Here’s the gist of it:
1. UI
2. scheduler
3. web server
4. Luup compatible API
6. Zwave bridge to Vera
openLuup was the result.
Set up:
2023-09-04 21:31:20.463 openLuup.io.server:: HTTP:3480 connection from 10.0.0.2 tcp{client}: 0x55aed35038 2023-09-04 21:31:20.464 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=316885191&Timeout=60&MinimumDelay=1500&_=1692128389970 HTTP/1.1 tcp{client}: 0x55ae538348 2023-09-04 21:31:20.465 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=316885191&Timeout=60&MinimumDelay=1500&_=1692129024374 HTTP/1.1 tcp{client}: 0x55addbe1e8 2023-09-04 21:31:20.477 openLuup.server:: GET /data_request?id=lr_render&target={temp_first_floor.w,temp_ground_floor.w,temp_back_wall_of_office.w,temp_inside_roof.w,temp_jps_bedrm_north.w,temp_outside.w}&title=Temperatures&height=750&from=-y&yMin=0&yMax=40 HTTP/1.1 tcp{client}: 0x55aed35038 2023-09-04 21:31:20.478 luup_log:6: DataGraph: drawing mode: connected, draw nulls as: null 2023-09-04 21:31:20.502 luup_log:6: DataGraph: Whisper query: CPU = 23.122 mS for 2016 points 2023-09-04 21:31:20.532 luup_log:6: DataGraph: Whisper query: CPU = 22.952 mS for 2016 points 2023-09-04 21:31:20.561 luup_log:6: DataGraph: Whisper query: CPU = 22.738 mS for 2016 points 2023-09-04 21:31:20.575 luup_log:6: DataGraph: Whisper query: CPU = 9.547 mS for 2016 points 2023-09-04 21:31:20.587 luup_log:6: DataGraph: Whisper query: CPU = 9.569 mS for 2016 points 2023-09-04 21:31:20.598 luup_log:6: DataGraph: Whisper query: CPU = 9.299 mS for 2016 points 2023-09-04 21:31:20.654 luup_log:6: visualization: LineChart(2016x7) 196kB in 51mS 2023-09-04 21:31:20.655 luup_log:6: DataGraph: render: CPU = 51.219 mS for 6x2016=12096 points 2023-09-04 21:31:20.755 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:20.855 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.037 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.138 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.332 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.432 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x55aed35038' sending 6 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 196367 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 144000 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 0 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x55aed35038 2023-09-04 21:31:21.507 openLuup.server:: ...only 0 bytes sent 2023-09-04 21:31:21.507 openLuup.server:: request completed (196367 bytes, 10 chunks, 1030 ms) tcp{client}: 0x55aed35038 2023-09-04 21:31:21.517 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55aed35038 2023-09-04 21:31:22.824 openLuup.io.server:: HTTP:3480 connection from 10.0.0.2 tcp{client}: 0x55aea22c88Re: socket.select() not ready to send
Hi @akbooer
Hey guys...
Long time... 😉
For example..
AND
AND
AND
IF binary-light1 is OFF
AND
IF binary-light2 is OFF
THEN
execute LUA code
WAIT 2 minute
execute LUA code
Now here's the query:
Bit of an odd one this:
I can ssh into all my servers
TIA for any thoughts
Hi Ak,
This is in the init function:
Regards
Jan
no file ‘./socket/http.lua’
no file ‘./socket/http.so’
no file ‘./socket.so’
stack traceback:
[C]: in function ‘require’
2021-08-20 14:59:39.827 :: openLuup LOG ROTATION :: (runtime 11.0 days) 2021-08-20 14:59:39.831 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6023b8088 2021-08-20 14:59:39.853 openLuup.server:: request completed (49215 bytes, 4 chunks, 22 ms) tcp{client}: 0x55b6023b8088 2021-08-20 14:59:39.854 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023b8088 2021-08-20 14:59:40.826 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.846 openLuup.server:: request completed (49215 bytes, 4 chunks, 16 ms) tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:40.847 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600f46ab8 2021-08-20 14:59:41.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.838 openLuup.server:: request completed (49215 bytes, 4 chunks, 8 ms) tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:41.838 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600d1ad98 2021-08-20 14:59:42.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.829 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.847 openLuup.server:: request completed (49215 bytes, 4 chunks, 17 ms) tcp{client}: 0x55b6016b9848 2021-08-20 14:59:42.876 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6016b9848 2021-08-20 14:59:43.054 luup.watch_callback:: 30003.DS18B20.Temperature called [37]virtualSensorWatchCallback() function: 0x55b600c2fff0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.PreviousRawValue was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.RawValue was: 28.5 now: 28.4 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 28.5 now: 28.4 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.PreviousValue was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:43.054 luup.variable_set:: 38.urn:toggledbits-com:serviceId:VirtualSensor1.LastUpdate was: 1629464323 now: 1629464383 #hooks:0 2021-08-20 14:59:43.265 openLuup.server:: request completed (3193 bytes, 1 chunks, 5550 ms) tcp{client}: 0x55b60162e488 2021-08-20 14:59:43.267 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b60162e488 2021-08-20 14:59:43.278 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.278 openLuup.server:: GET /data_request?id=status&DataVersion=516611499&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464383277 HTTP/1.1 tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.381 openLuup.server:: request completed (1091 bytes, 1 chunks, 102 ms) tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.381 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023c8458 2021-08-20 14:59:43.392 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:43.393 openLuup.server:: GET /data_request?id=status&DataVersion=516611500&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464383391 HTTP/1.1 tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:43.496 openLuup.server:: request completed (3196 bytes, 1 chunks, 4981 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:43.826 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.828 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.844 openLuup.server:: request completed (49215 bytes, 4 chunks, 15 ms) tcp{client}: 0x55b601d05a08 2021-08-20 14:59:43.844 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601d05a08 2021-08-20 14:59:44.524 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611500&Timeout=60&MinimumDelay=1500&_=1629292536029 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:44.828 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.831 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.844 openLuup.server:: request completed (49215 bytes, 4 chunks, 12 ms) tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:44.844 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6023a7d18 2021-08-20 14:59:45.514 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1629292536030 HTTP/1.1 tcp{client}: 0x55b601ab8228 2021-08-20 14:59:45.617 openLuup.server:: request completed (1 bytes, 1 chunks, 102 ms) tcp{client}: 0x55b601ab8228 2021-08-20 14:59:45.827 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.828 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.834 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b600b8de38 2021-08-20 14:59:45.836 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600b8de38 2021-08-20 14:59:46.828 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.830 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.841 openLuup.server:: request completed (49215 bytes, 4 chunks, 11 ms) tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:46.842 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6018a53f8 2021-08-20 14:59:47.