  4. Setting up Pushover in MSR
Reactor Loading Screen Safari
I'm having an issue with MSR's UI being very unresponsive. It started happening a couple days ago and I didn't make any changes that would have caused this except adding some meross lan devices in HA. When I go into an entity action and use the search functionality, it usually will start filtering and then get to a place after a few letters are entered where it will take 30 seconds or more (sometimes minutes) for the UI to show what I am typing. During this time MSR ui is completely unresponsive. I've tried multiple browsers and multiple computers. HA and MSR are both deployed in docker. I have run HTOP on the host and when the problem happens there are no CPU/Memory spikes at all. From a functionality standpoint MSR is working perfectly. This seems to be an UI issue only. Do i need to ditch Docker and run MSR on a Proxmox VM? I have both stand alone Docker and Proxmox environments. I dont mind doing that I just want to be able to use the UI again... Installation method Home Assistant Container Core 2025.7.3 Frontend 20250702.3 nothing crazy in the logs except some openweather map stuff that doesn't make any sense as it is working fine in MSR Any help would be greatly appreciated Reactor latest-25328-b2ed1365 app 25328 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-25328]2025-11-30T20:01:53.843Z <app:null> Reactor build latest-25328-b2ed1365 starting on v24.11.1 /usr/local/bin/node [latest-25328]2025-11-30T20:01:53.844Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #161-Ubuntu SMP Tue Jul 22 14:25:40 UTC 2025; locale (undefined) [latest-25328]2025-11-30T20:01:53.844Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-25328]2025-11-30T20:01:53.844Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-25328]2025-11-30T20:01:53.865Z <app:null> Resolved timezone=America/New_York, environment TZ=America/New_York; offset minutes from UTC=-300 [latest-25328]2025-11-30T20:01:53.867Z <default:null> Module i18n v25141 [latest-25328]2025-11-30T20:01:53.867Z <app:null> Configured locale (undefined); selected locale(s) en-US.UTF-8 [latest-25328]2025-11-30T20:01:53.879Z <app:null> Loaded locale en-US for en-US [latest-25328]2025-11-30T20:01:53.879Z <app:null> Local date/time using configured timezone and locale formatting is "11/30/2025, 3:01:53 PM" [latest-25328]2025-11-30T20:01:53.889Z <Structure:null> Module Structure v25326 [latest-25328]2025-11-30T20:01:53.890Z <Capabilities:null> Module Capabilities v24312 [latest-25328]2025-11-30T20:01:53.904Z <Plugin:null> Module Plugin v25141 [latest-25328]2025-11-30T20:01:53.923Z <Timer:null> Module Timer v25279 [latest-25328]2025-11-30T20:01:53.924Z <TimerBroker:null> Module TimerBroker v25314 [latest-25328]2025-11-30T20:01:53.927Z <Entity:null> Module Entity v25251 [latest-25328]2025-11-30T20:01:53.929Z <Controller:null> Module Controller v25253 [latest-25328]2025-11-30T20:01:53.930Z <AlertManager:null> Module AlertManager v25318 [latest-25328]2025-11-30T20:01:53.937Z <default:null> Module Ruleset v25283 [latest-25328]2025-11-30T20:01:53.937Z <default:null> Module Rulesets v25141 [latest-25328]2025-11-30T20:01:53.942Z <GlobalExpression:null> Module GlobalExpression v25258 [latest-25328]2025-11-30T20:01:53.953Z <Predicate:null> Module Predicate v25328 [latest-25328]2025-11-30T20:01:53.956Z <Rule:null> Module Rule v25323 [latest-25328]2025-11-30T20:01:53.958Z <GlobalReaction:null> Module GlobalReaction v25292 [latest-25328]2025-11-30T20:01:53.959Z <Engine:null> Module Engine v25325 [latest-25328]2025-11-30T20:01:53.964Z <httpapi:null> Module httpapi v25328 [latest-25328]2025-11-30T20:01:53.972Z <wsapi:null> Module wsapi v25328 [latest-25328]2025-11-30T20:01:53.994Z <TaskQueue:null> Module TaskQueue 24138 [latest-25328]2025-11-30T20:01:53.994Z <VeraController:null> Module VeraController v25141 [latest-25328]2025-11-30T20:01:54.179Z <HassController:null> Module HassController v25325 [latest-25328]2025-11-30T20:02:13.797Z <OWMWeatherController:null> Module OWMWeatherController v25268 [latest-25328]2025-11-30T20:02:13.800Z <SystemController:null> Module SystemController v25323 [latest-25328]2025-11-30T20:02:13.807Z <MQTTController:null> Module MQTTController v22092 [latest-25328]2025-11-30T20:02:20.630Z <OWMWeatherController:CRIT> FetchError: request to https://api.openweathermap.org/data/2.5/weather?lat=xxxxxxxxxx&lon=-xxxxxxxxx&appid=xxxxxxxxxxxxxxxxxxxxxxxxxx&units=standard&_r=1xxxxxxxxxxxxxxfailed, reason: [-] FetchError: request to https://api.openweathermap.org/data/2.5/weather?lat=xxxxxxxxxxx&lon=-xxxxxxxxxxxxxxxxxx&appid=xxxxxxxxxxxxxxxxxxx&units=standard&_r=xxxxxxxxxxxxxxxfailed, reason: at ClientRequest.