  4. Alerts - (vera>device_699) does not have attribute ?attr?
@toggledbits I pulled the image (well, Watchtower did) and within minutes the whole system went offline. The log looks like it ends with 26143. [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mkahsmgf/26qq82mw-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lqyfljfi/22f8on0t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lsb61rw8/24oenqi2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/rule-lrh58he0:S-1c00gfib-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1c00dylr-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1nam9w5u-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miuh2qqi/22ls4lql-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1vj8sdfc-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1qanz01x-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/24lq19p6-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mk0o8iox/23oy468y-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miscg2h3/rule-miscg2h3:S-22gmbq1c-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrfjke/238p0old-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-m7ccsso5/re-m7ccsso5-1r0myjxa-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/19nl9wq2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3xk9t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3vv5m-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/re-ln7j2nqp-22mx9lzd-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/22mx87c8-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-licneppy/1mzwe7ht-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ml3194ih/25jqt1j4-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrg7kf/227hshak-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13ua1p95-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13uagam7-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x4cbv-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x2fyl-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-lscjrws1/238p5c22-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lbwr0jvq/1xkczf03-cons [latest-26143]2026-05-31T15:23:44.547Z <Structure:NOTICE> Structure Structure#1 stopped [latest-26143]2026-05-31T15:23:44.547Z <app:NOTICE> Closing APIs... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: closing... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: disconnecting from "192.168.1.23#82" (1001 service closing) [latest-26143]2026-05-31T15:23:44.548Z <httpapi:NOTICE> HTTP API closing... [latest-26143]2026-05-31T15:23:44.549Z <wsapi:NOTICE> wsapi: server closed [latest-26143]2026-05-31T15:23:44.549Z <httpapi:INFO> HTTP server closed. [latest-26143]2026-05-31T15:23:44.549Z <app:NOTICE> Stopping timers... [latest-26143]2026-05-31T15:23:44.551Z <app:null> Shutdown complete, process ID 1 [latest-26143]2026-05-31T15:23:44.551Z <app:null> Closing logs... [latest-26143]2026-05-31T15:23:44.551Z <default:null> Closing log I can SSH to the VM. Alas, I do not have the previous image for 26143 as I'm a little too quick sometimes on housekeeping.
Hi. First off this is an unsupported version of HS 2026.5.2 so happy to be told it's that. Currently running latest-26130-3d2a489a on a Debian Buster bare metal VM. I've been working on moving away from OpenLuup completely and up until now have been using some virtual switches t manage things like 'Is there anyone home' I have a binary sensor in HA that provides the same thing binary_sensor.someone_home which appears in MSR as hass>binary_sensor_someone_home HA shows on or off. MSR shows true or false All fine. The odd thing happened after an update of HA and a restart. From HA 13:07:04 it turned off 13:07:11 it turned on However that does not appear to have been reflected in MSR which turned all the heating and so on off as it is supposed to do, and I got all my notifications as I should. Here's a huge log section (sorry) as I wanted to show how MSR identifies that HA is up and running at 12:07:08 (Zulu) but triggers the 'There's no one here' at 12:07:17 some 6 seconds after HA updated to on. Checking in the interface MSR said the status was 'False' while HA stated 'On' rule-mkwk2fwa.dval:[{"id":1,"container":2,"value":3,"serial":92,"tss":93,"tsc":93},"rule-mkwk2fwa","rules",{"id":1,"serial":4,"triggers":5,"constraints":21,"expressions":24,"name":25,"react_set":26,"react_reset":88,"ruleset":91},16,{"type":6,"id":7,"op":8,"conditions":9,"editor_version":20},"group","trig","and",[10],{"id":11,"type":12,"data":13},"condmkwk2fwa","entity",{"entity":14,"attribute":15,"op":16,"value":17},"hass>person_rachel_matthews","x_hass.state","change",[18,19],null,"not_home",25351,{"type":6,"id":22,"op":8,"conditions":23},"cons",[],{},"Rachel