  4. HASS version not supported?
4 Posts 3 Posters 973 Views 3 Watching
  • Tom_DT Offline
    Tom_DT Offline
    Tom_D
    I am running MSR 1.0.0-21200-16a604f and am seeing the message:
    HomeAssistant on "hass" may be an unsupported version. The reported version (2021.7.3) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available.
    latest-25082-3c348de6
    • MatohlM Offline
      MatohlM Offline
      Matohl
        HomeAssistant often publishes breaking changes (necessary to move the ball forward, sometimes), and while they are pretty good about publishing what is breaking on the user-facing side of things, they've been less thorough on the API side. So Reactor pays attention to "known good" versions of HomeAssistant when it connects. If everything seems fine, you are probably OK, but if you upgrade Hass, get this warning from Reactor, and simultaneously have something dire happen like no devices listed or an entire class of devices is missing or malfunctioning, you should downgrade to the version Reactor suggests and then send me a note with the version number of Hass you were trying to use.
        • Tom_DT Offline
          Tom_DT Offline
          Tom_D
          OK. Thanks.
            147.5k