<anonymous> (/opt/reactor/node_modules/node-fetch/lib/index.js:1501:11) at ClientRequest.emit (node:events:508:28) at ClientRequest.emit (node:domain:489:12) at emitErrorEvent (node:_http_client:108:11) at TLSSocket.socketErrorListener (node:_http_client:575:5) at TLSSocket.emit (node:events:508:28) at TLSSocket.emit (node:domain:489:12) at emitErrorNT (node:internal/streams/destroy:170:8) at emitErrorCloseNT (node:internal/streams/destroy:129:3) at processTicksAndRejections (node:internal/process/task_queues:89:21
Date/time condition
Device log?
This post does not apply to users of Intel/AMD-based systems. If you are using a Reactor image tagged latest-amd64 or stable-amd64, then this post does not apply to you. It also does not apply to bare-metal installs; it's for users of docker images on ARM-based systems only (principally Raspberry Pi hosts, but could be others). After January 15, 2026, I will no longer produce the aarch64-tagged docker image for Reactor. The ARM images will be arm64 for 64-bit operating systems, and armv7l for 32-bit operating systems. For those of you running a container from the aarch64 image today, this will be a relatively simple change: you just need to switch the image used for your docker container to a differently-tagged image. If you are using docker-compose, then this is a relatively simple matter of changing the image line in your docker-compose.yaml file and then stopping (docker-compose down) and restarting (docker-compose up -d) your Reactor daemon. But there's a catch... not all of you can safely just switch from the aarch64 image to the arm64 image. And, you can't just trust the output of uname -m, for example, because this exposes the CPU architecture, but not the word size of the OS running on that CPU. For Raspberry Pi systems, the transition to 64-bit operating systems was long (starting in 2016) and not always obvious — although there was a first "official" 64-bit OS for RPis in 2020, it did not become a default recommendation in the Raspberry Pi Imager until 2021, and then that was only the default for Pi 3/4 systems with >4GB RAM; it was 2022 before it was universally recommended for all 64-bit CPUs regardless of RAM size. Depending on when you first imaged your RPi system and what default you may have been offered/chosen, you could today easily have a 64-bit CPU Raspberry Pi running a 32-bit version of the operating system. Upgrades along the way would not change this; changing it to fully 64-bit requires a full reimage of the system. To establish if your OS is 64- or 32-bit, log in to your Pi and run: sudo dpkg-architecture -q DEB_HOST_ARCH. If the response is arm64 or aarch64, then you are running a 64-bit OS and you should use the arm64-tagged image. If it's anything else, you are running a 32-bit OS, and you should use the armv7l-tagged image. pi@rpi4-1:~ $ sudo dpkg-architecture -q DEB_HOST_ARCH armhf pi@rpi4-1:~ $ uname -m aarch64 pi@rpi4-1:~ $ In the example above, the uname command reports that the CPU is 64-bit architecture (aarch64), which is true for the host on which I ran these commands, but the DEB_HOST_ARCH value is armhf, indicating a 32-bit operating system. This system has to use the armv7l-tagged image. Other systems will have their own ways of determining the word size of the running OS. Since the majority of Reactor users running ARM systems are on Raspberry Pis, I am able to supply the above instructions, but if you happen to have a different ARM system, you'll need to do some web searching to figure out how to expose that information. Or, you can just try the arm64 image, and if it doesn't start up, try the armv7l image. Remember to always back up your system before making any changes. For everyone, please make this change as soon as possible, and if you have any trouble finding a working image, please (1) go back to the current aarch64 image; and (2) let me know in this thread along with as much detail about your host system as you can offer (including the output of the dpkg-architecture command mentioned above).