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.854 openLuup.server:: request completed (49215 bytes, 4 chunks, 21 ms) tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.855 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600d2d938 2021-08-20 14:59:47.962 luup.variable_set:: 10086.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 28.3 now: 28.5 #hooks:0 2021-08-20 14:59:48.370 openLuup.server:: request completed (1359 bytes, 1 chunks, 4977 ms) tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:48.372 openLuup.server:: request completed (1359 bytes, 1 chunks, 3847 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:48.373 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6013d6cc8 2021-08-20 14:59:48.384 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601e62df8 2021-08-20 14:59:48.385 openLuup.server:: GET /data_request?id=status&DataVersion=516611502&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464388383 HTTP/1.1 tcp{client}: 0x55b601e62df8 2021-08-20 14:59:48.813 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611502&Timeout=60&MinimumDelay=1500&_=1629292536031 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:48.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.854 openLuup.server:: request completed (49215 bytes, 4 chunks, 21 ms) tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:48.856 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600c44bf8 2021-08-20 14:59:49.829 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.830 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.835 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:49.835 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600e1fea8 2021-08-20 14:59:50.831 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.832 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.837 openLuup.server:: request completed (49215 bytes, 4 chunks, 4 ms) tcp{client}: 0x55b601cfa118 2021-08-20 14:59:50.838 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601cfa118 2021-08-20 14:59:51.833 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.835 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.852 openLuup.server:: request completed (49215 bytes, 4 chunks, 17 ms) tcp{client}: 0x55b601462bb8 2021-08-20 14:59:51.854 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601462bb8 2021-08-20 14:59:52.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.847 openLuup.server:: request completed (49215 bytes, 4 chunks, 11 ms) tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:52.848 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6016b1c98 2021-08-20 14:59:53.193 luup.variable_set:: 10005.urn:micasaverde-com:serviceId:SceneController1.sl_SceneActivated was: 255 now: 255 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10006.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10094.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10096.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10098.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.193 luup.variable_set:: 10104.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10106.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10109.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_UserCode was: UserID="4" UserName="Ella" now: UserID="4" UserName="Ella" #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_LockButton was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:DoorLock1.sl_PinFailed was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10112.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10131.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10132.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10133.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10165.urn:micasaverde-com:serviceId:HaDevice1.sl_Alarm was: SMOKE now: SMOKE #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10165.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 0 now: 0 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10188.urn:micasaverde-com:serviceId:HaDevice1.sl_TamperAlarm was: 1 now: 1 #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10188.urn:micasaverde-com:serviceId:HaDevice1.sl_Alarm was: TAMPER_ALARM now: TAMPER_ALARM #hooks:0 2021-08-20 14:59:53.194 luup.variable_set:: 10191.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 10 now: 10 #hooks:0 2021-08-20 14:59:53.299 openLuup.server:: request completed (5449 bytes, 1 chunks, 4485 ms) tcp{client}: 0x55b601a37db8 2021-08-20 14:59:53.505 openLuup.server:: request completed (5449 bytes, 1 chunks, 5119 ms) tcp{client}: 0x55b601e62df8 2021-08-20 14:59:53.511 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601e62df8 2021-08-20 14:59:53.513 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=516611523&Timeout=60&MinimumDelay=1500&_=1629292536032 HTTP/1.1 tcp{client}: 0x55b601a37db8 2021-08-20 14:59:53.522 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600bc7068 2021-08-20 14:59:53.524 openLuup.server:: GET /data_request?id=status&DataVersion=516611523&Timeout=15&MinimumDelay=100&output_format=json&_r=1629464393521 HTTP/1.1 tcp{client}: 0x55b600bc7068 2021-08-20 14:59:53.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.835 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.840 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:53.841 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b601b8cbe8 2021-08-20 14:59:54.834 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.849 openLuup.server:: request completed (49215 bytes, 4 chunks, 12 ms) tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:54.850 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b6013dacd8 2021-08-20 14:59:55.835 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b602316198 2021-08-20 14:59:55.836 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b602316198 2021-08-20 14:59:55.841 openLuup.server:: request completed (49215 bytes, 4 chunks, 5 ms) tcp{client}: 0x55b602316198 2021-08-20 14:59:55.842 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b602316198 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601547598 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6016c7cf8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b600b75158 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60187d188 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6011a5bf8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60115ecd8 2021-08-20 15:00:10.955 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601018c18 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60175d068 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60224ced8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b6017869d8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601ab40e8 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601914178 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60100a228 