is on the move",{"id":27,"actions":28,"rule":1,"editor_version":87,"set":61},"rule-mkwk2fwa:S",[29,35,62,83],{"id":30,"type":31,"data":32},"24kv27go","setvar",{"var":33,"value":34},"g_CurrentHour","${{int(strftime(\"%H\", time()))}}",{"id":36,"type":6,"actions":37,"constraints":46},"rule-mkwk2fwa:S-24kv7qgg",[38],{"id":39,"type":12,"data":40},"24kv4y1v",{"entity":41,"action":42,"args":43},"hass>system","x_hass_system.call_service",{"service":44,"data":45},"notify.alexa_media","{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has left the ${{g_rachel_last_area}} zone and is in transit \",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}",{"id":47,"name":48,"type":6,"op":8,"conditions":49,"editor_version":20},"rule-mkwk2fwa:S-24kv7qgg-cons","Group Constraints Copy",[50,55],{"id":51,"type":52,"data":53},"cond24kv89zv","comment",{"comment":54},"Should speak only when I'm home",{"id":56,"type":12,"data":57},"cond24kv7qgh",{"entity":58,"attribute":59,"op":60,"value":61},"mqqt>catman_iphone","binary_sensor.state","=",true,{"id":63,"type":6,"actions":64,"constraints":72},"rule-mkwk2fwa:S-24kv2lon",[65],{"id":66,"type":67,"data":68},"28xz6paf","notify",{"method":69,"message":70,"profile":71},"Telegram","Rachel has left the ${{g_rachel_last_area}} zone and is in transit","default",{"id":73,"name":48,"type":6,"op":8,"conditions":74,"editor_version":20},"rule-mkwk2fwa:S-24kv2lon-cons",[75,79],{"id":76,"type":52,"data":77},"cond24kvlpae",{"comment":78},"Should telegram while I am away",{"id":80,"type":12,"data":81},"cond24kvkyz7",{"entity":58,"attribute":59,"op":60,"value":82},false,{"id":84,"type":52,"data":85},"24kv7hvk",{"comment":86},"Enter comment text",25314,{"id":89,"actions":90,"rule":1,"set":82},"rule-mkwk2fwa:R",[],"rs-l5sdq41x",2,1779017869959] rule-mkwk2fwa.json:{"id":"rule-mkwk2fwa","container":"rules","value":{"id":"rule-mkwk2fwa","serial":16,"triggers":{"type":"group","id":"trig","op":"and","conditions":[{"id":"condmkwk2fwa","type":"entity","data":{"entity":"hass>person_rachel_matthews","attribute":"x_hass.state","op":"change","value":[null,"not_home"]}}],"editor_version":25351},"constraints":{"type":"group","id":"cons","op":"and","conditions":[]},"expressions":{},"name":"Rachel is on the move","react_set":{"id":"rule-mkwk2fwa:S","actions":[{"id":"24kv27go","type":"setvar","data":{"var":"g_CurrentHour","value":"${{int(strftime(\"%H\", time()))}}"}},{"id":"rule-mkwk2fwa:S-24kv7qgg","type":"group","actions":[{"id":"24kv4y1v","type":"entity","data":{"entity":"hass>system","action":"x_hass_system.call_service","args":{"service":"notify.alexa_media","data":"{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has left the ${{g_rachel_last_area}} zone and is in transit \",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}"}}}],"constraints":{"id":"rule-mkwk2fwa:S-24kv7qgg-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kv89zv","type":"comment","data":{"comment":"Should speak only when I'm home"}},{"id":"cond24kv7qgh","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":true}}],"editor_version":25351}},{"id":"rule-mkwk2fwa:S-24kv2lon","type":"group","actions":[{"id":"28xz6paf","type":"notify","data":{"method":"Telegram","message":"Rachel has left the ${{g_rachel_last_area}} zone and is in transit","profile":"default"}}],"constraints":{"id":"rule-mkwk2fwa:S-24kv2lon-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kvlpae","type":"comment","data":{"comment":"Should telegram while I am away"}},{"id":"cond24kvkyz7","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":false}}],"editor_version":25351}},{"id":"24kv7hvk","type":"comment","data":{"comment":"Enter comment text"}}],"rule":"rule-mkwk2fwa","editor_version":25314,"set":true},"react_reset":{"id":"rule-mkwk2fwa:R","actions":[],"rule":"rule-mkwk2fwa","set":false},"ruleset":"rs-l5sdq41x"},"serial":2,"tss":1779017869959,"tsc":1779017869959} rule-mkwlg11o.dval:[{"id":1,"container":2,"value":3,"serial":92,"tss":93,"tsc":93},"rule-mkwlg11o","rules",{"id":1,"serial":4,"triggers":5,"constraints":20,"expressions":23,"name":24,"react_set":25,"react_reset":88,"ruleset":91},5,{"type":6,"id":7,"op":8,"conditions":9,"editor_version":19},"group","trig","and",[10],{"id":11,"type":12,"data":13},"condmkwk2fwa","entity",{"entity":14,"attribute":15,"op":16,"value":17},"hass>person_rachel_matthews","x_hass.state","change",[18],"not_home",25351,{"type":6,"id":21,"op":8,"conditions":22},"cons",[],{},"Rachel