@toggledbits Do you know if this is related to that PR or is it a change they made in 2025.11.1? [latest-25310]2025-11-11T13:16:24.319Z <HassController:INFO> HassController#hass perform x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_dag with { "time": "10:45" } [latest-25310]2025-11-11T13:16:24.320Z <HassController:INFO> HassController#hass: sending payload for x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_dag action: { "type": "call_service", "service_data": { "date": (null), "time": "10:45", "datetime": (null), "timestamp": (null) }, "domain": "input_datetime", "service": "set_datetime", "target": { "entity_id": "input_datetime.vvb_dag" } } [latest-25310]2025-11-11T13:16:24.321Z <HassController:ERR> HassController#hass request 1762866984320<2025-11-11 14:16:24> (call_service) failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.321Z <HassController:WARN> HassController#hass action x_hass_input_datetime.set_datetime({ "time": "10:45" }) on Entity#hass>input_datetime_vvb_dag failed! [latest-25310]2025-11-11T13:16:24.321Z <HassController:INFO> Service call payload: {"type":"call_service","service_data":{"date":null,"time":"10:45","datetime":null,"timestamp":null},"domain":"input_datetime","service":"set_datetime","target":{"entity_id":"input_datetime.vvb_dag"},"id":1762866984320} [latest-25310]2025-11-11T13:16:24.322Z <HassController:INFO> Service data: {"fields":{"date":{"example":"\"2019-04-20\"","selector":{"text":{"multiline":false,"multiple":false}}},"time":{"example":"\"05:04:20\"","selector":{"time":{}}},"datetime":{"example":"\"2019-04-20 05:04:20\"","selector":{"text":{"multiline":false,"multiple":false}}},"timestamp":{"selector":{"number":{"min":0,"max":9223372036854776000,"mode":"box","step":1}}}},"target":{"entity":[{"domain":["input_datetime"]}]}} [latest-25310]2025-11-11T13:16:24.322Z <Engine:ERR> Engine#1 reaction rule-mgb8pfhs:S step 0 perform x_hass_input_datetime.set_datetime failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.322Z <Engine:INFO> Engine#1 action args: { "time": "10:45" } [latest-25310]2025-11-11T13:16:24.322Z <Engine:INFO> Resuming reaction Sätt Schema VVB i Home Assistant<AKTIV> (rule-mgb8pfhs:S) from step 1 [latest-25310]2025-11-11T13:16:24.323Z <HassController:INFO> HassController#hass perform x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_natt with { "time": "03:00", "timestamp": 0 } [latest-25310]2025-11-11T13:16:24.323Z <HassController:INFO> HassController#hass: sending payload for x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_natt action: { "type": "call_service", "service_data": { "date": (null), "time": "03:00", "datetime": (null), "timestamp": 0 }, "domain": "input_datetime", "service": "set_datetime", "target": { "entity_id": "input_datetime.vvb_natt" } } [latest-25310]2025-11-11T13:16:24.324Z <HassController:ERR> HassController#hass request 1762866984323<2025-11-11 14:16:24> (call_service) failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.324Z <HassController:WARN> HassController#hass action x_hass_input_datetime.set_datetime({ "time": "03:00", "timestamp": 0 }) on Entity#hass>input_datetime_vvb_natt failed! [latest-25310]2025-11-11T13:16:24.324Z <HassController:INFO> Service call payload: {"type":"call_service","service_data":{"date":null,"time":"03:00","datetime":null,"timestamp":0},"domain":"input_datetime","service":"set_datetime","target":{"entity_id":"input_datetime.vvb_natt"},"id":1762866984323} [latest-25310]2025-11-11T13:16:24.324Z <HassController:INFO> Service data: {"fields":{"date":{"example":"\"2019-04-20\"","selector":{"text":{"multiline":false,"multiple":false}}},"time":{"example":"\"05:04:20\"","selector":{"time":{}}},"datetime":{"example":"\"2019-04-20 05:04:20\"","selector":{"text":{"multiline":false,"multiple":false}}},"timestamp":{"selector":{"number":{"min":0,"max":9223372036854776000,"mode":"box","step":1}}}},"target":{"entity":[{"domain":["input_datetime"]}]}} [latest-25310]2025-11-11T13:16:24.324Z <Engine:ERR> Engine#1 reaction rule-mgb8pfhs:S step 1 perform x_hass_input_datetime.set_datetime failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.324Z <Engine:INFO> Engine#1 action args: { "time": "03:00", "timestamp": 0 } [latest-25310]2025-11-11T13:16:24.325Z <Engine:INFO> Resuming reaction Sätt Schema VVB i Home Assistant<AKTIV> (rule-mgb8pfhs:S) from step 2 [latest-25310]2025-11-11T13:16:24.325Z <Engine:INFO> Sätt Schema VVB i Home Assistant<AKTIV> all actions completed.