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b60197a998 2021-08-20 15:00:10.956 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601103238 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600c62438 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601eaabf8 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6017c95b8 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600d6e508 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601dd2168 2021-08-20 15:00:10.956 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60155eb68 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6016ddcd8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b602384ca8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60230cc78 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6017e3338 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600965de8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601e23608 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6018da2f8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600c9aa08 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600bbf0f8 2021-08-20 15:00:10.957 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601334518 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60183b5f8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6015682a8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6018869e8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6008839c8 2021-08-20 15:00:10.958 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60154ed58 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601a259e8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b600f617c8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6015884c8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601c85fe8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b602275ae8 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b60190ab88 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601692038 2021-08-20 15:00:10.959 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601fcea78 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601ca7f28 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b601fd37f8 2021-08-20 15:00:10.960 openLuup.io.server:: MQTT:1888 connection from 127.0.0.1 tcp{client}: 0x55b6020ec968 2021-08-20 15:00:10.961 openLuup.server:: GET /data_request?id=variableget&DeviceNum=0&serviceId=urn:micasaverde-com:serviceId:HomeAutomationGateway1&Variable=Mode&_=1629292536033 HTTP/1.1 tcp{client}: 0x55b601ab8228 2021-08-20 15:00:10.967 luup_log:0: 32Mb, 3.3%cpu, 11.0days 2021-08-20 15:00:10.972 openLuup.server:: request completed (3361 bytes, 1 chunks, 17459 ms) tcp{client}: 0x55b601a37db8 2021-08-20 15:00:10.973 openLuup.server:: request completed (3361 bytes, 1 chunks, 17449 ms) tcp{client}: 0x55b600bc7068 2021-08-20 15:00:10.990 luup.variable_set:: 10116.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 21.8 now: 21.9 #hooks:0 2021-08-20 15:00:10.990 luup.variable_set:: 10129.urn:micasaverde-com:serviceId:HumiditySensor1.CurrentLevel was: 58.8 now: 58.7 #hooks:0 2021-08-20 15:00:10.991 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.991 openLuup.mqtt:: closed tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.992 openLuup.mqtt:: mqttthing_Klimat kllaren_838dee2e UNSUBSCRIBE from tele/Källartemp/SENSOR tcp{client}: 0x55b600ba45a8 2021-08-20 15:00:10.992 openLuup.mqtt:: ERROR publishing application message for mqtt:tele/Källartemp/SENSOR : closed 2021-08-20 15:00:10.992 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55b601c8c288 2021-08-20 15:00:10.992 openLuup.io.server:: HTTP:3480 connection closed openLuup.server.receive closed tcp{client}: 0x55b600bc7068 2021-08-20 15:00:10.992 openLuup.server:: GET /data_request?id=sdata HTTP/1.1 tcp{client}: 0x55b601547598 2021-08-20 15:00:10.993 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.993 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Uttag garaget_6f4265a1 UNSUBSCRIBE from openLuup/update/10149/SwitchPower1/Status tcp{client}: 0x55b600a62818 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Takflkt hallen_6da387bf UNSUBSCRIBE from tele/TakfläktHall/LWT tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Takflkt hallen_6da387bf UNSUBSCRIBE from stat/TakfläktHall/POWER2 tcp{client}: 0x55b600ba8428 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Klimat sovrummet_0d664e41 UNSUBSCRIBE from openLuup/update/20010/HumiditySensor1/CurrentLevel tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Klimat sovrummet_0d664e41 UNSUBSCRIBE from openLuup/update/20021/TemperatureSensor1/CurrentTemperature tcp{client}: 0x55b600e59b88 2021-08-20 15:00:10.994 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.994 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.994 openLuup.mqtt:: mqttthing_Entrdrr_6acda58a UNSUBSCRIBE from openLuup/update/10095/SecuritySensor1/Tripped tcp{client}: 0x55b600bd02d8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Temperatur poolen_a589d192 UNSUBSCRIBE from tele/Pooltemp/SENSOR tcp{client}: 0x55b600bb6cf8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Rrelsesensor hallen_cf7c8293 UNSUBSCRIBE from openLuup/update/20013/SecuritySensor1/Tripped tcp{client}: 0x55b6009ff868 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Luftfuktighet badrum_d79a0ffb UNSUBSCRIBE from openLuup/update/10190/HumiditySensor1/CurrentLevel tcp{client}: 0x55b600a23e28 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Ljussensor hallen_19569c17 UNSUBSCRIBE from openLuup/update/20006/LightSensor1/CurrentLevel tcp{client}: 0x55b600bb33b8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Ljussensor trningsrum_ebf319c5 UNSUBSCRIBE from openLuup/update/20004/LightSensor1/CurrentLevel tcp{client}: 0x55b600a136b8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Solceller watt_e351a23b UNSUBSCRIBE from openLuup/update/10163/LightSensor1/CurrentLevel tcp{client}: 0x55b600babaa8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.mqtt:: mqttthing_Luftfuktighet dusch_91df9a58 UNSUBSCRIBE from openLuup/update/20008/HumiditySensor1/CurrentLevel tcp{client}: 0x55b6004a9de8 2021-08-20 15:00:10.995 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.995 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Altandrr kk_db6d3edd UNSUBSCRIBE from openLuup/update/10097/SecuritySensor1/Tripped tcp{client}: 0x55b600b84628 2021-08-20 15:00:10.996 openLuup.io.server:: MQTT:1888 connection closed tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Test datarum_adbe85e6 UNSUBSCRIBE from openLuup/update/20007/Dimming1/LoadLevelTarget tcp{client}: 0x55b600be6548 2021-08-20 15:00:10.996 openLuup.mqtt:: mqttthing_Test datarum_adbe85e6 UNSUBSCRIBE from openLuup/update/20007/SwitchPower1/Status tcp{client}: 0x55b600be6548And then in syslog:
OpenLuup unavailable
Just in case you would want to know how to update these libraries:
Need to install luarocks. This depends on what machine you are using but assuming you are on a debian base,sudo apt-get install luarocks
will do it. then you can start upgrading things:
@archers said in OpenLuup unavailable:
Much worse that what it was 3-4 days ago for some reason. Then the system was quite snappy, but after some time. This was on v21.3.25b, now I updated to 21.3.26, I will see if ot continues to be slow.
