Support for Ezlo Atom controllers?
The port number is right, it connects, it just never answers the usual login request, and doesn't issue any messages of any kind at all. I embellished details in my previous post there, and prompted Oleg in it. In any case, none of this is serviceable until this is documented.
Over a year ago on Skype, early on in perhaps March or April, I suggested that all of their PDF documents need to be in a single location/library where they can seen. This business of them posting single PDFs on demand in the forums is the worst possible way to get it done (maybe second worst: they were replying on Skype with them, which was actually worse). Did that ever happen? I know of no such repository. If there were, at least one could research, but as it is, their docs are a hodge-podge of "lucky if you have it" one-offs, a dated web reference site, and an incomplete/dated API tool. And no version control. Ugh. This entire situation is why I didn't want to do this eZLO interface, and I'm really regretting it this morning.
I feel your pain.
Forgot it for now then.
For me personally I don't need my Atom connected to MSR. But I just thought I'd try it and test it if it did connect.
As long as Ezlo Plus and Ezlo Secure works, I think most people will be happy with that.
That website you mentioned is all I know of and there's a bit of a library section they created on the forum here.
Yeah, nothing there either. Cart before the horse. API docs. No docs for how to log in to the API. And enough people have asked, including you, to produce various unofficial mechanisms; that should have been enough prompt/repetition to cause an official document to be produced (and really, together with/as part of the API docs is the perfect place for it).
Might be a bit OT, or not... I can't get my only Ezlo controller (a Plus) to work in MSR. I have the latest version of MSR (21203-9503e5d), and I have added all needed lines to my reactor.yaml. This is the message I get:
2021-07-29T13:13:57.524Z <Structure:ERR> [Structure:start] failed to start controller ezlo: Error: Cannot find module 'server/lib/Configuration' Require stack: - D:\msr\server\lib\EzloController.js 2021-07-29T13:13:57.525Z <Structure:CRIT> Error: Cannot find module 'server/lib/Configuration' Require stack: - D:\msr\server\lib\EzloController.js Error: Cannot find module 'server/lib/Configuration' Require stack: - D:\msr\server\lib\EzloController.js at Function.Module._resolveFilename (node:internal/modules/cjs/loader:924:15) at Function.Module._load (node:internal/modules/cjs/loader:769:27) at Module.require (node:internal/modules/cjs/loader:996:19) at require (node:internal/modules/cjs/helpers:92:18) at Object.<anonymous> (D:\msr\server\lib\EzloController.js:527:157) at Module._compile (node:internal/modules/cjs/loader:1092:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1121:10) at Module.load (node:internal/modules/cjs/loader:972:32) at Function.Module._load (node:internal/modules/cjs/loader:813:14) at ModuleWrap.<anonymous> (node:internal/modules/esm/translators:201:29) Error: Cannot find module 'server/lib/Configuration' Require stack: - D:\msr\server\lib\EzloController.js at Function.Module._resolveFilename (node:internal/modules/cjs/loader:924:15) at Function.Module._load (node:internal/modules/cjs/loader:769:27) at Module.require (node:internal/modules/cjs/loader:996:19) at require (node:internal/modules/cjs/helpers:92:18) at Object.<anonymous> (D:\msr\server\lib\EzloController.js:527:157) at Module._compile (node:internal/modules/cjs/loader:1092:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1121:10) at Module.load (node:internal/modules/cjs/loader:972:32) at Function.Module._load (node:internal/modules/cjs/loader:813:14) at ModuleWrap.<anonymous> (node:internal/modules/esm/translators:201:29) { code: 'MODULE_NOT_FOUND', requireStack: [ 'D:\\msr\\server\\lib\\EzloController.js' ] }And this is my reactor.yaml:
- id: ezlo enabled: true implementation: EzloController name: Ezlo Plus config: source: "wss://192.168.50.211:17000" # change the IP address serial: "90000453" # put your hub's serial # here username: "My_secret_name" # put your username here betw quotes password: "My_top_secret_password" # and passwordI have restarted MSR several times, with no luck. Any clues?
How is MSR installed, and how are you running/starting it?
MSR is installed on Windows 10, bare metall.
I open up Windows Powershell and navigate to the MSR folder, and then type "node app.js".