P
8 Posts 3 Posters 705 Views 3 Watching
  • J Offline
    J Offline
    jsimmo
    I've been using Pushover in VeraAlerts, but now want to send my notifications from MSR.
    I see in the reactor config directory that the notification. yaml file includes Pushover, but is showing #TBD. Is this where I need to set up my Pushover user key etc. and if so what and how should the information be entered?
    Any help would be appreciated.
      Look in /dist-config/notifications.yaml for the latest guide on configuring for Pushover
      • J Offline
        J Offline
        jsimmo
        Thanks. Should have known to look there. Will give it a try.
        • J Offline
          J Offline
          jsimmo
          Followed the guide and Pushover is now set up and working fine.
            I've got my Pushover config up and running (and dare I say, working great) in MSR, except for one minor "thing"...
            ...all my notifications keep coming to the default device (my cellphone) rather than the device explicitly declared in the "Device:" field of my Rule. I've double-checked the spelling (HP_mini, which matches the label assigned to my Web browser on pushover.net), verified that the Pushover client is open in Chrome and receiving messages -- particularly those I send from the Pushover web UI "as MSR", and that all keys are current and in the right places, etc.
            Like I say, the messages DO get sent. Only to the wrong endpoint. Is anyone else with multiple endpoints defined getting misdirected notices from MSR??
            • Libra "Edge Case" Sun
            P.S. I don't reckon these associated lines from Reactor.log shed any light on the URL sent (and MSR cannot capture Pushover's response, so far as I know):
            2021-04-22T22:11:10.717Z <Rule:5:Rule.js:750> Rule#rule-kntf80qj dependency notification entity-changed Entity#vera>device_110 from Entity#vera>device_110
            2021-04-22T22:11:10.718Z <Rule:5:Rule.js:756> Rule#rule-kntf80qj requesting eval; entity-changed Entity#vera>device_110
            2021-04-22T22:11:10.719Z <Rule:5:Rule.js:750> Rule#rule-kntf80qj dependency notification entity-changed Entity#vera>device_110 from Entity#vera>device_110
            2021-04-22T22:11:10.720Z <Rule:5:Rule.js:756> Rule#rule-kntf80qj requesting eval; entity-changed Entity#vera>device_110
            2021-04-22T22:11:10.721Z <Rule:5:Rule.js:951> Rule#rule-kntf80qj (rule-kntf80qj) evaluate() acquiring mutex
            2021-04-22T22:11:10.722Z <Rule:5:Rule.js:951> Rule#rule-kntf80qj (rule-kntf80qj) evaluate() acquiring mutex
            2021-04-22T22:11:10.723Z <Rule:5:Rule.js:955> Rule#rule-kntf80qj._evaluate() mutex acquired, evaluating
            2021-04-22T22:11:10.724Z <Rule:5:Rule.js:959> Rule#rule-kntf80qj update rate is 3/min limit 60/min
            2021-04-22T22:11:10.725Z <Rule:5:Rule.js:881> Rule#rule-kntf80qj evaluateExpressions() with 0 expressions
            2021-04-22T22:11:10.725Z <Rule:5:Rule.js:971> Rule#rule-kntf80qj._evaluate() trigger state now false (was false)
            2021-04-22T22:11:10.726Z <Rule:5:Rule.js:973> Rule#rule-kntf80qj._evaluate() constraints state true
            2021-04-22T22:11:10.727Z <Rule:null> Rule#rule-kntf80qj rule state now false, changed no
