  4. MSR API functions and documentation
This post does not apply to users of Intel/AMD-based systems. If you are using a Reactor image tagged latest-amd64 or stable-amd64, then this post does not apply to you. It also does not apply to bare-metal installs; it's for users of docker images on ARM-based systems only (principally Raspberry Pi hosts, but could be others). After January 15, 2026, I will no longer produce the aarch64-tagged docker image for Reactor. The ARM images will be arm64 for 64-bit operating systems, and armv7l for 32-bit operating systems. For those of you running a container from the aarch64 image today, this will be a relatively simple change: you just need to switch the image used for your docker container to a differently-tagged image. If you are using docker-compose, then this is a relatively simple matter of changing the image line in your docker-compose.yaml file and then stopping (docker-compose down) and restarting (docker-compose up -d) your Reactor daemon. But there's a catch... not all of you can safely just switch from the aarch64 image to the arm64 image. And, you can't just trust the output of uname -m, for example, because this exposes the CPU architecture, but not the word size of the OS running on that CPU. For Raspberry Pi systems, the transition to 64-bit operating systems was long (starting in 2016) and not always obvious — although there was a first "official" 64-bit OS for RPis in 2020, it did not become a default recommendation in the Raspberry Pi Imager until 2021, and then that was only the default for Pi 3/4 systems with >4GB RAM; it was 2022 before it was universally recommended for all 64-bit CPUs regardless of RAM size. Depending on when you first imaged your RPi system and what default you may have been offered/chosen, you could today easily have a 64-bit CPU Raspberry Pi running a 32-bit version of the operating system. Upgrades along the way would not change this; changing it to fully 64-bit requires a full reimage of the system. To establish if your OS is 64- or 32-bit, log in to your Pi and run: sudo dpkg-architecture -q DEB_HOST_ARCH. If the response is arm64 or aarch64, then you are running a 64-bit OS and you should use the arm64-tagged image. If it's anything else, you are running a 32-bit OS, and you should use the armv7l-tagged image. pi@rpi4-1:~ $ sudo dpkg-architecture -q DEB_HOST_ARCH armhf pi@rpi4-1:~ $ uname -m aarch64 pi@rpi4-1:~ $ In the example above, the uname command reports that the CPU is 64-bit architecture (aarch64), which is true for the host on which I ran these commands, but the DEB_HOST_ARCH value is armhf, indicating a 32-bit operating system. This system has to use the armv7l-tagged image. Other systems will have their own ways of determining the word size of the running OS. Since the majority of Reactor users running ARM systems are on Raspberry Pis, I am able to supply the above instructions, but if you happen to have a different ARM system, you'll need to do some web searching to figure out how to expose that information. Or, you can just try the arm64 image, and if it doesn't start up, try the armv7l image. Remember to always back up your system before making any changes. For everyone, please make this change as soon as possible, and if you have any trouble finding a working image, please (1) go back to the current aarch64 image; and (2) let me know in this thread along with as much detail about your host system as you can offer (including the output of the dpkg-architecture command mentioned above).
@toggledbits Do you know if this is related to that PR or is it a change they made in 2025.11.1? [latest-25310]2025-11-11T13:16:24.319Z <HassController:INFO> HassController#hass perform x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_dag with { "time": "10:45" } [latest-25310]2025-11-11T13:16:24.320Z <HassController:INFO> HassController#hass: sending payload for x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_dag action: { "type": "call_service", "service_data": { "date": (null), "time": "10:45", "datetime": (null), "timestamp": (null) }, "domain": "input_datetime", "service": "set_datetime", "target": { "entity_id": "input_datetime.vvb_dag" } } [latest-25310]2025-11-11T13:16:24.321Z <HassController:ERR> HassController#hass request 1762866984320<2025-11-11 14:16:24> (call_service) failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.321Z <HassController:WARN> HassController#hass action x_hass_input_datetime.set_datetime({ "time": "10:45" }) on Entity#hass>input_datetime_vvb_dag failed! [latest-25310]2025-11-11T13:16:24.321Z <HassController:INFO> Service call payload: {"type":"call_service","service_data":{"date":null,"time":"10:45","datetime":null,"timestamp":null},"domain":"input_datetime","service":"set_datetime","target":{"entity_id":"input_datetime.vvb_dag"},"id":1762866984320} [latest-25310]2025-11-11T13:16:24.322Z <HassController:INFO> Service data: {"fields":{"date":{"example":"\"2019-04-20\"","selector":{"text":{"multiline":false,"multiple":false}}},"time":{"example":"\"05:04:20\"","selector":{"time":{}}},"datetime":{"example":"\"2019-04-20 05:04:20\"","selector":{"text":{"multiline":false,"multiple":false}}},"timestamp":{"selector":{"number":{"min":0,"max":9223372036854776000,"mode":"box","step":1}}}},"target":{"entity":[{"domain":["input_datetime"]}]}} [latest-25310]2025-11-11T13:16:24.322Z <Engine:ERR> Engine#1 reaction rule-mgb8pfhs:S step 0 perform x_hass_input_datetime.set_datetime failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.322Z <Engine:INFO> Engine#1 action args: { "time": "10:45" } [latest-25310]2025-11-11T13:16:24.322Z <Engine:INFO> Resuming reaction Sätt Schema VVB i Home Assistant<AKTIV> (rule-mgb8pfhs:S) from step 1 [latest-25310]2025-11-11T13:16:24.323Z <HassController:INFO> HassController#hass perform x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_natt with { "time": "03:00", "timestamp": 0 } [latest-25310]2025-11-11T13:16:24.323Z <HassController:INFO> HassController#hass: sending payload for x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_natt action: { "type": "call_service", "service_data": { "date": (null), "time": "03:00", "datetime": (null), "timestamp": 0 }, "domain": "input_datetime", "service": "set_datetime", "target": { "entity_id": "input_datetime.vvb_natt" } } [latest-25310]2025-11-11T13:16:24.324Z <HassController:ERR> HassController#hass request 1762866984323<2025-11-11 14:16:24> (call_service) failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.324Z <HassController:WARN> HassController#hass action x_hass_input_datetime.set_datetime({ "time": "03:00", "timestamp": 0 }) on Entity#hass>input_datetime_vvb_natt failed! [latest-25310]2025-11-11T13:16:24.324Z <HassController:INFO> Service call payload: {"type":"call_service","service_data":{"date":null,"time":"03:00","datetime":null,"timestamp":0},"domain":"input_datetime","service":"set_datetime","target":{"entity_id":"input_datetime.vvb_natt"},"id":1762866984323} [latest-25310]2025-11-11T13:16:24.324Z <HassController:INFO> Service data: {"fields":{"date":{"example":"\"2019-04-20\"","selector":{"text":{"multiline":false,"multiple":false}}},"time":{"example":"\"05:04:20\"","selector":{"time":{}}},"datetime":{"example":"\"2019-04-20 05:04:20\"","selector":{"text":{"multiline":false,"multiple":false}}},"timestamp":{"selector":{"number":{"min":0,"max":9223372036854776000,"mode":"box","step":1}}}},"target":{"entity":[{"domain":["input_datetime"]}]}} [latest-25310]2025-11-11T13:16:24.324Z <Engine:ERR> Engine#1 reaction rule-mgb8pfhs:S step 1 perform x_hass_input_datetime.set_datetime failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.324Z <Engine:INFO> Engine#1 action args: { "time": "03:00", "timestamp": 0 } [latest-25310]2025-11-11T13:16:24.325Z <Engine:INFO> Resuming reaction Sätt Schema VVB i Home Assistant<AKTIV> (rule-mgb8pfhs:S) from step 2 [latest-25310]2025-11-11T13:16:24.325Z <Engine:INFO> Sätt Schema VVB i Home Assistant<AKTIV> all actions completed.
P
HA 2025.9.4 Supported Yet?
Rule Set UI bug - RESOLVED
10 Posts 3 Posters 1.1k Views 3 Watching
    I am assuming in time MSR will have some API documentation.
    I am going to ask Bill the developer of the Home Remote dashboard app if he can add support for MSR.
    Specifically support for MSR global Reactions (Scenes), where hopefully they can be imported in to the Home Remote Designer application and then we can more easily create dashboard tiles that when pressed would run a particular MSR global Reaction etc.
    Currently in Home Remote it's possible but not so easy to create a tile that runs a http request when pressed and I have tested this and it does work and will run an MSR global Reaction.
    But I'd much prefer if in the Home Remote Designer application MSR could be added as a device type and then all its global Reactions
    imported as it does with Vera and other systems.
      I seem to recall Patrick declaring his intention to make this very thing happen down the road. In the meantime, there's just a ton of documentation needing doing for the existing functionality, UI and workflows, not to mention the vast and growing lexpjs lexicon from which Expressions derive. I wonder sometimes how the man finds the time to get it all done, and so swiftly! (Says he who probably filed twice as many PRs - not all of them valid - as any beta tester!)
      I vote +1 for your request, but I also secretly hold out hope that I'll use MSR's own built-in Dashboard as my primary instead of outsourcing that function to Home Remote (awesome as it is!).
        @librasun said in MSR API functions and documentation:
        That remains to be seen. It maybe a future and easier option, but as of now Home Remote is a very advanced dashboard app platform.
          @toggledbits Are there any currently-documented HTTP calls we can make against MSR?