has arrived",{"id":26,"actions":27,"rule":1,"editor_version":87,"set":65},"rule-mkwlg11o:S",[28,33,39,66,83],{"id":29,"type":30,"data":31},"24kvboht","script",{"expr":32},"g_rachel_last_area = getEntity(\"hass>person_rachel_matthews\").attributes['x_hass'].state",{"id":34,"type":35,"data":36},"24kvbohu","setvar",{"var":37,"value":38},"g_CurrentHour","${{int(strftime(\"%H\", time()))}}",{"id":40,"type":6,"actions":41,"constraints":50},"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohv",[42],{"id":43,"type":12,"data":44},"24kvbohw",{"entity":45,"action":46,"args":47},"hass>system","x_hass_system.call_service",{"service":48,"data":49},"notify.alexa_media","{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has arrived in the ${{g_rachel_last_area}} zone.\",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}",{"id":51,"name":52,"type":6,"op":8,"conditions":53,"editor_version":19},"24kvbohv-cons","Group Constraints Copy",[54,59],{"id":55,"type":56,"data":57},"cond24kv89zv","comment",{"comment":58},"Should speak only when I'm home",{"id":60,"type":12,"data":61},"cond24kv7qgh",{"entity":62,"attribute":63,"op":64,"value":65},"mqqt>catman_iphone","binary_sensor.state","=",true,{"id":67,"type":6,"actions":68,"constraints":76},"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohx",[69],{"id":70,"type":71,"data":72},"24kvbohy","notify",{"method":73,"message":74,"profile":75},"Telegram","Rachel has arrived in the ${{g_rachel_last_area}} zone.","default",{"id":77,"name":52,"type":6,"op":8,"conditions":78,"editor_version":19},"24kvbohx-cons",[79],{"id":80,"type":12,"data":81},"cond24kvmzfp",{"entity":62,"attribute":63,"op":64,"value":82},false,{"id":84,"type":56,"data":85},"24kvbohz",{"comment":86},"Enter comment text",25314,{"id":89,"actions":90,"rule":1,"set":82},"rule-mkwlg11o:R",[],"rs-l5sdq41x",1,1770023368433] rule-mkwlg11o.json:{"id":"rule-mkwlg11o","container":"rules","value":{"id":"rule-mkwlg11o","serial":5,"triggers":{"type":"group","id":"trig","op":"and","conditions":[{"id":"condmkwk2fwa","type":"entity","data":{"entity":"hass>person_rachel_matthews","attribute":"x_hass.state","op":"change","value":["not_home"]}}],"editor_version":25351},"constraints":{"type":"group","id":"cons","op":"and","conditions":[]},"expressions":{},"name":"Rachel has arrived","react_set":{"id":"rule-mkwlg11o:S","actions":[{"id":"24kvboht","type":"script","data":{"expr":"g_rachel_last_area = getEntity(\"hass>person_rachel_matthews\").attributes['x_hass'].state"}},{"id":"24kvbohu","type":"setvar","data":{"var":"g_CurrentHour","value":"${{int(strftime(\"%H\", time()))}}"}},{"id":"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohv","type":"group","actions":[{"id":"24kvbohw","type":"entity","data":{"entity":"hass>system","action":"x_hass_system.call_service","args":{"service":"notify.alexa_media","data":"{\n\"message\":\"Good ${{g_Greeting}} Chris. , Rachel has arrived in the ${{g_rachel_last_area}} zone.\",\n\"data\":{\"type\":\"announce\", \"method\":\"speak\"},\n\"target\":[\"media_player.everywhere\"]\n}"}}}],"constraints":{"id":"24kvbohv-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kv89zv","type":"comment","data":{"comment":"Should speak only when I'm home"}},{"id":"cond24kv7qgh","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":true}}],"editor_version":25351}},{"id":"rule-mkwlg11o:S-rule-mkwlg11o-24kvbohx","type":"group","actions":[{"id":"24kvbohy","type":"notify","data":{"method":"Telegram","message":"Rachel has arrived in the ${{g_rachel_last_area}} zone.","profile":"default"}}],"constraints":{"id":"24kvbohx-cons","name":"Group Constraints Copy","type":"group","op":"and","conditions":[{"id":"cond24kvmzfp","type":"entity","data":{"entity":"mqqt>catman_iphone","attribute":"binary_sensor.state","op":"=","value":false}}],"editor_version":25351}},{"id":"24kvbohz","type":"comment","data":{"comment":"Enter comment text"}}],"rule":"rule-mkwlg11o","editor_version":25314,"set":true},"react_reset":{"id":"rule-mkwlg11o:R","actions":[],"rule":"rule-mkwlg11o","set":false},"ruleset":"rs-l5sdq41x"},"serial":1,"tss":1770023368433,"tsc":1770023368433} catman@openluup:~/reactor/storage/rules$ exit logout Connection to 192.168.70.249 closed. catman@ChrisMBP2021 ~ % ./NotVera ** WARNING: connection is not using a post-quantum key exchange algorithm. ** This session may be vulnerable to "store now, decrypt later" attacks. ** The server may need to be upgraded. See https://openssh.com/pq.html Linux openluup 4.19.0-20-amd64 #1 SMP Debian 4.19.235-1 (2022-03-17) x86_64 The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Mon May 18 12:13:38 2026 from 192.168.70.69 cdcatman@openluup:~$ cd reactor/lo locales/ logs/ catman@openluup:~$ cd reactor/logs/ catman@openluup:~/reactor/logs$ ls console.log hass_config.json hass_services-2025-11-1.json hass_services-2026-1-0.json hass_services-2026-5-2.json reactor.log reactor.log.4 vera-user_data-initial.json device_32 hass_device_registry.json hass_services-2025-11-2.json hass_services-2026-1-1.json hass_services.json reactor.log.1 reactor.log.5 e hass_entity_registry.json hass_services-2025-11-3.json hass_services-2026-4-2.json hass_sources.json reactor.log.2 unhandled.json hass_area_registry.json hass_integrations.json hass_services-2025-7-2.json hass_services-2026-4-4.json hass_states.json reactor.log.3 vera-status-initial.json catman@openluup:~/reactor/logs$ less reactor.log catman@openluup:~/reactor/logs$ tail reactor.log [latest-26130]2026-05-19T12:20:08.296Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:21:03.391Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:21:08.729Z <Rule:INFO> Rule#rule-mova0cpn re-evaluating local variable L_Cinema_Light_Level for dependency notification from ValueSensor#hass>sensor_cinema_multi_sensor_illuminance [latest-26130]2026-05-19T12:21:08.734Z <Rule:INFO> Rule#rule-mova0cpn requesting eval for changed dependent locals Array(1) ["L_Cinema_Light_Level"] [latest-26130]2026-05-19T12:22:03.501Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:22:08.614Z <Rule:INFO> Rule#rule-mova0cpn re-evaluating local variable L_Cinema_Light_Level for dependency notification from ValueSensor#hass>sensor_cinema_multi_sensor_illuminance [latest-26130]2026-05-19T12:22:08.624Z <Rule:INFO> Rule#rule-mova0cpn requesting eval for changed dependent locals Array(1) ["L_Cinema_Light_Level"] [latest-26130]2026-05-19T12:23:03.590Z <httpapi:INFO> httpapi#1 API request from ::ffff:192.168.70.249: GET /api/v1/netstatus [latest-26130]2026-05-19T12:23:08.503Z <Rule:INFO> Rule#rule-mova0cpn re-evaluating local variable L_Cinema_Light_Level for dependency notification from ValueSensor#hass>sensor_cinema_multi_sensor_illuminance [latest-26130]2026-05-19T12:23:08.506Z <Rule:INFO> Rule#rule-mova0cpn requesting eval for changed dependent locals Array(1) ["L_Cinema_Light_Level"] catman@openluup:~/reactor/logs$ less reactor.log [latest-26130]2026-05-19T12:07:17.946Z <Rule:INFO> Cyrus Stream Vol+ (rule-ml9yjy9z in Living Room) starting rule state evaluation; because predicate-state-changed Predicate#rule-ml9yjy9z/trig [latest-26130]2026-05-19T12:07:17.947Z <Rule:INFO> Cyrus Stream Vol+ (rule-ml9yjy9z in Living Room) evaluated; rule state transition from RESET to 'SET' [latest-26130]2026-05-19T12:07:17.961Z <Rule:INFO> Cyrus Stream Vol- (rule-ml9ylxw3 in Living Room) starting rule state evaluation; because predicate-state-changed Predicate#rule-ml9ylxw3/trig [latest-26130]2026-05-19T12:07:17.962Z <Rule:INFO> Cyrus Stream Vol- (rule-ml9ylxw3 in Living Room) evaluated; rule state transition from RESET to 'SET' [latest-26130]2026-05-19T12:07:17.995Z <Engine:INFO> Enqueueing "Heating Control Mode is Home<RESET>" (rule-l680lif2:R) [latest-26130]2026-05-19T12:07:17.996Z <Engine:INFO> Enqueueing "House Mode is Home<RESET>" (rule-l5sdqazh:R) [latest-26130]2026-05-19T12:07:17.997Z <Engine:INFO> Enqueueing "Cyrus Stream Play / Pause<SET>" (rule-ml9y0xqo:S) [latest-26130]2026-05-19T12:07:17.997Z <Engine:INFO> Enqueueing "Cyrus Stream Vol+<SET>" (rule-ml9yjy9z:S) [latest-26130]2026-05-19T12:07:17.998Z <Engine:INFO> Enqueueing "Cyrus Stream Vol-<SET>" (rule-ml9ylxw3:S) [latest-26130]2026-05-19T12:07:18.000Z <Engine:NOTICE> Starting reaction Heating Control Mode is Home<RESET> (rule-l680lif2:R) [latest-26130]2026-05-19T12:07:18.000Z <Engine:INFO> Engine#1 perform power_switch.off on Entity#hass>input_boolean_heating_mode with { } by reaction Heating Control Mode is Home<RESET> (rule-l680lif2:R) step 1 [latest-26130]2026-05-19T12:07:18.000Z <HassController:INFO> HassController#hass perform power_switch.off on Entity#hass>input_boolean_heating_mode with { } [latest-26130]2026-05-19T12:07:18.001Z <HassController:INFO> HassController#hass service homeassistant.turn_off target data is { } (empty), assuming default entity target [latest-26130]2026-05-19T12:07:18.001Z <HassController:INFO> HassController#hass: sending payload for power_switch.off on Entity#hass>input_boolean_heating_mode action: { "type": "call_service", "service_data": { }, "domain": "homeassistant", "service": "turn_off", "target": { "entity_id": "input_boolean.heating_mode" } } [latest-26130]2026-05-19T12:07:18.017Z <Engine:NOTICE> Starting reaction House Mode is Home<RESET> (rule-l5sdqazh:R) [latest-26130]2026-05-19T12:07:18.018Z <Engine:INFO> House Mode is Home<RESET> all actions completed. [latest-26130]2026-05-19T12:07:18.074Z <Engine:NOTICE> Starting reaction Cyrus Stream Play / Pause<SET> (rule-ml9y0xqo:S) [latest-26130]2026-05-19T12:07:18.076Z <Engine:INFO> Engine#1 perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BfcG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDQv3BvcGfAN8A/cG9wY=\" }" } by reaction Cyrus Stream Play / Pause<SET> (rule-ml9y0xqo:S) step 1 [latest-26130]2026-05-19T12:07:18.076Z <HassController:INFO> HassController#hass perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BfcG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDQv3BvcGfAN8A/cG9wY=\" }" } [latest-26130]2026-05-19T12:07:18.077Z <HassController:INFO> HassController#hass: sending payload for x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send action: { "type": "call_service", "service_data": { "value": "BfcG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDRP3BvcGfAN8A/cG9wb///cG9wZ8A+ABAeABDQv3BvcGfAN8A/cG9wY=" }, "domain": "text", "service": "set_value", "target": { "entity_id": "text.living_room_remote_ir_code_to_send" } } [latest-26130]2026-05-19T12:07:18.090Z <Engine:NOTICE> Starting reaction Cyrus Stream Vol+<SET> (rule-ml9yjy9z:S) [latest-26130]2026-05-19T12:07:18.091Z <Engine:INFO> Engine#1 perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BXsDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBD/cG9wZ7A3sDewN7A3sDewM=\" }" } by reaction Cyrus Stream Vol+<SET> (rule-ml9yjy9z:S) step 1 [latest-26130]2026-05-19T12:07:18.092Z <HassController:INFO> HassController#hass perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"BXsDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBD/cG9wZ7A3sDewN7A3sDewM=\" }" } [latest-26130]2026-05-19T12:07:18.092Z <HassController:INFO> HassController#hass: sending payload for x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send action: { "type": "call_service", "service_data": { "value": "BXsDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBBfcG9wZ7A+ABAQf//3sDewP3BkABAXsD4AUBD/cG9wZ7A3sDewN7A3sDewM=" }, "domain": "text", "service": "set_value", "target": { "entity_id": "text.living_room_remote_ir_code_to_send" } } [latest-26130]2026-05-19T12:07:18.093Z <Engine:NOTICE> Starting reaction Cyrus Stream Vol-<SET> (rule-ml9ylxw3:S) [latest-26130]2026-05-19T12:07:18.093Z <Engine:INFO> Engine#1 perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"AXoD4AEBA/EGegPgBQEF8QbxBnoDgAFACQP//3oD4AEBQBHgBQEP8QbxBnoDegN6A3oD8QZ6Aw==\" }" } by reaction Cyrus Stream Vol-<SET> (rule-ml9ylxw3:S) step 1 [latest-26130]2026-05-19T12:07:18.094Z <HassController:INFO> HassController#hass perform x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send with { "service": "text.set_value", "data": "{ \"value\": \"AXoD4AEBA/EGegPgBQEF8QbxBnoDgAFACQP//3oD4AEBQBHgBQEP8QbxBnoDegN6A3oD8QZ6Aw==\" }" } [latest-26130]2026-05-19T12:07:18.111Z <HassController:INFO> HassController#hass: sending payload for x_hass.call_service on Entity#hass>text_living_room_remote_ir_code_to_send action: { "type": "call_service", "service_data": { "value": "AXoD4AEBA/EGegPgBQEF8QbxBnoDgAFACQP//3oD4AEBQBHgBQEP8QbxBnoDegN6A3oD8QZ6Aw==" }, "domain": "text", "service": "set_value", "target": { "entity_id": "text.living_room_remote_ir_code_to_send" } } [latest-26130]2026-05-19T12:07:18.113Z <Rule:INFO> Rule#rule-l5sdqazh reaction rule-l5sdqazh:R completed This is hardly the end of the world as HA restarting is rare and I simply hit refresh on the entity in MSR but is this some kind of race condition or something that needs addressing? Hoping I've given enough data to make it sensible C
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
32 Posts 2 Posters 7.6k Views 2 Watching
    After restarting MSR I now have four alerts:
    Three of them are referring to an Everspring EH403 outdoor flood light.
    In the rules trigger I am using this:
    x_vera_srv_micasaverde_com_SecuritySensor1.Tripped
    This is a bit of an odd ball device in Vera as it doesn't create a motion sensor child device natively.
    The parent device I have configured as a Binary Light, but it does have a "Tripped" variable for the PIR motion sensor portion of the device.
    These rules have been working OK however.
    As a test now, if I manually set the "Tripped" variable to 1 then my rules actions are run OK.