Everything else is working. I have a Vera and a Home Assistant up and running since months back... It's just the Ezlo that's not working. -
OK. You need to set the shell environment variable NODE_PATH to the install directory where Reactor lives (the directory that contains Reactor's app.js file).
@toggledbits . Thanks. Did that. Sadly it still don't work. Got this instead:
PS D:\msr> node app.js basedir D:\msr confdir D:\msr\config datadir D:\msr\storage logsdir D:\msr\logs plugindir D:\msr\ext module.paths [ 'D:\\msr\\node_modules', 'D:\\node_modules' ] NODE_PATH D:\MSR Logging stream path spec may be using pre-21075 form; please remove ./logs/ from the path! 2021-07-30T13:10:38.707Z <app:null> Reactor latest-21203-9503e5d starting on v15.11.0 2021-07-30T13:10:38.708Z <app:INFO> Process ID 16096; platform win32/x64 Windows 10 Pro 2021-07-30T13:10:38.709Z <app:INFO> Basedir D:\msr; data in D:\msr\storage 2021-07-30T13:10:38.709Z <app:INFO> NODE_PATH D:\MSR; module paths [ "D:\\msr\\node_modules", "D:\\node_modules" ] 2021-07-30T13:10:38.751Z <Plugin:null> Module Plugin v21173 2021-07-30T13:10:38.757Z <default:INFO> Module Entity v21177 2021-07-30T13:10:38.760Z <Controller:null> Module Controller v21191 2021-07-30T13:10:38.761Z <default:null> Module Structure v21196 2021-07-30T13:10:38.766Z <default:null> Module Ruleset v21096 2021-07-30T13:10:38.766Z <default:null> Module Rulesets v21096 2021-07-30T13:10:38.781Z <default:null> Module Rule v21168 2021-07-30T13:10:38.786Z <default:null> Module Engine v21197 2021-07-30T13:10:38.787Z <default:null> Module httpapi v21200 2021-07-30T13:10:38.790Z <default:null> Module httpproxy v21054 2021-07-30T13:10:38.806Z <default:null> Module wsapi v21196 2021-07-30T13:10:38.810Z <app:NOTICE> Starting Structure... 2021-07-30T13:10:38.814Z <Structure:INFO> Structure#1 starting controller interface vera (VeraController) 2021-07-30T13:10:38.820Z <Structure:INFO> Structure#1 starting controller interface ezlo (EzloController) 2021-07-30T13:10:38.822Z <Structure:INFO> Structure#1 starting controller interface hass (HassController) 2021-07-30T13:10:38.823Z <Structure:INFO> Structure#1 starting controller interface reactor_system (SystemController) 2021-07-30T13:10:38.860Z <default:null> Module VeraController v21202 2021-07-30T13:10:38.924Z <default:null> Module HassController v21191 2021-07-30T13:10:38.926Z <default:null> Module SystemController v21102 2021-07-30T13:10:38.929Z <VeraController:NOTICE> VeraController#vera starting 2021-07-30T13:10:38.960Z <VeraController:INFO> VeraController#vera loaded mapping ver 21202 rev 1 format 1 notice 2021-07-30T13:10:38.970Z <Controller:CRIT> Controller: failed to load ezlo implementation file:///D:/msr/server/lib/EzloController.js: TypeError: Cannot read property 'getConfig' of undefined 2021-07-30T13:10:38.970Z <Controller:CRIT> TypeError: Cannot read property 'getConfig' of undefined TypeError: Cannot read property 'getConfig' of undefined at Function.getInstance (D:\MSR\server\lib\Configuration.js:128:89) at Object.<anonymous> (D:\MSR\server\lib\Logger.js:154:49) at Module._compile (node:internal/modules/cjs/loader:1092:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1121:10) at Module.load (node:internal/modules/cjs/loader:972:32) at Function.Module._load (node:internal/modules/cjs/loader:813:14) at Module.require (node:internal/modules/cjs/loader:996:19) at require (node:internal/modules/cjs/helpers:92:18) at Object.<anonymous> (D:\MSR\server\lib\Capabilities.js:71:99) at Module._compile (node:internal/modules/cjs/loader:1092:14) TypeError: Cannot read property 'getConfig' of undefined at Function.getInstance (D:\MSR\server\lib\Configuration.js:128:89) at Object.<anonymous> (D:\MSR\server\lib\Logger.js:154:49) at Module._compile (node:internal/modules/cjs/loader:1092:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1121:10) at Module.load (node:internal/modules/cjs/loader:972:32) at Function.Module._load (node:internal/modules/cjs/loader:813:14) at Module.require (node:internal/modules/cjs/loader:996:19) at require (node:internal/modules/cjs/helpers:92:18) at Object.<anonymous> (D:\MSR\server\lib\Capabilities.js:71:99) at Module._compile (node:internal/modules/cjs/loader:1092:14) -
Fix the case on your NODE_PATH value so it matches the actual case of every element of the directory path and give it a try.