          As in GET requests of this type or similar...
          http://<msr_platform_ip>:8111/action/set?<var_name>=<var_value>
          I'd love to be able to send data directly to MSR in certain circumstances, rather than filter them through an artificial construct like a Virtual Sensor on Vera.
            NOTE: API DOCUMENTATION HAS BEEN MOVED HERE. THE DOCUMENTATION BELOW IS NOW OUTDATED.
            Yes... another thing that needs documentation, but also somewhat in flux, and incomplete. The HTTP API is little-used, but I've tried to keep up some parity with the WebSocket API, which is what the UI uses exclusively.
            All HTTP APIs are accessible at the service IP and port beneath the /api/v1/ path (i.e. http://192.168.0.10:8111/api/v1/alive). All charset encoding is UTF-8. There is no security/authorization currently, but this is expected to change.
            alive - (GET) returns a fixed response UUID together with the IP address of the requestor; any error would indicate that MSR is not running/healthy.
            structure - (GET) returns a JSON response containing the Structure instance, all controllers, and all entities.
            capabilities - (GET) returns the currently-known information for a registered capability
            capability/:id - (GET) returns the information for the specified (id) capability
            controller/:id - (GET) returns the information for the specified (id) controller instance
            entity/:id - (GET) returns the current state of the specified entity (canonical id) instance
            entity/:id/attribute/:attr - (GET) returns the attribute value of the specified attribute (capability + attribute name in attr) for the specified entity (id)
            entity/:id/attribute/:attr/set - (GET, POST) sets the attribute value to that in the "value" query parameter (when POST is used, the request body type must be application/x-www-form-urlencoded)
            entity/:id/perform/:action - (GET, POST) performs the named action (capability + action name form) on the specified entity; query parameters are the action arguments, if any (when POST is used, the request body type must be application/x-www-form-urlencoded)
            reaction/:id - (GET) return data for the specified global reaction
            reaction/:id/run - (GET) run the specified global reaction
            reaction/:id/stop - (GET) stop the specified global reaction if it is running
            reaction/:id/enable - (GET) enable the specified global reaction
            reaction/:id/disable - (GET) enable the specified global reaction
            rulesets - (GET) return the system rule sets and their rules
            variables - (GET) return the global variable defined
            variable/:name - (GET) return definition and current value for the named global variable
            variable/:name/set - (PUT) set the global variable specified to a value (JSON data); the request body must be application/json type.
            cw-kidC 2 Replies Last reply
              @toggledbits said in MSR API functions and documentation:
              Just trying this, I was able to get a Z-Wave appliance plug to turn ON / OFF with a simple one line HTTP command !
              http://MSR-IP:8111/api/v1/entity/vera>device_50/perform/power_switch.on
              http://MSR-IP:8111/api/v1/entity/vera>device_50/perform/power_switch.off
              Don't really have a need for this though as Vera's own HTTP API (Luup Requests) is also pretty simple to use.
              However the new Ezlo HTTP API is not so easy to use.
              Maybe in the future if MSR does support and integrate with Ezlo hubs, we could use MSR's own HTTP API for controlling devices on the Ezlo hub, instead of actually using Ezlo's own HTTP API directly.
                Please can we have a GET for this one rather than PUT ?
                I would like a simple one line HTTP command to set the value of a Global Expression.
                This could then be used to manually trigger Rule Sets, that are using that Global Expression as a trigger and monitoring for a particular value being set in that expression etc.
                I could then create some MSR Rule Sets that act as "Scenes" and manually trigger / run them by sending in a HTTP request to MSR from the Home Remote dashboard app and a button.
                  MSR Health Check:
                  http://MSR-IP:8111/api/v1/alive
                  Any ideas how I can have a device in Vera that checks the health of MSR if its up or down etc ?
                  If I enter this URL in a browser I get a response like this:
                  fbd1234c-5fdc-11fg-9093-3798dc850621 Hello 192.168.0.101
                  That IP is my laptop's IP address.
                  If I stop MSR from running and run the URL again then obvious I then get no response back from MSR.
                  Or maybe I could just use the WOL with Ping plugin for Vera and ping the Raspberry Pi itself, think I already have the plugin installed.
                    The WOL with Ping plug-in should suffice for your purposes; the other logical alternative would be Rigpapa's awesome Site Sensor plug-in, which checks a specified URL on a schedule and parses the response into JSON. Because it can handle multiple instances/children peeking at different URLs, you could conceivably have Vera react to more than just "Is MSR awake?" events.
                      NOTE: API DOCUMENTATION HAS BEEN MOVED HERE. THE DOCUMENTATION IN THIS THREAD IS NOW OUTDATED.
                      • [Solved] Local expression in Rule does not evaluate as they used to do
                        73.8k
                        488
                      • Shelly Wall Display XL
                      • [Solved] alarm() in global expression throws error in log.
                        902