      @cw-kid The alert may be new, but the error being thrown in the log file would not be, so you probably didn't notice (i.e. the new alert is generated in the same breath as the log message that's been there for a while now).
      Just to clarify, are you testing the action device or is this a virtual device you are copying to?
      If it comes up again, go the rule editor right away and see if it exists there or not. That would be instructive. Then go look on the Vera side (hard refresh your browser first to make sure the UI Variables tab is showing you current data, it rarely does). If it's there, it would be good to know what value it has.
      And a device dump from a startup may also provide a clue:
      1. Under the config section for the vera controller in reactor.yaml, add a dump_entity: line indented two spaces relative to the config.
      2. After the dump_entity: line, add "device_699": true and make sure that's indented two space from dump_entity.
      It will look like this:
      controller:
        - id: vera
          # other config redacted for clarity
            # your source and other stuff redacted for clarity
            dump_entity:              <---- add this
              "device_699": true    <--- and this
      Make sure you only use spaces for indenting. The restart MSR. Wait a moment, and a file called vera-device_699.json will be created in your logs directory. Grab and post here.
        controller:
          - id: vera
        @toggledbits said in Alerts - (vera>device_699) does not have attribute ?attr?:
        Just to clarify, are you testing the actual device or is this a virtual device you are copying to?
        In MSR my rules trigger is looking at the "real" device the parent device and its "Tripped" variable, this is device ID 699, this is configured as a Binary Light device.
        The virtual motion sensor device I created and that I am copying the tripped status to from the parent, I am not using this device in MSR as a trigger. But I guess I could do instead.
        Virtual Motion Sensor:
        And this is an actual child device of the parent, which is a LUX sensor.
        You can download the device dump for the parent device 699 here.
          I had to restart MSR a few times to do that device dump, after the first restart the alerts went away and cleared. After the second restart they are back again.
          Not sure I know what you mean here?
          "If it comes up again, go the rule editor right away and see if it exists there or not."
            Device 699 information from the Entities area:
            power_switch.state=false
            x_vera_device.configured=true
            x_vera_device.device_number=699
            x_vera_device.device_type="urn:schemas-upnp-org:device:BinaryLight:1"
            x_vera_device.failed=null
            x_vera_device.mapped_by="*;device_type=urn:schemas-upnp-org:device:BinaryLight:1"
            x_vera_device.mapped_class="generic_switch"
            x_vera_svc_micasaverde_com_HaDevice1.ChildrenSameRoom="1"
            x_vera_svc_micasaverde_com_HaDevice1.Configured="1"
            x_vera_svc_micasaverde_com_HaDevice1.FirstConfigured="1616524758"
            x_vera_svc_micasaverde_com_HaDevice1.LastUpdate="1616525032"
            x_vera_svc_micasaverde_com_HaDevice1.ModeSetting="1:;2:;3:;4:"
            x_vera_svc_micasaverde_com_HaDevice1.PollRatings="5.00"
            x_vera_svc_micasaverde_com_SecuritySensor1.Armed="0"
            x_vera_svc_micasaverde_com_SecuritySensor1.ArmedTripped="0"
            x_vera_svc_micasaverde_com_SecuritySensor1.IgnoreTripTime="2"
            x_vera_svc_micasaverde_com_SecuritySensor1.LastTrip="1617297343"
            x_vera_svc_micasaverde_com_SecuritySensor1.Tripped="0"
            x_vera_svc_micasaverde_com_ZWaveDevice1.AgiInfo="X"
            x_vera_svc_micasaverde_com_ZWaveDevice1.AlarmType="0x7,0x8,"
            x_vera_svc_micasaverde_com_ZWaveDevice1.AlarmVersion="0,2"
            x_vera_svc_micasaverde_com_ZWaveDevice1.AssociationNum="0"
            x_vera_svc_micasaverde_com_ZWaveDevice1.Capabilities="211,156,1,4,7,1,L,R,B,RS,|37S,49S:5,85,89S,90S,94,108S,112S,113S:4,114S,115S,122S,133S,134S,152,159,"
            x_vera_svc_micasaverde_com_ZWaveDevice1.ConfiguredAssoc=""
