  4. Will this rule work for lighting?
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
8 Posts 3 Posters 795 Views 3 Watching
    I had an existing rule that turns on my Kitchen ceiling lights to 100% when motion is detected.
    I want to make a change so that when Vera is in Night Mode the lights will instead turn on to 25% brightness.
    I have added a Constraints Group in to the Set Reaction and set it to OR :
    Is this likely to work or not ?
    Or do I need two Constraints Groups within the Set Reaction ?
    I can test it later on when its time to put Vera in to Night mode.
      Technically, what you have there should work just fine!!
      In this situation, I would have recommended two different Constraint Groups (leaving each one set to [AND], though it doesn't matter since you only have one condition per Group) within the Set Reaction. One for full brightness, the other for setting the Dim Level. Sure beats having to create two groups, though!
        @cw-kid It will work, but not the way you think.
        The "OR" only applies to the conditions within the group. It does not look outside the group at any states.
        That means that what you have here (assuming there is not a global rule constraint, not shown) is that the light will be set to 100% every time the reaction runs, and at night a few milliseconds later it will be reduced to 25%. That may or may not look right or work consistently.
        You need two groups, one for day, one for night, the former setting 100%, the latter setting 25%.
          @toggledbits said in Will this rule work for lighting?:
          OK thanks I thought that might be the case.
          It's Vera House mode Home and Night not daytime and night time I'm looking to base things off.
          I'll create another Constraint group within the Set Reaction, for when Vera is in Home mode and in that mode I want the light to turn on to 100%.
          And when Vera is in Night mode aka I've stumbled down stairs in the middle of the night, then I want the light to turn on to 25% so I'm not made blind.
            Like this? I assume I make both Groups AND
              Since the constraint group(s) only have one condition, AND and OR give the same result, but it's always my preference to use AND on singles. Looks good.
                OK great thanks I'll test it later tonight.
                  WARNING: Avoid using the "Clone" button (for now) when constructing multiple Group Constraints. Minor glitch found with resolution TBA. Stick with creating each Group Constraint individually from scratch in your Set and Reset reactions.
                    911
                    2.0k
                    3.7k
                    3.3k
                    937