            2021-04-22T22:11:10.728Z <Rule:5:Rule.js:955> Rule#rule-kntf80qj._evaluate() mutex acquired, evaluating
            2021-04-22T22:11:10.729Z <Rule:5:Rule.js:959> Rule#rule-kntf80qj update rate is 3/min limit 60/min
            2021-04-22T22:11:10.730Z <Rule:5:Rule.js:881> Rule#rule-kntf80qj evaluateExpressions() with 0 expressions
            2021-04-22T22:11:10.731Z <Rule:5:Rule.js:971> Rule#rule-kntf80qj._evaluate() trigger state now false (was false)
            2021-04-22T22:11:10.732Z <Rule:5:Rule.js:973> Rule#rule-kntf80qj._evaluate() constraints state true
            2021-04-22T22:11:10.733Z <Rule:null> Rule#rule-kntf80qj rule state now false, changed no
            2021-04-22T22:11:10.850Z <Rule:5:Rule.js:750> Rule#rule-kntf80qj dependency notification entity-changed Entity#vera>device_110 from Entity#vera>device_110
            2021-04-22T22:11:10.851Z <Rule:5:Rule.js:756> Rule#rule-kntf80qj requesting eval; entity-changed Entity#vera>device_110
            2021-04-22T22:11:10.852Z <Rule:5:Rule.js:750> Rule#rule-kntf80qj dependency notification entity-changed Entity#vera>device_110 from Entity#vera>device_110
            2021-04-22T22:11:10.853Z <Rule:5:Rule.js:756> Rule#rule-kntf80qj requesting eval; entity-changed Entity#vera>device_110
            2021-04-22T22:11:10.854Z <Rule:5:Rule.js:951> Rule#rule-kntf80qj (rule-kntf80qj) evaluate() acquiring mutex
            2021-04-22T22:11:10.855Z <Rule:5:Rule.js:951> Rule#rule-kntf80qj (rule-kntf80qj) evaluate() acquiring mutex
            2021-04-22T22:11:10.856Z <Rule:5:Rule.js:955> Rule#rule-kntf80qj._evaluate() mutex acquired, evaluating
            2021-04-22T22:11:10.856Z <Rule:5:Rule.js:959> Rule#rule-kntf80qj update rate is 4/min limit 60/min
            2021-04-22T22:11:10.857Z <Rule:5:Rule.js:881> Rule#rule-kntf80qj evaluateExpressions() with 0 expressions
            2021-04-22T22:11:10.859Z <Rule:5:Rule.js:1579> cond cond7hpkrvd evaluation state false->true
            2021-04-22T22:11:10.860Z <Rule:5:Rule.js:1579> cond trig evaluation state false->true
            2021-04-22T22:11:10.860Z <Rule:5:Rule.js:971> Rule#rule-kntf80qj._evaluate() trigger state now true (was false)
            2021-04-22T22:11:10.861Z <Rule:5:Rule.js:973> Rule#rule-kntf80qj._evaluate() constraints state true
            2021-04-22T22:11:10.862Z <Rule:INFO> Rule#rule-kntf80qj (rule-kntf80qj) triggered!
            2021-04-22T22:11:10.863Z <Rule:null> Rule#rule-kntf80qj rule state changed, was false now true
            2021-04-22T22:11:10.863Z <Rule:null> Rule#rule-kntf80qj rule state now true, changed true
            2021-04-22T22:11:10.865Z <Rule:5:Rule.js:955> Rule#rule-kntf80qj._evaluate() mutex acquired, evaluating
            2021-04-22T22:11:10.866Z <Rule:5:Rule.js:959> Rule#rule-kntf80qj update rate is 4/min limit 60/min
            2021-04-22T22:11:10.867Z <Rule:5:Rule.js:881> Rule#rule-kntf80qj evaluateExpressions() with 0 expressions
            2021-04-22T22:11:10.868Z <Rule:5:Rule.js:971> Rule#rule-kntf80qj._evaluate() trigger state now true (was false)
            2021-04-22T22:11:10.869Z <Rule:5:Rule.js:973> Rule#rule-kntf80qj._evaluate() constraints state true
            2021-04-22T22:11:10.869Z <Rule:INFO> Rule#rule-kntf80qj (rule-kntf80qj) triggered!