            x_vera_svc_micasaverde_com_ZWaveDevice1.ConfiguredVariable="1-PIR Trigger Off period,2d,60,2-Lux sensor threshold,2d,30,3-Lux auto report,2d,1"
            x_vera_svc_micasaverde_com_ZWaveDevice1.FirmwareInfo="96,4609,29529"
            x_vera_svc_micasaverde_com_ZWaveDevice1.LastArr="1617238811,7"
            x_vera_svc_micasaverde_com_ZWaveDevice1.LastNnu="1617238807,7"
            x_vera_svc_micasaverde_com_ZWaveDevice1.LastReset="1616524754"
            x_vera_svc_micasaverde_com_ZWaveDevice1.LastRouteUpdate="1616525092"
            x_vera_svc_micasaverde_com_ZWaveDevice1.ManufacturerInfo="96,18,1"
            x_vera_svc_micasaverde_com_ZWaveDevice1.NodeInfo="55,5e,98,9f,"
            x_vera_svc_micasaverde_com_ZWaveDevice1.PlusInfo="1,5,0,12,7,12,7"
            x_vera_svc_micasaverde_com_ZWaveDevice1.PollOk="2"
            x_vera_svc_micasaverde_com_ZWaveDevice1.PollSettings="60"
            x_vera_svc_micasaverde_com_ZWaveDevice1.SecurityFailed="0"
            x_vera_svc_micasaverde_com_ZWaveDevice1.SensorMlType="3"
            x_vera_svc_micasaverde_com_ZWaveDevice1.SubscribedAlarms=",0x7,0x8,"
            x_vera_svc_micasaverde_com_ZWaveDevice1.VariablesGet="1,60,2,30,3,1,"
            x_vera_svc_micasaverde_com_ZWaveDevice1.VariablesSet="1-PIR Trigger Off period,2d,60,2-Lux sensor threshold,2d,30,3-Lux auto report,2d,1"
            x_vera_svc_micasaverde_com_ZWaveDevice1.VersionInfo="3,4,61,1,1"
            x_vera_svc_micasaverde_com_ZWaveNetwork1.ConsecutivePollFails="0"
            x_vera_svc_micasaverde_com_ZWaveNetwork1.LastPollSuccess="1616525034"
            x_vera_svc_upnp_org_SwitchPower1.Status="0"
            x_vera_svc_upnp_org_SwitchPower1.Target="0"
            zwave_device.capabilities="211,156,1,4,7,1,L,R,B,RS,|37S,49S:5,85,89S,90S,94,108S,112S,113S:4,114S,115S,122S,133S,134S,152,159,"
            zwave_device.failed=null
            zwave_device.manufacturer_info="96,18,1"
            zwave_device.node_id=133
            zwave_device.version_info="3,4,61,1,1"
            Capabilities: power_switch, toggle, x_vera_device, x_vera_svc_micasaverde_com_EnergyMetering1, x_vera_svc_micasaverde_com_HaDevice1, x_vera_svc_micasaverde_com_SecuritySensor1, x_vera_svc_micasaverde_com_ZWaveDevice1, x_vera_svc_micasaverde_com_ZWaveNetwork1, x_vera_svc_upnp_org_SwitchPower1, zwave_device
            Actions: power_switch.off, power_switch.on, toggle.toggle, x_vera_device.set_variable, x_vera_svc_micasaverde_com_EnergyMetering1.ResetKWH, x_vera_svc_micasaverde_com_HaDevice1.AllowPairing, x_vera_svc_micasaverde_com_HaDevice1.Poll, x_vera_svc_micasaverde_com_HaDevice1.Reconfigure, x_vera_svc_micasaverde_com_HaDevice1.Remove, x_vera_svc_micasaverde_com_HaDevice1.SetPollFrequency, x_vera_svc_micasaverde_com_HaDevice1.StressTest, x_vera_svc_micasaverde_com_HaDevice1.ToggleState, x_vera_svc_micasaverde_com_SecuritySensor1.SetArmed, x_vera_svc_micasaverde_com_ZWaveNetwork1.AddNodes, x_vera_svc_micasaverde_com_ZWaveNetwork1.BackupDongle, x_vera_svc_micasaverde_com_ZWaveNetwork1.DownloadNetwork, x_vera_svc_micasaverde_com_ZWaveNetwork1.HealNetwork, x_vera_svc_micasaverde_com_ZWaveNetwork1.PollAllNodes, x_vera_svc_micasaverde_com_ZWaveNetwork1.PutByte, x_vera_svc_micasaverde_com_ZWaveNetwork1.ReconfigureAllNodes, x_vera_svc_micasaverde_com_ZWaveNetwork1.RemoveNodes, x_vera_svc_micasaverde_com_ZWaveNetwork1.ResetNetwork, x_vera_svc_micasaverde_com_ZWaveNetwork1.SendData, x_vera_svc_micasaverde_com_ZWaveNetwork1.SetPolling, x_vera_svc_micasaverde_com_ZWaveNetwork1.SimulateIncomingData, x_vera_svc_micasaverde_com_ZWaveNetwork1.UpdateNeighbors, x_vera_svc_micasaverde_com_ZWaveNetwork1.UpdateNetwork, x_vera_svc_upnp_org_SwitchPower1.SetTarget, zwave_device.poll
              I just updated to the latest version of MSR 21091 and now I have some more new alerts regarding this particular device:
              An Entity Attribute condition in rule Deck Floodlight (Disarmed) - Tripped (Day) - Send Alert failed because the referenced entity Deck Floodlight (vera>device_699) does not have attribute x_vera_svc_micasaverde_com_SecuritySensor1.Armed
              Not sure what I can do about this Everspring flood light device and these alerts ?
              So I have edited my rules to use the virtual motion sensor device instead for their triggers instead of the parent device (Binary Light).