I've tried and tried - but I can't get it to work (getting the Ezlo Plus to work in MSR). I've several times tried every step. I use the Windows 10 bare metal install (reactor-latest-21221-4a447cb).
I have repeatedly used:npm install --loglevel error --no-save set NODE_PATH=D:\reactorAll cases are correct.
This is what I get:
2021-08-12T17:45:38.541Z <Controller:CRIT> Controller: failed to load ezlo implementation file:///D:/reactor/server/lib/EzloController.js: Error: Cannot find module 'server/lib/Configuration' Require stack: - D:\reactor\server\lib\EzloController.js 2021-08-12T17:45:38.542Z <Controller:CRIT> Error: Cannot find module 'server/lib/Configuration' Require stack: - D:\reactor\server\lib\EzloController.js Error: Cannot find module 'server/lib/Configuration' Require stack: - D:\reactor\server\lib\EzloController.js at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15) at Function.Module._load (node:internal/modules/cjs/loader:778:27) at Module.require (node:internal/modules/cjs/loader:1005:19) at require (node:internal/modules/cjs/helpers:94:18) at Object.<anonymous> (D:\reactor\server\lib\EzloController.js:506:144) at Module._compile (node:internal/modules/cjs/loader:1101:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10) at Module.load (node:internal/modules/cjs/loader:981:32) at Function.Module._load (node:internal/modules/cjs/loader:822:12) at ModuleWrap.<anonymous> (node:internal/modules/esm/translators:201:29) Error: Cannot find module 'server/lib/Configuration' Require stack: - D:\reactor\server\lib\EzloController.js at Function.Module._resolveFilename (node:internal/modules/cjs/loader:933:15) at Function.Module._load (node:internal/modules/cjs/loader:778:27) at Module.require (node:internal/modules/cjs/loader:1005:19) at require (node:internal/modules/cjs/helpers:94:18) at Object.<anonymous> (D:\reactor\server\lib\EzloController.js:506:144) at Module._compile (node:internal/modules/cjs/loader:1101:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1153:10) at Module.load (node:internal/modules/cjs/loader:981:32) at Function.Module._load (node:internal/modules/cjs/loader:822:12) at ModuleWrap.<anonymous> (node:internal/modules/esm/translators:201:29) { code: 'MODULE_NOT_FOUND', requireStack: [ 'D:\\reactor\\server\\lib\\EzloController.js' ] }I do have the files that's MSR is asking for (eg. D:\reactor\server\lib\EzloController.js). So it's so strange! Do you know what could be wrong?
