Is Telegram working?
Did you include it in the config?
Edit: clarifying, by "it" I mean the number (bot ID) before the colon (and the colon). The
bot_tokenvalue in the config should be on the formnnnnnn:mixedlongstring. The object literally copies the entirebot_tokenstring onto the end of the URL; there's not filtering or editing of any kind, so your log post suggests it's not there.Did you enclose it in quotes?
@toggledbits said in Is Telegram working?:
Yes and No.
Seems I needed to restart Reactor engine.
I now see the correct full bot ID string in the log file OK.
Also I had to remove "bot" from the yaml file as MSR puts than in for you.
However its still not working.
I am still getting 404.
This is what I see now in the log:
2021-06-18T17:25:12.205Z <Engine:INFO> Enqueueing "Test Telegram" (re-kq29nxzw) 2021-06-18T17:25:12.210Z <Engine:5:Engine.js:953> Engine#1 enqueued reaction re-kq29nxzw as 6 2021-06-18T17:25:12.212Z <Engine:5:Engine.js:1108> _process_reaction_queue() wake-up! 2021-06-18T17:25:12.215Z <Engine:5:Engine.js:1069> _process_reaction_queue() running task 6 { "tid": 6, "id": "re-kq29nxzw", "rule": --undef--, "__reaction": GlobalReaction#re-kq29nxzw, "next_step": 0, "status": 0, "ts": 1624037112207, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise] } 2021-06-18T17:25:12.216Z <Engine:NOTICE> Starting reaction Test Telegram (re-kq29nxzw) 2021-06-18T17:25:12.217Z <Engine:5:Engine.js:1216> Engine#1 reaction re-kq29nxzw step 0 notify Telegram with { "message": "This is a TEST", "profile": "default" } 2021-06-18T17:25:12.218Z <Engine:5:NotifyTelegram.js:159> NotifyTelegram sending profile default notification request: This is a TEST 2021-06-18T17:25:12.222Z <Engine:INFO> Test Telegram all actions completed. 2021-06-18T17:25:12.223Z <Engine:5:Engine.js:1073> _process_reaction_queue() task returned, new status -1; task 6 2021-06-18T17:25:12.226Z <Engine:5:Engine.js:1108> _process_reaction_queue() ending with 1 in queue; waiting for 1 (next delayed task) 2021-06-18T17:25:12.349Z <Engine:ERR> NotifyTelegram failure response from endpoint: 400 Bad Request 2021-06-18T17:25:12.351Z <Engine:ERR> NotifyTelegram fres=[object Response] 2021-06-18T17:25:12.352Z <Engine:INFO> NotifyTelegram request URL: https://api.telegram.org/bot2188872596:BBF5RD5P-kDty8ZTB88e--GB5T5ENpId4xN/sendMessage 2021-06-18T17:25:12.352Z <Engine:INFO> NotifyTelegram request body: {"text":"This is a TEST","chat_id":"314603256"} 2021-06-18T17:25:12.353Z <Engine:ERR> NotifyTelegram request to https://api.telegram.org/bot2188872596:BBF5RD5P-kDty8ZTB88e--GB5T5ENpId4xN/sendMessage failed: Error: NotifyTelegram request failed 2021-06-18T17:25:12.354Z <Engine:ERR> Engine#1 reaction re-kq29nxzw step 0 notification (Telegram) failed: Error: NotifyTelegram request failed -
You're now getting a 400, not a 404. That likely means that the chat ID is invalid. Is the bot a member of that chat?
Oh yes sorry 400 not 404.
Chat ID is correct and yes I think it must be a member. Because I am using the same bot ID and the same chat ID in a raw HTTPS command and the notifications work and go to my "Vera Group" aka my chat ID.
This is the type of HTTPS command I've been using previously:
https://api.telegram.org/bot2188872596:BBF5RD5P-kDty8ZTB88e--GB5T5ENpId4xN/sendMessage?chat_id=-314603256&text=This is a test -
The chat ID in your HTTPS fetch has a minus sign at the front, while the chat ID in MSR does not. Check you configuration again.
Well spotted I didn't even notice that.
I added a minus sign also in the notification.yaml file and now its working from MSR.
@toggledbits minus is allowed, and is a message for a group. When it does not have a minus sign, it is for a single user.
Yes and No.