              Also this is a new but similar Alert regarding the Vera Day or Night plugin
              An Entity Attribute condition in rule Night - Day / Night Plugin failed because the referenced entity Day or Night (vera>device_43) does not have attribute ?attr?
              Status 1 or 0 appears to have gone missing for this rule:
              https://reactor.toggledbits.com/mantisbt/view.php?id=159
                All x_vera_state attributes were removed several builds ago. You'll find a x_vera_svc replacement for it. You could also just use the native date/time and sunrise/sunset conditions, rather than relying on yet another plugin.
                And by the way, the alerts from 21090 will persist until you dismiss them. You should not see any {attr} in messages from 21091, but alerts from 21090, if they were not dismissed, would still have them. With a few exceptions (controller up/down), alerts don't go away until you dismiss them.
                This isn't going to help the troubleshooting. Please go back to the prior configuration, and let's continue trying to figure this out.
                  I think I added it just as a test to see if I could use the status of the Day or Night plugin. I've changed it to use x_vera_svc...status I didn't see that earlier when I looked.
                  All my other rules are using the MSR inbuilt sunrise/sunset conditions.
                  I've cleared the other Alerts and restarted MSR, as yet none have come back.
                    Now that we know exactly what state variable it was complaining about, I took a look at the vera-device_699.json file you posted earlier, and sure enough the state variable Armed is missing (go check my work, please). So that seems like there's an odd device implementation thing going on in Luup.
                    I think we can work around it, though, and make it stable for your rules, by telling MSR that the device is special and instead of letting just have default Vera-specific capabilities, give it additional MSR-native capabilities. These will give you null when the variable is missing, but you can handle (or ignore) that more easily and it won't throw an error or alert. So you'll just test your device using the MSR-native attributes instead of the Vera service ones.
                    I'll make up the changes to the device configuration file and PM it to you, and you can try it. It should work.
                      On the Everspring Flood light parent device (Binary Light) I've just looked in Vera and there is no "Armed" variable.
                      There is this variable however which is strange.
                      "urn:micasaverde-com:serviceId:SecuritySensor1 / ArmedTripped"
                      I could add an "Armed" variable to the device using the "New Service" function in Vera, think I know how to do that.
                        New Alert just appeared
                        "An Entity Attribute condition in rule Vera Luup Reloads failed because the referenced entity vera>system could not be found"
                        The rule looks to be OK however:
                        EDIT: Actually I think this Alert might happen if I manually reload the LUUP engine on Vera.
                        This rule is meant to keep track of the number of LUUP engine reloads.
                          @cw-kid said in Alerts - (vera>device_699) does not have attribute ?attr?:
                          It would have to have been there at some point or you could not have chosen it for your rule. The list in the rule editor only shows what exists on the device/entity, not what it thinks would normally be there. So it was there at one point, and disappeared later, and this is not that unusual in the Vera world, sadly.
                          You can try re-creating it. It would be educational to see if it "sticks" after a reload, and after changing house mode, which aside from user action are the principal ways that variable gets played with.
                            "Tripped" I was using "Tripped" as the trigger in the rule not "Armed".
                            Looking in the device dump .json file I did the other day I can't see "Armed" in there either. So maybe this device never had it in the first place.
                                oh LOL that was a Constraint. So yes looks like I was using "Armed" also at some point.
                                So it has vanished as you suggested.
                                  Whew! OK... that's good (no, really). So, I have the changes for the device def. I'll send that via PM. You can drop it into your reactor/server/lib directory and restart Reactor. It should give you the standard arming service, with a value report of null (if it's still missing at that point -- hope so, don't change anything on the Vera yet!). Even if you don't use it, I'd like to confirm this approach would work if it comes up for other devices.
                                    OK I won't do anything on the Vera side or attempt to add back in the "Armed" variable using the New Service function.
                                      The other issue, found that, will be fixed in today's build (restart reporting system entity missing).
                                        OK I have uploaded the vera_devices.yaml file and restarted MSR.
                                        For the Everspring Flood light parent device this is what I am now seeing:
                                        SecuritySensor1.Armed is the last item in the list in the drop down box.
                                        So what does this mean ?
                                        It can't see the actual "Armed" state if that variable has now vanished off Vera.
                                        It seems to think its "false" not null.
                                          Your other snip shows the variable is there now, at the bottom of the list, therefore it has appeared and has a value, and null is not to be expected. This is exactly why I am taking this approach: the arming capability will make sure that its state attribute always exists with a value of true, false, or null, the first two following the value of SecuritySensor1/Armed when it is present on the device, or getting null if it is not. This is easier to handle in rules/conditions than getting an error thrown; you can treat null and false as equivalent, in all likelihood, which is exactly what a simple is TRUE condition operation would do.
                                          For the sake of clarity, the update did not make the Armed variable appear on the device. It can't do that. It only affects how it reads the device data that is available. So something created Armed on the Vera side in the interim, perhaps Vera itself.
                                            117.8k