Best regards,
/Fanan -
Working for me:
C:\Users\Patrick\Documents\MSR>set NODE_PATH=C:\Users\Patrick\Documents\MSR C:\Users\Patrick\Documents\MSR>node app.js basedir C:\Users\Patrick\Documents\MSR confdir C:\Users\Patrick\Documents\MSR\config datadir C:\Users\Patrick\Documents\MSR\storage logsdir C:\Users\Patrick\Documents\MSR\logs plugindir C:\Users\Patrick\Documents\MSR\ext module.paths [ 'C:\\Users\\Patrick\\Documents\\MSR\\node_modules', 'C:\\Users\\Patrick\\Documents\\node_modules', 'C:\\Users\\Patrick\\node_modules', 'C:\\Users\\node_modules', 'C:\\node_modules' ] NODE_PATH C:\Users\Patrick\Documents\MSR 2021-08-12T18:39:38.096Z <app:null> Reactor ###BUILDVERSION### starting on v14.15.5 2021-08-12T18:39:38.097Z <app:INFO> Process ID 26416; platform win32/x64 Windows 10 Pro 2021-08-12T18:39:38.099Z <app:INFO> Basedir C:\Users\Patrick\Documents\MSR; data in C:\Users\Patrick\Documents\MSR\storage 2021-08-12T18:39:38.099Z <app:INFO> NODE_PATH C:\Users\Patrick\Documents\MSR; module paths [ "C:\\Users\\Patrick\\Documents\\MSR\\node_modules", "C:\\Users\\Patrick\\Documents\\node_modules", "C:\\Users\\Patrick\\node_modules", "C:\\Users\\node_modules", "C:\\node_modules" ] 2021-08-12T18:39:38.100Z <app:INFO> process.env=[object Object] 2021-08-12T18:39:38.100Z <app:INFO> process.env.TEST=(undefined) 2021-08-12T18:39:38.145Z <Plugin:null> Module Plugin v21173 2021-08-12T18:39:38.152Z <default:INFO> Module Entity v21177 2021-08-12T18:39:38.155Z <Controller:null> Module Controller v21191 2021-08-12T18:39:38.156Z <default:null> Module Structure v21216 2021-08-12T18:39:38.162Z <default:null> Module Ruleset v21096 2021-08-12T18:39:38.162Z <default:null> Module Rulesets v21096 2021-08-12T18:39:38.181Z <default:null> Module Rule v21221 2021-08-12T18:39:38.185Z <default:null> Module Engine v21213 2021-08-12T18:39:38.186Z <default:null> Module httpapi v21215 2021-08-12T18:39:38.189Z <default:null> Module httpproxy v21054 2021-08-12T18:39:38.209Z <default:null> Module wsapi v21196 2021-08-12T18:39:38.212Z <app:NOTICE> Starting Structure... 2021-08-12T18:39:38.214Z <Structure:NOTICE> Structure#1 plugin ID influx disabled; skipping 2021-08-12T18:39:38.216Z <Structure:INFO> Structure#1 starting controller interface ezlo (EzloController) 2021-08-12T18:39:38.220Z <Structure:INFO> Structure#1 starting controller interface reactor_system (SystemController) 2021-08-12T18:39:38.249Z <default:null> Module EzloController v21218 2021-08-12T18:39:38.251Z <default:null> Module SystemController v21102 2021-08-12T18:39:38.254Z <EzloController:null> EzloController#ezlo created, config { "source": "wss://192.168.0.67:17000", "serial": "900xxxxx", "username": "xxxxx", "password": "xxxxx", "auto_rediscover": false } 2021-08-12T18:39:38.255Z <EzloController:null> EzloController#ezlo instance log level (null) (4) 2021-08-12T18:39:38.269Z <Controller:INFO> EzloController#ezlo device mapping data loaded; checking... 2021-08-12T18:39:38.272Z <Controller:INFO> EzloController#ezlo performing cloud auth to get local access token 2021-08-12T18:39:38.324Z <Controller:NOTICE> Controller SystemController#reactor_system is now online. 2021-08-12T18:39:38.395Z <app:INFO> Structure running; pausing for controllers' initial ready 2021-08-12T18:39:39.934Z <Controller:INFO> EzloController#ezlo cloud auth phase complete (local access token acquired) 2021-08-12T18:39:39.936Z <Controller:INFO> EzloController#ezlo opening local hub connection to "900xxxxx" at wss://192.168.0.67:17000 2021-08-12T18:39:39.938Z <Controller:NOTICE> EzloController#ezlo configured to ignore host ("900xxxxx") certificate 2021-08-12T18:39:39.940Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://192.168.0.67:17000 2021-08-12T18:39:40.038Z <Controller:NOTICE> EzloController#ezlo successful hub login; performing inventory 2021-08-12T18:39:40.227Z <Controller:INFO> EzloController#ezlo data load complete; 21 devices received, 26 entities registered; 66 items. 