2021-06-18T17:25:12.205Z <Engine:INFO> Enqueueing "Test Telegram" (re-kq29nxzw) 2021-06-18T17:25:12.210Z <Engine:5:Engine.js:953> Engine#1 enqueued reaction re-kq29nxzw as 6 2021-06-18T17:25:12.212Z <Engine:5:Engine.js:1108> _process_reaction_queue() wake-up! 2021-06-18T17:25:12.215Z <Engine:5:Engine.js:1069> _process_reaction_queue() running task 6 { "tid": 6, "id": "re-kq29nxzw", "rule": --undef--, "__reaction": GlobalReaction#re-kq29nxzw, "next_step": 0, "status": 0, "ts": 1624037112207, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise] } 2021-06-18T17:25:12.216Z <Engine:NOTICE> Starting reaction Test Telegram (re-kq29nxzw) 2021-06-18T17:25:12.217Z <Engine:5:Engine.js:1216> Engine#1 reaction re-kq29nxzw step 0 notify Telegram with { "message": "This is a TEST", "profile": "default" } 2021-06-18T17:25:12.218Z <Engine:5:NotifyTelegram.js:159> NotifyTelegram sending profile default notification request: This is a TEST 2021-06-18T17:25:12.222Z <Engine:INFO> Test Telegram all actions completed. 2021-06-18T17:25:12.223Z <Engine:5:Engine.js:1073> _process_reaction_queue() task returned, new status -1; task 6 2021-06-18T17:25:12.226Z <Engine:5:Engine.js:1108> _process_reaction_queue() ending with 1 in queue; waiting for 1 (next delayed task) 2021-06-18T17:25:12.349Z <Engine:ERR> NotifyTelegram failure response from endpoint: 400 Bad Request 2021-06-18T17:25:12.351Z <Engine:ERR> NotifyTelegram fres=[object Response] 2021-06-18T17:25:12.352Z <Engine:INFO> NotifyTelegram request URL: https://api.telegram.org/bot2188872596:BBF5RD5P-kDty8ZTB88e--GB5T5ENpId4xN/sendMessage 2021-06-18T17:25:12.352Z <Engine:INFO> NotifyTelegram request body: {"text":"This is a TEST","chat_id":"314603256"} 2021-06-18T17:25:12.353Z <Engine:ERR> NotifyTelegram request to https://api.telegram.org/bot2188872596:BBF5RD5P-kDty8ZTB88e--GB5T5ENpId4xN/sendMessage failed: Error: NotifyTelegram request failed 2021-06-18T17:25:12.354Z <Engine:ERR> Engine#1 reaction re-kq29nxzw step 0 notification (Telegram) failed: Error: NotifyTelegram request failed@cw-kid this comment about having the letters bot in front is already added by MSR, we have to be careful, because when we copy the ID when it is generated in Telegram it comes with these letters bot in front that has to be removed when configuring. I had the same problem until I identified this in the log appearing twice botbot.
Where are you seeing that? I can't screenshot the Android app because it won't let me (security policy--smart!), but the response to
/newbotfrom BotFather does not contain the string "bot" in front of the key. Are you seeing it elsewhere? Maybe iOS? -
@wmarcolin said in Is Telegram working?:
Yes indeed, that is what I was seeing in the log file also.
Well first I don't remember how to get the ID, I don't remember when the number was generated
lolI think what may have created confusion, was that when using a direct call, as the example below is necessary to put the bot, but when configuring the MSR not, because the application already adds the information.
https://api.telegram.org/bot177_____83:AAER___________________________GTGk/getUpdates
I think the situation is closed, we just have to stay alert to some other user who mentions that Telegram is not working pass this orientation.
The key/token in the response from BotFather when creating the bot will not have 'bot' prepended to it, so that makes sense.
Yesterday I converted all my rules to use the now inbuilt notify for Telegram, rather than sending Http requests out as I was.
No further problems and everything seems to be working well.
Thanks for adding Telegram support, I had previously requested it, but at that time it sounded like it would not be added.
Hi!
