  4. Feature Request: Enhanced 'Reactor System' Environment State
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
1 Posts 1 Posters 537 Views 1 Watching
    I miss the days of Vax mainframes, when I could sit at the terminal and pull all manner of Unix system variables seemingly out of thin air, which were great for tracking cron jobs and batch files.
    Could the (already existing) reactor_system entity gain a few extra datapoints, such as (in descending order of importance):
    ◘ .last_rule_triggered.name // friendly rule name (string)
    ◘ .last_rule_triggered.id // rule _ID (string)
    ◘ .rules_set_by_name // array of currently SET reactions (rule names)
    ◘ .rules_set_by_id // array of currently SET reactions (rule _IDs)
    ◘ .rules_reset_by_name // array of currently RESET reactions (rule names)
    ◘ .rules_reset_by_id // array of currently RESET reactions (rule _IDs)
    Of course, not if any of this causes undue overhead in MSR! I realize much of this information can already be retrieved from Logs, but I'm looking toward including some of this "snapshot" information within SMTP messages sent to me whenever critical events happen, such as Vera restarting or rebooting without warning.
      164.0k
