  4. Let's talk about MSR-provided Virtual Devices... NOT!
DynamicGroupController updating members issue
Bare-metal latest-26193 I have this group: "OKforLarm": name: OK för Larm select: - include_controller: vera - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state It contains the entities I expect but behaves a bit odd. When I open vera>device_10097 the entity attribute door_sensor.state changes to true but it won't show up as member in the group, when I also open vera>device_10095 they both shows as members and when I close vera>device_10095 it disappear from the group but when I close vera>device_10097 it lingers in the group until I restart Reactor.
@toggledbits I pulled the image (well, Watchtower did) and within minutes the whole system went offline. The log looks like it ends with 26143. [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mkahsmgf/26qq82mw-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lqyfljfi/22f8on0t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lsb61rw8/24oenqi2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/rule-lrh58he0:S-1c00gfib-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1c00dylr-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1nam9w5u-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miuh2qqi/22ls4lql-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1vj8sdfc-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1qanz01x-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/24lq19p6-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mk0o8iox/23oy468y-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miscg2h3/rule-miscg2h3:S-22gmbq1c-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrfjke/238p0old-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-m7ccsso5/re-m7ccsso5-1r0myjxa-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/19nl9wq2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3xk9t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3vv5m-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/re-ln7j2nqp-22mx9lzd-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/22mx87c8-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-licneppy/1mzwe7ht-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ml3194ih/25jqt1j4-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrg7kf/227hshak-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13ua1p95-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13uagam7-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x4cbv-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x2fyl-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-lscjrws1/238p5c22-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lbwr0jvq/1xkczf03-cons [latest-26143]2026-05-31T15:23:44.547Z <Structure:NOTICE> Structure Structure#1 stopped [latest-26143]2026-05-31T15:23:44.547Z <app:NOTICE> Closing APIs... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: closing... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: disconnecting from "192.168.1.23#82" (1001 service closing) [latest-26143]2026-05-31T15:23:44.548Z <httpapi:NOTICE> HTTP API closing... [latest-26143]2026-05-31T15:23:44.549Z <wsapi:NOTICE> wsapi: server closed [latest-26143]2026-05-31T15:23:44.549Z <httpapi:INFO> HTTP server closed. [latest-26143]2026-05-31T15:23:44.549Z <app:NOTICE> Stopping timers... [latest-26143]2026-05-31T15:23:44.551Z <app:null> Shutdown complete, process ID 1 [latest-26143]2026-05-31T15:23:44.551Z <app:null> Closing logs... [latest-26143]2026-05-31T15:23:44.551Z <default:null> Closing log I can SSH to the VM. Alas, I do not have the previous image for 26143 as I'm a little too quick sometimes on housekeeping.
8 Posts 5 Posters 1.9k Views 5 Watching
    Guys,
    One of the things I really like about Home Assistant are these "input_boolean", "input_number", "input_text" and "input_select" components that serve as data containers. The "input_boolean" component, for example, functions in the same way as a virtual switch, holding a boolean state and allowing you to modify that state. The "input_select" holds a defined set of values, as opposed to "input_text" which just accepts anything. There's even an "input_datetime" object.
    I can see these being far more useful than trying to shoehorn more flexible behavior into virtualized models of existing devices, so this is the direction I'm thinking of going for MSR. One thing I really like is that the flexibility of them is sufficient to eliminate the need for expressionless variables in many, if not most, cases.
    Thoughts?
    • F Offline
      Absolutely - that make sense! Many of us still use a Vera as a z-wave radio, and we can always create a virtual device in Vera if we want to keep it the old and simple Vera way. Lay the effort elsewhere! 🙂
      /Fanan
        To be clear, I'm not saying "use Home Assistant", I'm saying that I'm going to adopt Hass' model to MSR's upcoming virtual entities.
            Hammer? What? I'm confused by all of this, and it mostly seems the opposite of what I'm saying. I want things to be done as close as possible to the point of use, generally speaking, so it makes sense to me that data stored for use in (i.e. as terms of) rules and logic be managed in the same place as the rules and logic. I've never thought otherwise. I just think overloading existing device types is far too constraining. Hass has a simple, successful model, in my view.
            @librasun said in Let's talk about MSR-provided Virtual Devices... NOT!:
            Seems clear (to me, anyway) that your intent with early MSR has been to leverage Expressions primarily as set-once-read-many, with the heavy lifting being done with ${{ substitutions }} and [ Set Variable ]. I think this explains why it remains comparatively challenging in MSR to, say, update arrays on the fly or modify JSON objects at all after initial declaration, without jumping through lots of indirect hoops.
            First sentence, no, that's never been my intent. The rest, sounds like a conversation we haven't had (and should be separate from this thread), both about what makes it difficult and why you want to do it in the first place. Remember, MSR is not an expression language with support for rules and reactions. I wouldn't need to build that, because Lua, Python and groovy already exist.
            • K Offline
              K Offline
              kfxo
              @toggledbits So what would be the difference between MSR provided Virtual Devices and expressionless variables? Do you envision interacting with the virtual devices in MSR? Right now I use expressionless variables whenever I need to keep track of some value and I have no intention of needing to modify the value outside of logic. I use virtual devices both in openluup and HA when I intend to physically interact to change the value (or I have no other way of getting the value into MSR..cough cough HA event data generated by integrations that are not reflected in entities). I guess I am not seeing why MSR would need Virtual Devices to act as data containers when MSR already has data containers with expressionless variables.
                Well, I think it has a meaning when we add dashboards to the mix. I’ll vote for it, plus combo device (like HA) to express complex devices. I’m using this approach right now in my own dashboard system.
                • K Offline
                  K Offline
                  kfxo
                  I could definitely see it being useful for dashboards and also if an integrated controller does not provide the ability to create a virtual device.
                  • DynamicGroupController updating members issue
                    128.4k