2021-08-12T18:39:40.227Z <Controller:INFO> EzloController#ezlo hub inventory complete/successful; 187ms 2021-08-12T18:39:40.229Z <Controller:NOTICE> Controller EzloController#ezlo is now online. 2021-08-12T18:39:40.231Z <app:NOTICE> Starting Reaction Engine... 2021-08-12T18:39:40.233Z <Engine:INFO> Reaction Engine starting 2021-08-12T18:39:40.234Z <Engine:INFO> Checking rule sets... 2021-08-12T18:39:40.237Z <Engine:INFO> Checking rules... 2021-08-12T18:39:40.237Z <Engine:INFO> Data check complete; no corrections. 2021-08-12T18:39:40.240Z <Engine:NOTICE> Reaction Engine running! 2021-08-12T18:39:40.241Z <app:NOTICE> Starting HTTP server and API... 2021-08-12T18:39:40.245Z <app:NOTICE> Startup complete 2021-08-12T18:39:40.249Z <httpapi:NOTICE> HTTP API v1 21215 base URL http://192.168.0.164:8111; listening 2021-08-12T18:39:40.258Z <app:NOTICE> HTTP server running; registering proxy endpoints. 2021-08-12T18:39:40.259Z <app:NOTICE> Starting WSAPI... 2021-08-12T18:39:40.260Z <wsapi:NOTICE> wsapi: starting version 21196 2021-08-12T18:39:40.343Z <Engine:INFO> Engine#1 master timer tick, local time "8/12/2021, 2:39:40 PM" (TZ offset -240 mins from UTC)Your snippets don't show the current startup information, which would be useful. Make sure that NODE_PATH appears with the correct value in the startup messages, as shown in the log above.
Also works under PowerShell:
PS C:\Users\Patrick\Documents\MSR> $env:NODE_PATH = 'C:\Users\Patrick\Documents\MSR' PS C:\Users\Patrick\Documents\MSR> $env:NODE_PATH C:\Users\Patrick\Documents\MSR PS C:\Users\Patrick\Documents\MSR> node app.js basedir C:\Users\Patrick\Documents\MSR confdir C:\Users\Patrick\Documents\MSR\config datadir C:\Users\Patrick\Documents\MSR\storage logsdir C:\Users\Patrick\Documents\MSR\logs plugindir C:\Users\Patrick\Documents\MSR\ext module.paths [ 'C:\\Users\\Patrick\\Documents\\MSR\\node_modules', 'C:\\Users\\Patrick\\Documents\\node_modules', 'C:\\Users\\Patrick\\node_modules', 'C:\\Users\\node_modules', 'C:\\node_modules' ] NODE_PATH C:\Users\Patrick\Documents\MSR 2021-08-12T18:45:56.225Z <app:null> Reactor ###BUILDVERSION### starting on v14.15.5 2021-08-12T18:45:56.226Z <app:INFO> Process ID 25296; platform win32/x64 Windows 10 Pro 2021-08-12T18:45:56.227Z <app:INFO> Basedir C:\Users\Patrick\Documents\MSR; data in C:\Users\Patrick\Documents\MSR\storage 2021-08-12T18:45:56.227Z <app:INFO> NODE_PATH C:\Users\Patrick\Documents\MSR; module paths [ "C:\\Users\\Patrick\\Documents\\MSR\\node_modules", "C:\\Users\\Patrick\\Documents\\node_modules", "C:\\Users\\Patrick\\node_modules", "C:\\Users\\node_modules", "C:\\node_modules" ] 2021-08-12T18:45:56.228Z <app:INFO> process.env=[object Object] 2021-08-12T18:45:56.228Z <app:INFO> process.env.TEST=(undefined) 2021-08-12T18:45:56.271Z <Plugin:null> Module Plugin v21173 2021-08-12T18:45:56.279Z <default:INFO> Module Entity v21177 2021-08-12T18:45:56.282Z <Controller:null> Module Controller v21191 2021-08-12T18:45:56.283Z <default:null> Module Structure v21216 2021-08-12T18:45:56.287Z <default:null> Module Ruleset v21096 2021-08-12T18:45:56.287Z <default:null> Module Rulesets v21096 2021-08-12T18:45:56.303Z <default:null> Module Rule v21221 2021-08-12T18:45:56.310Z <default:null> Module Engine v21213 2021-08-12T18:45:56.310Z <default:null> Module httpapi v21215 2021-08-12T18:45:56.312Z <default:null> Module httpproxy v21054 2021-08-12T18:45:56.332Z <default:null> Module wsapi v21196 2021-08-12T18:45:56.334Z <app:NOTICE> Starting Structure... 