OK, I have a possible answer to that. The system wait for up to a specified period of time if it fins that a socket is not ready to send. Initially, I used a timeout of zero (v21.3.24) bad choice, since most things timed out. Changed it to 0.2 seconds (v21.3.24b) , and later, then to 1.0 seconds (v21.3.26).
I will rever to something smaller, perhaps 0.1s. But you can change this (for the HTTP server) with:
luup.attr_set ("openLuup.HTTP.SelectWait", 0.1)
Again, apologies, but your excellent reporting of the effect of these changes is a very efficient way for me to zero in on issues, for which, thanks.
@akbooer thanks! I see that my text above got a bit incomplete.
This is how it should be ( I think, many updates lately ) :
What I still have noticed is that the system has been quite slow on v21.3.25b and v2.3.24b with at times very long response times. Much worse that what it was 3-4 days ago for some reason, before updating from v2.3.21 to v2.3.24b.
On 2.3.21 the system was quite snappy, but after some time crashed without warning.
Now I updated to 21.3.26 and so far it seems much more responsive that on v2.3.24b / v21.3.25b.For clarity I edited the post above also.
A short status update.
Yesterday evening I updated OpenLupp to v21.3.26 and LuaFileSystem to 1.8.0.
I have since then left the system up and running as-is, i.e. without Mqtt re-enabled and with most of the http updates from my various Tasmota devices turned off.So far so good, the system seems as responsive as it has been earlier for the past approx 20 hours.
I have not changed the http server waiting time, it is at the default value for v21.3.26.When looking in the logs, it looks ok. Usually quite fast responses and no errors.
I found two similar lines that had a bit longer response time:
2002 lines, 0 errors, max gap 41s @ 2021-03-28 17:30:00.131 2021-03-28 17:29:18.910 luup.variable_set:: 10909.urn:micasaverde-com:serviceId:HaDevice1.sl_BatteryAlarm was: 0 now: 0 #hooks:0 2021-03-28 17:30:00.131 luup_log:0: 40Mb, 3.5%cpu, 0.8days 2021-03-28 17:30:00.646 luup.variable_set:: 68.urn:toggledbits-com:serviceId:ReactorSensor.cstate was: {"cond0":{"evaledge":[],"stateedge":[],"valuestamp":1615722020,"id":"cond0","statestamp":0,"lastvalue":0},"vars":{"... now: {"cond0":{"evaledge":[],"stateedge":[],"valuestamp":1615722020,"id":"cond0","statestamp":0,"lastvalue":0},"vars":{"... #hooks:0 2002 lines, 0 errors, max gap 65s @ 2021-03-28 16:54:07.724 2021-03-28 16:53:02.682 luup.variable_set:: 244.urn:toggledbits-com:serviceId:VirtualSensor1.LastUpdate was: 1616943122 now: 1616943182 #hooks:0 2021-03-28 16:54:07.724 luup_log:0: 44Mb, 1.5%cpu, 0.7days 2021-03-28 16:54:07.755 luup.variable_set:: 122.urn:toggledbits-com:serviceId:DelayLightTimer.Message was: Delay Off 9m now: Delay Off 8m #hooks:0
I will keep off the system until tomorrow to see that it is stable over time before I restart the Mqtt server.
I looked in the logs again after I had some slow responses in the system and found some errors. The IP address 192.168.1.127 this my iPhone and Homewave. I tested with Homewave on my iPad and got a similar set of errors for that IP address. These errors seem to be in the direction of what @rafale77 mentioned.
Edit: Still had some errors so I changed it to 0.1 which seems to give even fewer errors.
I changed the http server wait to0.20.1 from 1.0 withluup.attr_set ("openLuup.HTTP.SelectWait", 0.1)
and it seems as if it may have helped removing the errors. I will check some more later on and see if the errors return.From the log file:
2021-03-28 19:58:23.148 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x55979ef92ba8 2021-03-28 19:58:23.148 openLuup.server:: error 'closed' sending 6 bytes to tcp{client}: 0x55979ef92ba8 2021-03-28 19:58:23.148 openLuup.server:: error 'closed' sending 858578 bytes to tcp{client}: 0x55979ef92ba8 2021-03-28 19:58:23.148 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x55979ef92ba8 2021-03-28 19:58:23.149 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x55979ef92ba8 2021-03-28 20:01:02.561 openLuup.server:: error 'closed' sending 4 bytes to tcp{client}: 0x55979f3f9768 2021-03-28 20:01:02.561 openLuup.server:: error 'closed' sending 104 bytes to tcp{client}: 0x55979f3f9768 2021-03-28 20:01:02.561 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x55979f3f9768 ... 2021-03-28 19:58:21.155 openLuup.io.server:: HTTP:3480 connection from 192.168.1.127 tcp{client}: 0x55979ef92ba8 2021-03-28 20:01:00.882 openLuup.io.server:: HTTP:3480 connection from 127.0.0.1 tcp{client}: 0x55979f3f9768 2021-03-28 19:58:22.954 luup_log:203: VirtualBinaryLight[2.40@203]:[updateMeters] Watts Path: "meters[1].power" - Value: 0 2021-03-28 19:58:23.148 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x55979ef92ba8 2021-03-28 19:58:23.148 openLuup.server:: ...only 0 bytes sent 2021-03-28 19:58:23.148 openLuup.server:: error 'closed' sending 6 bytes to tcp{client}: 0x55979ef92ba8 2021-03-28 19:58:23.148 openLuup.server:: ...only 0 bytes sent 2021-03-28 19:58:23.148 openLuup.server:: error 'closed' sending 858578 bytes to tcp{client}: 0x55979ef92ba8 2021-03-28 19:58:23.148 openLuup.server:: ...only 64000 bytes sent 2021-03-28 19:58:23.148 openLuup.server:: error 'closed' sending 2 bytes to tcp{client}: 0x55979ef92ba8 2021-03-28 19:58:23.148 openLuup.server:: ...only 0 bytes sent 2021-03-28 19:58:23.149 openLuup.server:: error 'closed' sending 5 bytes to tcp{client}: 0x55979ef92ba8 2021-03-28 19:58:23.149 openLuup.server:: ...only 0 bytes sent 2021-03-28 19:58:23.149 openLuup.server:: request completed (858578 bytes, 5 chunks, 446 ms) tcp{client}: 0x55979ef92ba8
I have now had the Mqtt server up and running for approx 30 hours without any crashes so far, a step in the right direction as it seems.
