than returning a copy, specific to arrays, so this particular test would hit it, any other data type would not. Good catch!
                        Already posted as a PR with much-simplified rendering of underlying formula.
                          OK. It may or may not make today's build. I'm still testing other parts of my parser changes.
                            #65
                            Here's an odd response, to an expression defined (in 21085) as:
                            testStr = [  "cat", "  dog", "idle  ", "  jump  "  ],
                            trim(testStr)
                            // result = (string) "cat, dog,idle , jump"
                            // note (a) the lopsided leftover spaces, (b) concatenation into a single string, (c) type coercion into String
                            // unsure whether trim() ought even accept Array as input?
                              Meanwhile, this expression is returning the original string when I actually use a Regex as the "split" term:
                              testStr = "Th3 sw1ft br0wn c4t!",
                              split (testStr,"1",2)
                              // returns ["Th3 sw","ft br0wn c4t!"]
                              // expected
                              split (testStr,"\d",2)
                              // returns ["Th3 sw1ft br0wn c4t!"]
                              // unexpected
                                Another to ponder:
                                testObj = {animal:"cat",planet:"earth",size:"big"},
                                k = keys(testObj),
                                each key in k:
                                v = testObj.key
                                produces an empty array [] rather than (the expected) ["cat","earth","big"]. (Won't parse at all using .[key] btw.)
                                  The correct syntax here is testObj[key]
                                  Basically, [] and . are nearly equivalent member accessors. In JavaScript and lexpjs you can, for example, use array.0 to refer to the first element of an array, same as array[0]. The difference between them is that the interior of [] can be an expression, where . must only have an identifier on its right-hand side. So when you testObj[key], it will use the value of key for the member access. It would also be the case that testObj.animal and testObj['animal'] are equivalent.
                                  Your earlier split (testStr,"\d",2) example doesn't work because "\d" is parsed as escape plus d, which is simply the letter d, which is not what you want. You want a literal backslash followed by a d, which would be the string "\\d" to get the RegExp character class for digits 0-9. This is also the way JavaScript would parse it and behave:
                                  > t="The quick brown f0x"
                                  'The quick brown f0x'
                                  > t.match( "\d" )
                                  null                      <---- No match!
                                  > t.match( "\\d" )
                                  [ '0', index: 17, input: 'The quick brown f0x', groups: undefined ]
                                    #69
                                    Ah, typical of me not to have known the precise array['key'] syntax offhand.
                                    Yay, that variant works as advertised. (You were supposed to be out having fun today!)
                                    And thanks for the pro tip re: "slash"-escaping the right way.
                                    I was thrown off by this one working as expected (even without the double slash construct):
                                    testStr = "Does this work?",
                                    match(testStr,"\st")
                                    // yields " t"
                                      Fun!? I'm Clonezilla-ing everyone's desktops, and retiring my old Linux server that has served as the main NAS, moving the Synology into that role. Lots of services to move (which has been done over time, but the last-minute cut-overs for some things that couldn't), etc. Busy busy!
                                      The other example, "\s" is an unrecognized escape sequence so it's leaking it. I'll fix that. "\s" is what's required.
                                          #72
                                          This one is only funny because it's true:
                                          indexof=["indexOf(indexof,indexOf)!"],
                                          indexOf(indexof,"indexOf")!=indexof
                                          This one is just plain funny:
                                          HA={ha:'HA'},
                                          ha={HA:HA['ha']},
                                          HA={ha:ha.HA}
                                          Result: ["ha":"HA"] 😆
                                          And yet these are both uncharacteristically false?
                                          [1]===[1]
                                          despite both sides having length 1 and being of the same Type?
                                          So is this (false); a bit surprising but that kinda makes sense with Objects...
                                          {a:1}=={a:1}
                                          Seriously though, I do have a slight concern about this evaluating to FALSE when it is axiomatically and mathematically TRUE:
                                          sin(1)/cos(1)==tan(1)
                                          // false, due to rounding in the 16th decimal place!
                                            163.9k