2021-08-12T18:45:56.338Z <Structure:NOTICE> Structure#1 plugin ID influx disabled; skipping 2021-08-12T18:45:56.339Z <Structure:INFO> Structure#1 starting controller interface ezlo (EzloController) 2021-08-12T18:45:56.344Z <Structure:INFO> Structure#1 starting controller interface reactor_system (SystemController) 2021-08-12T18:45:56.370Z <default:null> Module EzloController v21218 2021-08-12T18:45:56.372Z <default:null> Module SystemController v21102 2021-08-12T18:45:56.375Z <EzloController:null> EzloController#ezlo created, config { "source": "wss://192.168.0.67:17000", "serial": "900xxxxx", "username": "xxxxx", "password": "xxxxx", "auto_rediscover": false } 2021-08-12T18:45:56.375Z <EzloController:null> EzloController#ezlo instance log level (null) (4) 2021-08-12T18:45:56.385Z <Controller:INFO> EzloController#ezlo device mapping data loaded; checking... 2021-08-12T18:45:56.386Z <Controller:INFO> EzloController#ezlo performing cloud auth to get local access token 2021-08-12T18:45:56.441Z <Controller:NOTICE> Controller SystemController#reactor_system is now online. 2021-08-12T18:45:56.518Z <app:INFO> Structure running; pausing for controllers' initial ready 2021-08-12T18:45:59.726Z <Controller:INFO> EzloController#ezlo cloud auth phase complete (local access token acquired) 2021-08-12T18:45:59.727Z <Controller:INFO> EzloController#ezlo opening local hub connection to "900xxxxx" at wss://192.168.0.67:17000 2021-08-12T18:45:59.727Z <Controller:NOTICE> EzloController#ezlo configured to ignore host ("900xxxxx") certificate 2021-08-12T18:45:59.729Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://192.168.0.67:17000 2021-08-12T18:45:59.823Z <Controller:NOTICE> EzloController#ezlo successful hub login; performing inventory 2021-08-12T18:46:00.006Z <Controller:INFO> EzloController#ezlo data load complete; 21 devices received, 26 entities registered; 66 items. 2021-08-12T18:46:00.006Z <Controller:INFO> EzloController#ezlo hub inventory complete/successful; 182ms 2021-08-12T18:46:00.007Z <Controller:NOTICE> Controller EzloController#ezlo is now online. 2021-08-12T18:46:00.008Z <app:NOTICE> Starting Reaction Engine... 2021-08-12T18:46:00.009Z <Engine:INFO> Reaction Engine starting 2021-08-12T18:46:00.009Z <Engine:INFO> Checking rule sets... 2021-08-12T18:46:00.012Z <Engine:INFO> Checking rules... 2021-08-12T18:46:00.012Z <Engine:INFO> Data check complete; no corrections. 2021-08-12T18:46:00.016Z <Engine:NOTICE> Reaction Engine running! 2021-08-12T18:46:00.017Z <app:NOTICE> Starting HTTP server and API... 2021-08-12T18:46:00.022Z <app:NOTICE> Startup complete 2021-08-12T18:46:00.026Z <httpapi:NOTICE> HTTP API v1 21215 base URL http://192.168.0.164:8111; listening 2021-08-12T18:46:00.039Z <app:NOTICE> HTTP server running; registering proxy endpoints. 2021-08-12T18:46:00.040Z <app:NOTICE> Starting WSAPI... 2021-08-12T18:46:00.042Z <wsapi:NOTICE> wsapi: starting version 21196 2021-08-12T18:46:00.123Z <Engine:INFO> Engine#1 master timer tick, local time "8/12/2021, 2:46:00 PM" (TZ offset -240 mins from UTC) -
Working for me:
