  4. Restart Reactor option not working on QNAP docker
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
6 Posts 3 Posters 1.3k Views 3 Watching
  • D Offline
    D Offline
    d868
    Hi @toggledbits here is the thread to discuss the restart issue with MSR as discussed.
    When I use the Tools > Restart Reactor button in the UI it shuts down reactor successfully but doesn't restart. It doesn't bother me as I can easily restart it manually via the docker UI, but thought it would be still worth posting it if anyone else has the same issue, or if you want to look into it.
    I'm running MSR using the latest-generic-amd64 docker image on a QNAP NAS via the standard docker implementation (container station).
      That tool can only stop MSR. It relies on the OS (or in this case, docker) to restart the container when it sees it has stopped.
      Confirm that "Auto Start" is turned on for your container in its settings. This may not be enough for QNAP though. I did some Googling, and there is a lot of discussion going back some time that the UI for Container Station has no real equivalent for docker's "--restart" option to set the restart policy for the container. Users suggest starting up the container from the command line (once you've done it once, it sticks in docker's configuration).
      See:
      • https://forum.qnap.com/viewtopic.php?t=143609
      • https://www.reddit.com/r/qnap/comments/agsnc6/container_station_autorestart_after_unexpected/
      • https://docs.docker.com/config/containers/start-containers-automatically/
      Ugh. This makes QNAP/Container Station much more difficult (higher learning curve, more exotic commands required to get started). That puts it (way) down my list for recommended platforms.
      • D Offline
        D Offline
        d868
        Ah, now that I know the button is just shutting down MSR and not trying to actually restart it that explains what's happening. I haven't had much luck with the auto start even though it's turned on so I just do a manual restart when needed. Thanks for suggesting some links, but don't worry about looking into it any further. I'm not worried about it, but it's good to have it documented here if anyone else comes across it in the future.
        Might be handy to add something to the documentation about what the button actually does when you get to updating the Tools section.
          The thing is, it works correctly on Synology, or under other docker installations, because the restart policy can be defined. This is a QNAP limitation, so the fact that it doesn't work on QNAP (specifically Container Station UI) is all that's to be documented, and if the links are to be believed, using the command line to create and start the container rather than Container Station, it then works fine. It would be good to have confirmation of that.
          • D Offline
            D Offline
            d868
            If I get some time I'll test it for you and let you know via this thread, but I've made a point with this NAS of not doing anything in the command line because I want to keep it as out of the box and standard as possible. I know it's not hard, but my last NAS was basically all command line and a lot of tweaking which made for some interesting times during some upgrades so this time I'm keeping it all standard and working around any limitations.
            For the documentation I wasn't suggesting you document specific issues with platforms, just what the button actually does which would help anyone in the future if they were wondering what was happening. It maybe just me, but I wouldn't have bothered to ask about this if I'd realised that the restart was an OS thing, not part of the button function. Eg: The restart reactor button shuts down reactor (or the container) and the OS is then responsible for automatically restarting MSR using whatever specific method is supported.
            Anyway, coming from Reactor on Vera I'm very happy with MSR so far and this was just a suggestion. 😊
            • Tom_DT Offline
              Tom_DT Offline
              Tom_D
              Nice to know that "Restart Reactor" under tools shuts Reactor down and then relies on the host to restart it. Nice to know that QNAP is not behaving. I restart on the QNAP GUI after I make configuration changes. I am using QNAP because it is what I have so this would be good info for someone looking for a NAS to run Reactor on.
              latest-25082-3c348de6
              • Next Release?
