  4. MSR Logic vs Reactor question
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
7 Posts 3 Posters 1.0k Views 3 Watching
    RogerO
    Hello,
    Trying to convert my Reactor scripts to MSR. Couldn't get the import to work so gave up on that. Anyway, curious on how to work with the following example.
    Have a motion sensor on my back porch. Very simple logic:
    7fbcd69e-9f85-4b7f-8138-1267d4e4ba1a-image.png The Reactor activities are as follows:
    34e715fd-c2f1-4b92-99ea-e2838fc5d3dc-image.png.
    In MSR, how do you tie activities to sub conditions like I have with the last action in activities.
    In this case I was to trigger BlueIris to trigger regardless of the time of day, but only want the light to come on at night. Do I need multiple Rule Sets?
    Thanks,
    Roger
      I believe the answer you seek lies within the new-ish "Group" feature in Reactions. (There is no section covering this yet in Docs, at least when I looked under "Creating Automations" > "Reactions").
      I'm sorry not to have the time to type out a complete example for you, but I know the Forum contains several use cases involving "Group Constraints".
        RogerO
        I did not find anything in the forum under those keywords. Do you have a link or 2?
          I had looked for links earlier and found none that were illustrative of setting up Group Constraints, but generally speaking, I can suggest:
          In your Rule, within your Set Reaction, add a "Group Constraint" (which will look and behave like it's own "section"). Add one or more Conditions, such as your "Is Night" timeframe, and then add the thing(s) you want that group to do when true.
          Do all this again, adding a Group Constraint to the Set Reaction which contains your "Porch Sensor Tripped" logic, along with actions you want it to take when that logic is true.
          In this way, you wind up with a Rule that runs under the appropriate AND logic it always did, but internally forks to run one (or both) subsets of functions depending on their truth.
          Of course, since my basic example happens to repeat your SET conditions within the Group Constraints sections, they will kinda automatically be TRUE every time the Rule fires, so both constraints' actions will always fire. Up to you to decide which logic you really want internally.
            Using Group Constraints is one way. The other way is to make Porch Sensor Tripped its own rule with its own reaction (the HTTP Request), and then create an additional rule Back Porch Motion that uses a "Rule State" condition to test Porch Sensor Tripped and the entity condition to check the back porch switch.
              The way that Patrick is suggesting I believe is the more versatile and manageable approach.
                RogerO
                Went with Patrick's suggested approach. I do like the old reactor a bit better for this instance. Less clutter. Sure there was a technical reason to do it this way. Guess I can create multiple rule sets to group them by.
                  2.1k
                  3.9k