PS C:\Users\Patrick\Documents\MSR> $env:NODE_PATH = 'C:\Users\Patrick\Documents\MSR' PS C:\Users\Patrick\Documents\MSR> $env:NODE_PATH C:\Users\Patrick\Documents\MSR PS C:\Users\Patrick\Documents\MSR> node app.js basedir C:\Users\Patrick\Documents\MSR confdir C:\Users\Patrick\Documents\MSR\config datadir C:\Users\Patrick\Documents\MSR\storage logsdir C:\Users\Patrick\Documents\MSR\logs plugindir C:\Users\Patrick\Documents\MSR\ext module.paths [ 'C:\\Users\\Patrick\\Documents\\MSR\\node_modules', 'C:\\Users\\Patrick\\Documents\\node_modules', 'C:\\Users\\Patrick\\node_modules', 'C:\\Users\\node_modules', 'C:\\node_modules' ] NODE_PATH C:\Users\Patrick\Documents\MSR 2021-08-12T18:45:56.225Z <app:null> Reactor ###BUILDVERSION### starting on v14.15.5 2021-08-12T18:45:56.226Z <app:INFO> Process ID 25296; platform win32/x64 Windows 10 Pro 2021-08-12T18:45:56.227Z <app:INFO> Basedir C:\Users\Patrick\Documents\MSR; data in C:\Users\Patrick\Documents\MSR\storage 2021-08-12T18:45:56.227Z <app:INFO> NODE_PATH C:\Users\Patrick\Documents\MSR; module paths [ "C:\\Users\\Patrick\\Documents\\MSR\\node_modules", "C:\\Users\\Patrick\\Documents\\node_modules", "C:\\Users\\Patrick\\node_modules", "C:\\Users\\node_modules", "C:\\node_modules" ] 2021-08-12T18:45:56.228Z <app:INFO> process.env=[object Object] 2021-08-12T18:45:56.228Z <app:INFO> process.env.TEST=(undefined) 2021-08-12T18:45:56.271Z <Plugin:null> Module Plugin v21173 2021-08-12T18:45:56.279Z <default:INFO> Module Entity v21177 2021-08-12T18:45:56.282Z <Controller:null> Module Controller v21191 2021-08-12T18:45:56.283Z <default:null> Module Structure v21216 2021-08-12T18:45:56.287Z <default:null> Module Ruleset v21096 2021-08-12T18:45:56.287Z <default:null> Module Rulesets v21096 2021-08-12T18:45:56.303Z <default:null> Module Rule v21221 2021-08-12T18:45:56.310Z <default:null> Module Engine v21213 2021-08-12T18:45:56.310Z <default:null> Module httpapi v21215 2021-08-12T18:45:56.312Z <default:null> Module httpproxy v21054 2021-08-12T18:45:56.332Z <default:null> Module wsapi v21196 2021-08-12T18:45:56.334Z <app:NOTICE> Starting Structure... 2021-08-12T18:45:56.338Z <Structure:NOTICE> Structure#1 plugin ID influx disabled; skipping 2021-08-12T18:45:56.339Z <Structure:INFO> Structure#1 starting controller interface ezlo (EzloController) 2021-08-12T18:45:56.344Z <Structure:INFO> Structure#1 starting controller interface reactor_system (SystemController) 2021-08-12T18:45:56.370Z <default:null> Module EzloController v21218 2021-08-12T18:45:56.372Z <default:null> Module SystemController v21102 2021-08-12T18:45:56.375Z <EzloController:null> EzloController#ezlo created, config { "source": "wss://192.168.0.67:17000", "serial": "900xxxxx", "username": "xxxxx", "password": "xxxxx", "auto_rediscover": false } 2021-08-12T18:45:56.375Z <EzloController:null> EzloController#ezlo instance log level (null) (4) 2021-08-12T18:45:56.385Z <Controller:INFO> EzloController#ezlo device mapping data loaded; checking... 2021-08-12T18:45:56.386Z <Controller:INFO> EzloController#ezlo performing cloud auth to get local access token 2021-08-12T18:45:56.441Z <Controller:NOTICE> Controller SystemController#reactor_system is now online. 2021-08-12T18:45:56.518Z <app:INFO> Structure running; pausing for controllers' initial ready 2021-08-12T18:45:59.726Z <Controller:INFO> EzloController#ezlo cloud auth phase complete (local access token acquired) 2021-08-12T18:45:59.727Z <Controller:INFO> EzloController#ezlo opening local hub connection to "900xxxxx" at wss://192.168.0.67:17000 2021-08-12T18:45:59.727Z <Controller:NOTICE> EzloController#ezlo configured to ignore host ("900xxxxx") certificate 2021-08-12T18:45:59.729Z <Controller:NOTICE> EzloController#ezlo connecting via WS to wss://192.168.0.67:17000 2021-08-12T18:45:59.823Z <Controller:NOTICE> EzloController#ezlo successful hub login; performing inventory 2021-08-12T18:46:00.006Z <Controller:INFO> EzloController#ezlo data load complete; 21 devices received, 26 entities registered; 66 items. 