I've been trying to get Telegram to work, but I think it's something I'm doing wrong in the notification.yaml. It's working from within Home Assistent, but not with MSR. This is from my Notification.yaml:Telegram: profiles: default: # description - A friendly description of this profile (for menus) description: Telegram # # api_url - Access URL for Telegram API. Default is https://api.telegram.org api_url: https://api.telegram.org # # bot_token - (required) Bot Token, from Telegram. See: https://core.telegram.org/bots bot_token: "2091____________(blanked for security reason)____________wH2Z0" # # default_chat_id - (required) Default chat ID to use if not specified in message. See # this link for how to get chat ID: # https://stackoverflow.com/questions/32423837/telegram-bot-how-to-get-a-group-chat-id default_chat_id: "77________07" # # default_disable_notification - Default notification flag, may be either "true" # or "false". The system default is "false" # (false == notification enabled/not disabled). default_disable_notification: "false" # # default_parse_mode - Default message format/parse mode. The system default is # blank, for plain text. Other options: MarkdownV2, HTML # See: https://core.telegram.org/bots/api#formatting-options #default_parse_mode: ""I have tried both with and without qoutes " " around chat_id and bot_token. Am I missing something? I'm on MSR ver 21337. Thanks in advance.
/Fanan -
Telegram is working fine for me. Any chance you've looked at your logs?
@toggledbits This is my log (I changed my personal info):
[latest-21342]2021-12-09T18:38:18.936Z <Engine:NOTICE> Resuming reaction Tända hos Khalisi<SET> (rule-kuvhc9mc:S) from step 1 [latest-21342]2021-12-09T18:38:18.939Z <Engine:INFO> Tända hos Khalisi<SET> all actions completed. [latest-21342]2021-12-09T18:38:19.248Z <NotifyTelegram:ERR> NotifyTelegram failure response from endpoint: 400 Bad Request [latest-21342]2021-12-09T18:38:19.248Z <NotifyTelegram:INFO> NotifyTelegram request URL: https://api.telegram.org/bot2091333304:AXXpXQDQJ1L19xQoI1Gyc9i5XEH0uIwH2Z0/sendMessage [latest-21342]2021-12-09T18:38:19.249Z <NotifyTelegram:INFO> NotifyTelegram request body: {"text":"Hello!!","chat_id":"7777777","disable_notification":"false"} [latest-21342]2021-12-09T18:38:19.249Z <NotifyTelegram:ERR> NotifyTelegram request to https://api.telegram.org/bot2091550404:AXXXXQDQJ1L19xQoI1Gyc9i5XEH0uIwH2Z0/sendMessage failed: Error: NotifyTelegram request failed [latest-21342]2021-12-09T18:38:19.249Z <Engine:ERR> Engine#1 reaction rule-kuvhc9mc:S step 1 notification (Telegram) failed: Error: NotifyTelegram request failed [latest-21342]2021-12-09T18:38:19.250Z <NotifyTelegram:ERR> NotifyTelegram failure response text: {"ok":false,"error_code":400,"description":"Bad Request: chat not found"} -
OK, you've found the issue.
No worries. Just trying to teach fishing rather than just handing the fish over...
The last line of your log snippet:
[latest-21342]2021-12-09T18:38:19.250Z <NotifyTelegram:ERR> NotifyTelegram failure response text: {"ok":false,"error_code":400,"description":"Bad Request: chat not found"}It's not happy with the chat ID, it appears. That's a pretty specific message. Where did you get it? Have you verified it?
Getting the chat ID can be a bit of work. Sometimes it's in the message you get when you set up in Bot Father, sometimes not. The config file template's comments give you some instructions and a link for how to get the chat ID.
# # default_chat_id - (required) Default chat ID to use if not specified in message. See # this link for how to get chat ID: # https://stackoverflow.com/questions/32423837/telegram-bot-how-to-get-a-group-chat-id default_chat_id: "123456789"At the very least, I'd go through this process and confirm. Watch the case on the ending of the URL that you're asked to fetch. If it's incorrect, the API will give you a bogus empty-ish response rather than an error, which can be frustrating to figure out.
@toggledbits Thank you for your patience!
After two hours of digging, google searching and some trial and errors, I finally found why it didn't work...
It's easier if the reactor is activated...
It do not work even in the editing menu, as long as it's not activated. This is strange, since I can activate a specific entity/step to try it out. But that was not the case with the notify function. All of my tries have been in the editing menu with the reaction not activated. Now it's working perfectly, and so are my other notify services. Have a great weekend!