I am still on OpenLuup version: v21.3.26 and LuaFileSystem v1.8.0 (luasec not updated), want to keep the setup as-is to see what happens over longer time.
So far only one Tasmota device connected via Mqtt reporting every minute.
No errors in the log files (except for Homewave, see below), max response time usually approx 16 seconds. Changing the http wait to 0.1 was a big change. With 1.0 OpenLuup was sluggish and there is a noticable difference also when comparing to 0.2.
With 0.1 the system is much better.Messages as displayed by MqttExplorer:
I have noticed two brief Mqtt disconnects during this time.
Log file:1575 lines, 0 errors, max gap 75s @ 2021-03-29 13:35:48.179 2021-03-29 13:34:33.581 luup.variable_set:: 216.urn:upnp-org:serviceId:TemperatureSensor1.CurrentTemperature was: 25.3 now: 25.4 #hooks:0 2021-03-29 13:34:33.582 luup.variable_set:: 228.urn:micasaverde-com:serviceId:HumiditySensor1.CurrentLevel was: 36.1 now: 36.1 #hooks:0 2021-03-29 13:35:48.179 openLuup.io.server:: MQTT:1883 connection from 192.168.1.60 tcp{client}: 0x5652106f2f48 2021-03-29 13:35:48.180 openLuup.io.server:: HTTP:3480 connection closed EXPIRED tcp{client}: 0x56520e9d91c8 2021-03-29 13:35:48.180 openLuup.io.server:: MQTT:1883 connection closed EXPIRED tcp{client}: 0x565210622978 2021-03-29 13:35:48.180 openLuup.mqtt:: mqtt-explorer-22233d66 UNSUBSCRIBE from # tcp{client}: 0x565210622978 2021-03-29 13:35:48.180 openLuup.mqtt:: mqtt-explorer-22233d66 UNSUBSCRIBE from $SYS/# tcp{client}: 0x565210622978
Log from the Tasmota device console:
12:43:08 MQT: tele/tasmota_test/SENSOR = {"Time":"2021-03-29T12:43:08","AM2301":{"Temperature":25.4,"Humidity":36.1,"DewPoint":9.3},"TempUnit":"C"} 12:43:33 MQT: Attempting connection... 12:43:48 MQT: Connect failed to 192.168.1.107:1883, rc -4. Retry in 10 sec 12:43:59 MQT: Attempting connection... 12:44:10 MQT: Connected 12:44:10 MQT: tele/tasmota_test/LWT = Online (retained) 12:44:10 MQT: cmnd/tasmota_test/POWER = 12:44:33 MQT: tele/tasmota_test/STATE = {"Time":"2021-03-29T12:44:33","Uptime":"0T01:05:15","UptimeSec":3915,"Heap":26,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":4,"Wifi":{"AP":1,"SSId":"BeachAC","BSSId":"FC:EC:DA:D1:7A:64","Channel":11,"RSSI":100,"Signal":-50,"LinkCount":1,"Downtime":"0T00:00:03"}}
It reconnected without problem quite fast, so that seems to be fine.
I have not used Homewave very much during this time, but it also seems to work ok. However I do see errors for it when I use it. So something is not 100% right there perhaps. I got more errors with a longer http wait (1.0 >> 0.2 > 0.1).
Log file:2021-03-30 20:10:47.908 openLuup.server:: request completed (5907 bytes, 1 chunks, 194 ms) tcp{client}: 0x565210f173b8 2021-03-30 20:10:48.260 openLuup.server:: GET /data_request?output_format=json&id=lu_status HTTP/1.1 tcp{client}: 0x5652108936d8 2021-03-30 20:10:48.484 openLuup.server:: error 'socket.select() not ready to send tcp{client}: 0x5652108936d8' sending 2 bytes to tcp{client}: 0x5652108936d8 2021-03-30 20:10:48.563 openLuup.server:: request completed (858554 bytes, 54 chunks, 302 ms) tcp{client}: 0x5652108936d8 2021-03-30 20:10:48.932 openLuup.server:: GET /data_request?id=lu_status2&output_format=json&DataVersion=14594009&Timeout=60&MinimumDelay=1500&_=1617014398016 HTTP/1.1 tcp{client}: 0x565210f173b8 2021-03-30 20:10:49.068 openLuup.server:: request completed (5909 bytes, 1 chunks, 135 ms) tcp{client}: 0x565210f173b8
@akbooer today I got another crash unfortunately.
