  4. Posting from log files
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
5 Posts 3 Posters 1.2k Views 3 Watching
    For years of participating in the other community, I've watched people post a single error message from a log file when asking for help. I'm now seeing the same behavior (I guess not surprisingly, given the genesis of this community) here. But it's got to stop.
    When you post just the error message, you leave out vital context that may give clues to more quickly troubleshoot whatever problem you are having. Very often, by the time someone responds to ask for more, the message is gone (e.g. rotating logs on Vera) or has become too difficult to locate.
    Please, when posting anything from a log file, you should be giving context with the message by including, let's say at least 10, messages before, and a few after. Particularly in the case of MSR, almost every exception that is logged is accompanied by a context-defining message immediately before, and in many cases, a follow-on additional data dump related to the error.
    Thanks for listening.
    P.S. My weekly (it seems) reminder: when things go wrong that obviously aren't just the UI doing something dumb, you must look at the logs.
      There's logs? ::rimshot::
        I'm going to check. Have I been guilty? Given my background this would be useful feedback!
          Not singling anybody out, and I'm sure I've unintentionally redacted important context as well myself, because sometimes you just don't know if what you're seeing is relevant or not, but the general message is: err on the safe side, posting too much is probably better than too little.
            My job here is nearly done...
            - YouTube
              163.8k