2021-08-12T18:46:00.006Z <Controller:INFO> EzloController#ezlo hub inventory complete/successful; 182ms 2021-08-12T18:46:00.007Z <Controller:NOTICE> Controller EzloController#ezlo is now online. 2021-08-12T18:46:00.008Z <app:NOTICE> Starting Reaction Engine... 2021-08-12T18:46:00.009Z <Engine:INFO> Reaction Engine starting 2021-08-12T18:46:00.009Z <Engine:INFO> Checking rule sets... 2021-08-12T18:46:00.012Z <Engine:INFO> Checking rules... 2021-08-12T18:46:00.012Z <Engine:INFO> Data check complete; no corrections. 2021-08-12T18:46:00.016Z <Engine:NOTICE> Reaction Engine running! 2021-08-12T18:46:00.017Z <app:NOTICE> Starting HTTP server and API... 2021-08-12T18:46:00.022Z <app:NOTICE> Startup complete 2021-08-12T18:46:00.026Z <httpapi:NOTICE> HTTP API v1 21215 base URL http://192.168.0.164:8111; listening 2021-08-12T18:46:00.039Z <app:NOTICE> HTTP server running; registering proxy endpoints. 2021-08-12T18:46:00.040Z <app:NOTICE> Starting WSAPI... 2021-08-12T18:46:00.042Z <wsapi:NOTICE> wsapi: starting version 21196 2021-08-12T18:46:00.123Z <Engine:INFO> Engine#1 master timer tick, local time "8/12/2021, 2:46:00 PM" (TZ offset -240 mins from UTC)@toggledbits
Thanks! I now seem to have overcome the NODE_PATH.... So the next problem arise. I now get a message related to the Ezlo plus: "... ezlo failed to authenticate: Error: Request failed: 404 NOT FOUND."I did a screenshot, so that I could easily hide my credentials. I have used my username as I use for both my Vera and Ezlo. I have checked them over and over - and they are correct. Is it something connected to the " "? Or what could it be?
The last lines are:
2021-08-13T12:04:13.950Z <Controller:ERR> EzloController#ezlo failed to authenticate: Error: Request failed: 404 NOT FOUND 2021-08-13T12:04:13.951Z <Controller:ERR> EzloController#ezlo failed to log in: auth failed 2021-08-13T12:04:15.034Z <VeraController:NOTICE> Controller VeraController#vera is now online. 2021-08-13T12:04:18.963Z <Controller:INFO> EzloController#ezlo performing cloud auth to get local access token 2021-08-13T12:04:19.460Z <Controller:ERR> EzloController#ezlo failed to authenticate: Error: Request failed: 404 NOT FOUND 2021-08-13T12:04:19.461Z <Controller:ERR> EzloController#ezlo failed to log in: auth failed 2021-08-13T12:04:24.470Z <Controller:INFO> EzloController#ezlo performing cloud auth to get local access token 2021-08-13T12:04:24.955Z <Controller:ERR> EzloController#ezlo failed to authenticate: Error: Request failed: 404 NOT FOUND 2021-08-13T12:04:24.956Z <Controller:ERR> EzloController#ezlo failed to log in: auth failed -
Username or password is incorrect. The "NOT FOUND" it is referring to is you.
I also thought so. But it's not incorrect. I even tried to create another user profile. The profile is able to log in to Vera/Ezlo. But when I use the profiles credentials, I get the same error. I changed between my true profile and the test profile - and always get the same result. So it's more to the story.
This is from my yaml file. I guess it looks alright?
Are there any special characters in the password, like international characters? Also what region are you in?
Yes, there is a @ in my password. I'm in Europe/Sweden.
Vera/Ezlo has these demands on the passwords:
Password must be at least 8 characters long and include:- at least one lowercase letter;
- at least one special character;
- uppercase letters or numbers.
Is your username capitalized?
Yes. Everywhere. -
OK. That's probably it. Try creating an account with an all lower-case username. Password is fine.