I had it up and running with two Mqtt devices reporting during approx 24 hours before the crash. Before that approx 2 days with one device.
This morning 4 hours before the crash it looked like this:
When looking through the log I can find the a lot of errors building up the last 2.5 hours before the crash.
2021-04-01 10:10:20.698 openLuup.io.server:: MQTT:1883 connection closed tcp{client}: 0x55d8bb5a9b48 2021-04-01 10:10:20.698 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bb5a9b48 2021-04-01 10:10:20.698 openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum_fb/# tcp{client}: 0x55d8bb5a9b48 2021-04-01 10:10:20.698 openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum/# tcp{client}: 0x55d8bb5a9b48 2021-04-01 10:10:20.698 openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55d8bb5a9b48 ... 2021-04-01 10:10:20.707 openLuup.io.server:: MQTT:1883 connection closed tcp{client}: 0x55d8bae0e948 2021-04-01 10:10:20.707 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bae0e948 ... 2021-04-01 10:10:20.709 openLuup.io.server:: MQTT:1883 connection closed tcp{client}: 0x55d8bb8a48a8 2021-04-01 10:10:20.709 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bb8a48a8 2021-04-01 10:10:20.709 openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test_fb/# tcp{client}: 0x55d8bb8a48a8 2021-04-01 10:10:20.709 openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55d8bb8a48a8 2021-04-01 10:10:20.709 openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test/# tcp{client}: 0x55d8bb8a48a8 2021-04-01 10:10:20.741 openLuup.io.server:: MQTT:1883 connection from 192.168.1.50 tcp{client}: 0x55d8bad50918 2021-04-01 10:10:20.744 openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmota_test/# tcp{client}: 0x55d8bb53f518 2021-04-01 10:10:20.746 openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x55d8bb53f518 2021-04-01 10:10:20.752 openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmota_test_fb/# tcp{client}: 0x55d8bb53f518 2021-04-01 10:10:20.770 openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/TasmotaUterum/# tcp{client}: 0x55d8bad50918 2021-04-01 10:10:20.770 openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x55d8bad50918 2021-04-01 10:10:20.771 openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/TasmotaUterum_fb/# tcp{client}: 0x55d8bad50918 ... 2021-04-01 10:13:26.365 openLuup.io.server:: MQTT:1883 connection closed tcp{client}: 0x55d8bb6e71e8 2021-04-01 10:13:26.365 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bb6e71e8 2021-04-01 10:13:26.365 openLuup.io.server:: MQTT:1883 connection closed tcp{client}: 0x55d8bab0a8d8 2021-04-01 10:13:26.365 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bab0a8d8 .. 2021-04-01 10:13:26.368 openLuup.io.server:: MQTT:1883 connection closed tcp{client}: 0x55d8bad50918 2021-04-01 10:13:26.368 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bad50918 2021-04-01 10:13:26.368 openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum_fb/# tcp{client}: 0x55d8bad50918 2021-04-01 10:13:26.368 openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum/# tcp{client}: 0x55d8bad50918 2021-04-01 10:13:26.368 openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55d8bad50918 2021-04-01 10:13:26.368 openLuup.io.server:: MQTT:1883 connection closed tcp{client}: 0x55d8bb53f518 2021-04-01 10:13:26.368 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bb53f518 2021-04-01 10:13:26.368 openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test_fb/# tcp{client}: 0x55d8bb53f518 2021-04-01 10:13:26.368 openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55d8bb53f518 2021-04-01 10:13:26.368 openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test/# tcp{client}: 0x55d8bb53f518 2021-04-01 10:13:26.374 openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/TasmotaUterum/# tcp{client}: 0x55d8bacf35d8 2021-04-01 10:13:26.379 openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x55d8bacf35d8 2021-04-01 10:13:26.386 openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/TasmotaUterum_fb/# tcp{client}: 0x55d8bacf35d8 2021-04-01 10:13:26.397 openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmota_test/# tcp{client}: 0x55d8bad3fc48 2021-04-01 10:13:26.400 openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x55d8bad3fc48 2021-04-01 10:13:26.406 openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmota_test_fb/# tcp{client}: 0x55d8bad3fc48 .. 2021-04-01 10:35:23.058 openLuup.io.server:: MQTT:1883 connection closed tcp{client}: 0x55d8bacf35d8 2021-04-01 10:35:23.059 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bacf35d8 2021-04-01 10:35:23.059 openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum_fb/# tcp{client}: 0x55d8bacf35d8 2021-04-01 10:35:23.059 openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum/# tcp{client}: 0x55d8bacf35d8 2021-04-01 10:35:23.059 openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55d8bacf35d8 ... 2021-04-01 10:35:23.088 openLuup.io.server:: MQTT:1883 connection closed tcp{client}: 0x55d8bb736018 2021-04-01 10:35:23.088 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bb736018 2021-04-01 10:35:23.088 openLuup.io.server:: MQTT:1883 connection closed tcp{client}: 0x55d8bb7380c8 2021-04-01 10:35:23.089 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bb7380c8 ... 