            2021-04-22T22:11:10.870Z <Rule:null> Rule#rule-kntf80qj rule state now true, changed no
            2021-04-22T22:11:10.872Z <Rule:5:Rule.js:999> Rule#rule-kntf80qj enqueueing reaction rule-kntf80qj:S
            2021-04-22T22:11:10.873Z <Engine:INFO> Enqueueing "rule-kntf80qj<SET>" (rule-kntf80qj:S)
            2021-04-22T22:11:10.874Z <Engine:5:Engine.js:948> Engine#1 queueReaction() starting Promise for rule-kntf80qj:S rule rule-kntf80qj task 368
            2021-04-22T22:11:10.875Z <Engine:5:Engine.js:1059> _process_reaction_queue() wake-up!
            2021-04-22T22:11:10.877Z <Engine:5:Engine.js:1020> _process_reaction_queue() running task 368 { "tid": 368, "id": "rule-kntf80qj:S", "rule": "rule-kntf80qj", "__reaction": [RuleReaction#rule-kntf80qj:S], "next_step": 0, "status": 0, "ts": 1619129470873, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise] }
            2021-04-22T22:11:10.878Z <Engine:NOTICE> Starting reaction rule-kntf80qj<SET> [RuleReaction#rule-kntf80qj:S]
            2021-04-22T22:11:10.879Z <Engine:5:NotifyPushover.js:208> NotifyPushover sending profile default notification request: Test
            2021-04-22T22:11:10.882Z <Engine:INFO> rule-kntf80qj<SET> all actions completed.
            2021-04-22T22:11:10.883Z <Engine:5:Engine.js:1024> _process_reaction_queue() task returned, new status -1; task 368
            2021-04-22T22:11:10.885Z <Engine:5:Engine.js:1059> _process_reaction_queue ending with 0 in queue; none delayed/ready; waiting
            2021-04-22T22:11:11.288Z <Engine:5:NotifyPushover.js:216> NotifyPushover successful endpoint exchange (message sent)
            2021-04-22T22:11:14.936Z <Rule:NOTICE> Rule#rule-kntf80qj configuration changed; reloading
            2021-04-22T22:11:14.937Z <Rule:5:Rule.js:715> Rule#rule-kntf80qj reloading with new data
            2021-04-22T22:11:14.937Z <Rule:NOTICE> Rule#rule-kntf80qj stopping rule
            2021-04-22T22:11:14.938Z <Rule:5:Rule.js:696> Rule#rule-kntf80qj acquiring semaphore
            2021-04-22T22:11:14.938Z <Rule:NOTICE> Rule#rule-kntf80qj configuration changed; reloading
            2021-04-22T22:11:14.939Z <Rule:5:Rule.js:715> Rule#rule-kntf80qj reloading with new data
            2021-04-22T22:11:14.940Z <Rule:NOTICE> Rule#rule-kntf80qj stopping rule
            2021-04-22T22:11:14.940Z <Rule:5:Rule.js:696> Rule#rule-kntf80qj acquiring semaphore
            2021-04-22T22:11:14.941Z <Rule:5:Rule.js:699> Rule#rule-kntf80qj semaphore acquired; releasing timer
            2021-04-22T22:11:14.942Z <Rule:5:Rule.js:699> Rule#rule-kntf80qj semaphore acquired; unsubscribing from condition dependencies
            2021-04-22T22:11:14.943Z <Rule:5:Rule.js:701> Rule#rule-kntf80qj saving states
            2021-04-22T22:11:14.944Z <Rule:5:Rule.js:705> Rule#rule-kntf80qj stopped
            2021-04-22T22:11:14.944Z <Rule:NOTICE> Rule Rule#rule-kntf80qj stopped
            2021-04-22T22:11:14.945Z <Rule:5:Rule.js:699> Rule#rule-kntf80qj semaphore acquired; releasing timer
            2021-04-22T22:11:14.945Z <Rule:5:Rule.js:699> Rule#rule-kntf80qj semaphore acquired; unsubscribing from condition dependencies
            2021-04-22T22:11:14.946Z <Rule:5:Rule.js:701> Rule#rule-kntf80qj saving states
            2021-04-22T22:11:14.948Z <Rule:5:Rule.js:705> Rule#rule-kntf80qj stopped
            2021-04-22T22:11:14.948Z <Rule:NOTICE> Rule Rule#rule-kntf80qj stopped
                Confirmed bug on the device in the Pushover notification. Open a PR!
                  Fixed! Pushover sends just fine now to any designated endpoint.
                  • Oh the joy of pairing
                  • HDMI oddness
                    582
                    sethlampman
                  • Date/time condition