2021-04-01 10:35:23.096 openLuup.io.server:: MQTT:1883 connection closed tcp{client}: 0x55d8bad3fc48 2021-04-01 10:35:23.096 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bad3fc48 2021-04-01 10:35:23.096 openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test_fb/# tcp{client}: 0x55d8bad3fc48 2021-04-01 10:35:23.096 openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55d8bad3fc48 2021-04-01 10:35:23.096 openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test/# tcp{client}: 0x55d8bad3fc48 2021-04-01 10:35:25.955 openLuup.io.server:: MQTT:1883 connection from 192.168.1.50 tcp{client}: 0x55d8b9bd4838 2021-04-01 10:35:25.973 openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/TasmotaUterum/# tcp{client}: 0x55d8b9bd4838 2021-04-01 10:35:25.977 openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x55d8b9bd4838 2021-04-01 10:35:25.977 openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/TasmotaUterum_fb/# tcp{client}: 0x55d8b9bd4838 2021-04-01 10:35:29.040 openLuup.io.server:: MQTT:1883 connection from 192.168.1.60 tcp{client}: 0x55d8bb605448 2021-04-01 10:35:29.058 openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmota_test/# tcp{client}: 0x55d8bb605448 2021-04-01 10:35:29.062 openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x55d8bb605448 2021-04-01 10:35:29.063 openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmota_test_fb/# tcp{client}: 0x55d8bb605448 ... 2021-04-01 10:39:23.441 openLuup.io.server:: MQTT:1883 connection closed tcp{client}: 0x55d8b9bd4838 2021-04-01 10:39:23.441 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8b9bd4838 2021-04-01 10:39:23.441 openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum_fb/# tcp{client}: 0x55d8b9bd4838 2021-04-01 10:39:23.441 openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum/# tcp{client}: 0x55d8b9bd4838 2021-04-01 10:39:23.441 openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55d8b9bd4838 ... 2021-04-01 10:39:29.585 openLuup.io.server:: MQTT:1883 connection from 192.168.1.60 tcp{client}: 0x55d8b8fedf68 2021-04-01 10:39:29.585 openLuup.io.server:: MQTT:1883 connection closed tcp{client}: 0x55d8baee2da8 2021-04-01 10:39:29.585 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8baee2da8 2021-04-01 10:39:29.585 openLuup.io.server:: MQTT:1883 connection closed tcp{client}: 0x55d8baacc308 2021-04-01 10:39:29.585 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8baacc308 ... 2021-04-01 10:39:35.729 openLuup.io.server:: MQTT:1883 connection closed tcp{client}: 0x55d8bb605448 2021-04-01 10:39:35.729 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bb605448 2021-04-01 10:39:35.729 openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test_fb/# tcp{client}: 0x55d8bb605448 ... 2021-04-01 10:40:49.043 openLuup.context_switch:: ERROR: [dev #106] table: 0x55d8bb856790 2021-04-01 10:40:49.043 luup.incoming_callback:: function: 0x55d8bacaad00 ERROR: table: 0x55d8bb856790 ... 2021-04-01 10:43:20.159 openLuup.io.server:: MQTT:1883 connection closed tcp{client}: 0x55d8bb0f87b8 2021-04-01 10:43:20.159 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bb0f87b8 ... 2021-04-01 10:43:20.161 openLuup.io.server:: MQTT:1883 connection closed tcp{client}: 0x55d8b8fedf68 2021-04-01 10:43:20.161 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8b8fedf68 2021-04-01 10:43:20.161 openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test_fb/# tcp{client}: 0x55d8b8fedf68 2021-04-01 10:43:20.161 openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55d8b8fedf68 2021-04-01 10:43:20.161 openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test/# tcp{client}: 0x55d8b8fedf68 2021-04-01 10:43:20.161 openLuup.io.server:: MQTT:1883 connection closed tcp{client}: 0x55d8bb46f488 2021-04-01 10:43:20.161 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bb46f488 2021-04-01 10:43:20.161 openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum_fb/# tcp{client}: 0x55d8bb46f488 2021-04-01 10:43:20.162 openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum/# tcp{client}: 0x55d8bb46f488 2021-04-01 10:43:20.162 openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55d8bb46f488 2021-04-01 10:43:20.254 openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/TasmotaUterum/# tcp{client}: 0x55d8ba375f28 2021-04-01 10:43:20.258 openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x55d8ba375f28 2021-04-01 10:43:20.258 openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/TasmotaUterum_fb/# tcp{client}: 0x55d8ba375f28 2021-04-01 10:43:20.260 openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmota_test/# tcp{client}: 0x55d8bb83d468 2021-04-01 10:43:20.260 openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x55d8bb83d468 2021-04-01 10:43:20.260 openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmota_test_fb/# tcp{client}: 0x55d8bb83d468 ... 2021-04-01 10:51:25.662 openLuup.io.server:: MQTT:1883 connection closed tcp{client}: 0x55d8baaa6608 2021-04-01 10:51:25.662 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8baaa6608 2021-04-01 10:51:25.663 openLuup.io.server:: MQTT:1883 connection closed tcp{client}: 0x55d8badfb488 2021-04-01 10:51:25.663 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8badfb488 ... 2021-04-01 10:51:25.665 openLuup.io.server:: MQTT:1883 connection closed tcp{client}: 0x55d8bb83d468 2021-04-01 10:51:25.665 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bb83d468 2021-04-01 10:51:25.665 openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test_fb/# tcp{client}: 0x55d8bb83d468 2021-04-01 10:51:25.665 openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55d8bb83d468 2021-04-01 10:51:25.665 openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test/# tcp{client}: 0x55d8bb83d468 2021-04-01 10:51:25.665 openLuup.io.server:: MQTT:1883 connection closed tcp{client}: 0x55d8ba375f28 2021-04-01 10:51:25.665 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8ba375f28 2021-04-01 10:51:25.665 openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum_fb/# tcp{client}: 0x55d8ba375f28 2021-04-01 10:51:25.665 openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum/# tcp{client}: 0x55d8ba375f28 2021-04-01 10:51:25.665 openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55d8ba375f28 2021-04-01 10:51:25.735 openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/TasmotaUterum/# tcp{client}: 0x55d8ba738ad8 2021-04-01 10:51:25.739 openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x55d8ba738ad8 2021-04-01 10:51:25.739 openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/TasmotaUterum_fb/# tcp{client}: 0x55d8ba738ad8 2021-04-01 10:51:25.844 openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmota_test/# tcp{client}: 0x55d8baf3baa8 2021-04-01 10:51:25.847 openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x55d8baf3baa8 2021-04-01 10:51:25.851 openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmota_test_fb/# tcp{client}: 0x55d8baf3baa8 ... 2021-04-01 10:54:32.113 openLuup.io.server:: MQTT:1883 connection closed tcp{client}: 0x55d8baf3baa8 2021-04-01 10:54:32.113 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8baf3baa8 2021-04-01 10:54:32.113 openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test_fb/# tcp{client}: 0x55d8baf3baa8 2021-04-01 10:54:32.113 openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55d8baf3baa8 2021-04-01 10:54:32.113 openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test/# tcp{client}: 0x55d8baf3baa8 2021-04-01 10:54:32.113 openLuup.io.server:: MQTT:1883 connection closed tcp{client}: 0x55d8ba738ad8 2021-04-01 10:54:32.113 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8ba738ad8 2021-04-01 10:54:32.113 openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum_fb/# tcp{client}: 0x55d8ba738ad8 2021-04-01 10:54:32.113 openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum/# tcp{client}: 0x55d8ba738ad8 2021-04-01 10:54:32.113 openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55d8ba738ad8 2021-04-01 10:54:32.175 openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/TasmotaUterum/# tcp{client}: 0x55d8ba6ce668 2021-04-01 10:54:32.178 openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmota_test/# tcp{client}: 0x55d8bb6b8028 2021-04-01 10:54:32.185 openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x55d8bb6b8028 2021-04-01 10:54:32.185 openLuup.mqtt:: tasmota_test SUBSCRIBE to cmnd/tasmota_test_fb/# tcp{client}: 0x55d8bb6b8028 2021-04-01 10:54:32.190 openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/tasmotas/# tcp{client}: 0x55d8ba6ce668 2021-04-01 10:54:32.190 openLuup.mqtt:: TasmotaUterum SUBSCRIBE to cmnd/TasmotaUterum_fb/# tcp{client}: 0x55d8ba6ce668 ... <<<<repeats itself every 3rd minute or so>>>> ... 2021-04-01 12:42:40.786 openLuup.io.server:: MQTT:1883 connection closed tcp{client}: 0x55d8bb0f87b8 2021-04-01 12:42:40.786 openLuup.mqtt:: closed tcp{client}: 0x55d8bb0f87b8 2021-04-01 12:42:40.786 openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test_fb/# tcp{client}: 0x55d8bb0f87b8 2021-04-01 12:42:40.786 openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55d8bb0f87b8 2021-04-01 12:42:40.786 openLuup.mqtt:: tasmota_test UNSUBSCRIBE from cmnd/tasmota_test/# tcp{client}: 0x55d8bb0f87b8 2021-04-01 12:42:40.786 openLuup.mqtt:: ERROR publishing application message for mqtt:cmnd/tasmota_test/POWER : closed 2021-04-01 12:42:40.786 openLuup.io.server:: MQTT:1883 connection closed tcp{client}: 0x55d8bab88d38 2021-04-01 12:42:40.786 openLuup.mqtt:: RECEIVE ERROR: closed tcp{client}: 0x55d8bab88d38 2021-04-01 12:42:40.786 openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum_fb/# tcp{client}: 0x55d8bab88d38 2021-04-01 12:42:40.786 openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/TasmotaUterum/# tcp{client}: 0x55d8bab88d38 2021-04-01 12:42:40.786 openLuup.mqtt:: TasmotaUterum UNSUBSCRIBE from cmnd/tasmotas/# tcp{client}: 0x55d8bab88d38 <<<<crashed>>>>
In addition to the above I also found the following in the log, during one period (approx 20 times during a few minutes, two hours before the crash) "no route to host" for the Zway server (it is not on the same server as OpenLuup) and another error (only once), see below.
2021-04-01 10:39:23.440 luup_log:106: ZWay ASYNC request: No route to host 2021-04-01 10:40:49.043 openLuup.context_switch:: ERROR: [dev #106] table: 0x55d8bb856790 2021-04-01 10:40:49.043 luup.incoming_callback:: function: 0x55d8bacaad00 ERROR: table: 0x55d8bb856790
Now I have disabled the Mqtt and restarted the server to see what happens.
I have now tested this back and forth during the last few weeks and for some reason my OpenLuup installation crashes when I have Mqtt devices running against it for some time. Sometimes it takes a bit longer somtimes faster. I cannot see anything specific in the log, I think the socket crash mentioned above could be something.
I had it up and running for a few days with the Mqtt server enabled but no Mqtt devices sending any data to the server and then it did not crash.
The Homewave erros have disappeared more or less, I moved my Zway Pi so that it has proper gigabit Ethernet (it was on a slow powerline connection for historical reasons from when I set it up). That also amended the Zway delay errors in the log.
I have also tested it with @therealdb Mqtt bridge reporting over http and that seem to work.
I set up a fresh install OpenLuup on a Raspberry Pi 4 with Mqtt enabled and that did not crash. The devices were the same as I had for testing on my original server, so I can conclude they do work together with OpenLuup. The Pi did more or less only have the Mqtt server active.
Next step is to test and migrate my original configuration with the Zway etc integration and see if that works on the Pi or not.
