  4. Having issues with a shell command
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Need help with sequence
Possible feature request?
60 Posts 2 Posters 11.6k Views 2 Watching
    I am having issues with a shell command. I installed ps4-waker on to the same Debian box as MSR. Its a utility to turn on the Playstation4 console as Sony block 3rd party remotes like Harmony from doing it.
    I have two rules setup in MSR, one that turns on the PS4 when the associated Harmony Activity is starting (Vera Harmony plugin).
    The shell command that is sent in this rule is just:
    ps4-waker
    This works most of the time OK, but sometimes for some reason the PS4 doesn't turn on every time.
    I then had another rule and I wanted to see if I could extract some information? from the ps4-waker utility about the status of the PS4. The shell command for this one is:
    ps4-waker check
    In the rule I get "null"
    This is the one that isn't working currently. In the log it says:
    <Engine:ERR> Engine#1 reaction PS4 Waker Check<SET> step 0 error executing shell `ps4-waker check': Error: Command failed: ps4-waker check
    If I run this command directly in terminal it works fine every time:
    As a quick test I changed the shell command to this one and that does work OK
    ps4-waker --help
    This is the --help output of the switches and options:
      Look for other messages in the log file before the one you pasted.
        Here is a bit more of the log:
        2021-07-30T14:06:29.372Z <Engine:ERR> Engine#1 reaction PS4 Waker Check<SET> step 0 error executing shell `ps4-waker check': Error: Command failed: ps4-waker check
        2021-07-30T14:06:29.375Z <Rule:5:Rule.js:674> Rule#rule-krq612qx rule set variable ps4wakercheck = (object) (null)
        2021-07-30T14:06:29.376Z <Engine:5:Engine.js:940> Engine#1 set variable rule rule-krq612qx ps4wakercheck=(null), requesting re-eval
        2021-07-30T14:06:29.377Z <Rule:5:Rule.js:962> Rule#rule-krq612qx (PS4 Waker Check) evaluate() acquiring mutex
        2021-07-30T14:06:29.378Z <Engine:5:Engine.js:1140> _process_reaction_queue() wake-up!
        2021-07-30T14:06:29.379Z <Rule:5:Rule.js:966> Rule#rule-krq612qx._evaluate() mutex acquired, evaluating
        2021-07-30T14:06:29.380Z <Rule:5:Rule.js:970> Rule#rule-krq612qx update rate is 2/min limit 60/min
        2021-07-30T14:06:29.381Z <Rule:5:Rule.js:892> Rule#rule-krq612qx evaluateExpressions() with 1 expressions
        2021-07-30T14:06:29.382Z <Rule:5:Rule.js:1600> cond condbefy480 evaluation state false->true
        2021-07-30T14:06:29.383Z <Rule:5:Rule.js:1600> cond trig evaluation state false->true
        2021-07-30T14:06:29.383Z <Rule:5:Rule.js:982> Rule#rule-krq612qx._evaluate() trigger state now true (was false)
        2021-07-30T14:06:29.384Z <Rule:5:Rule.js:984> Rule#rule-krq612qx._evaluate() constraints state true
        2021-07-30T14:06:29.384Z <Rule:5:Rule.js:988> Rule#rule-krq612qx ready to set, constraints met
        2021-07-30T14:06:29.385Z <Rule:5:Rule.js:991> Rule#rule-krq612qx rule state changed, was false now true
        2021-07-30T14:06:29.385Z <Rule:INFO> PS4 Waker Check (Rule#rule-krq612qx) SET!
        2021-07-30T14:06:29.386Z <Rule:5:Rule.js:993> Rule#rule-krq612qx rule state now true, changed true
        2021-07-30T14:06:29.391Z <Engine:5:Engine.js:1101> _process_reaction_queue() running task 37 { "tid": 37, "id": "rule-krq612qx:S", "rule": "rule-krq612qx", "__reaction": [RuleReaction#rule-krq612qx:S], "next_step": 1, "status": 1, "ts": 1627653988822, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise], "attempts": 1 }
        2021-07-30T14:06:29.391Z <Engine:NOTICE> Resuming reaction PS4 Waker Check<SET> (rule-krq612qx:S) from step 1
        2021-07-30T14:06:29.391Z <Engine:INFO> PS4 Waker Check<SET> all actions completed.
        2021-07-30T14:06:29.392Z <Engine:5:Engine.js:1105> _process_reaction_queue() task returned, new status -1; task 37
        2021-07-30T14:06:29.395Z <Engine:5:Engine.js:1140> _process_reaction_queue ending with 0 in queue; none delayed/ready; waiting
        2021-07-30T14:06:29.396Z <Rule:5:Rule.js:1010> Rule#rule-krq612qx enqueueing reaction rule-krq612qx:S
        2021-07-30T14:06:29.396Z <Engine:INFO> Enqueueing "PS4 Waker Check<SET>" (rule-krq612qx:S)
        2021-07-30T14:06:29.398Z <Engine:5:Engine.js:985> Engine#1 enqueued reaction rule-krq612qx:S as 38
        2021-07-30T14:06:29.399Z <Engine:5:Engine.js:1140> _process_reaction_queue() wake-up!
        2021-07-30T14:06:29.400Z <Engine:5:Engine.js:1101> _process_reaction_queue() running task 38 { "tid": 38, "id": "rule-krq612qx:S", "rule": "rule-krq612qx", "__reaction": [RuleReaction#rule-krq612qx:S], "next_step": 0, "status": 0, "ts": 1627653989396, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise] }
        2021-07-30T14:06:29.401Z <Engine:NOTICE> Starting reaction PS4 Waker Check<SET> (rule-krq612qx:S)
        2021-07-30T14:06:29.402Z <Engine:5:Engine.js:1378> Engine#1 reaction rule-krq612qx:S step 0 shell command { "command": "ps4-waker check", "rule": "rule-krq612qx", "rvar": "ps4wakercheck" }
        2021-07-30T14:06:29.419Z <Engine:5:Engine.js:1105> _process_reaction_queue() task returned, new status 3; task 38
        2021-07-30T14:06:29.422Z <Engine:5:Engine.js:1140> _process_reaction_queue ending with 1 in queue; none delayed/ready; waiting
        2021-07-30T14:06:29.424Z <Rule:5:Rule.js:762> Rule#rule-krq612qx dependency notification timer-trigger Timer#rule-krq612qx from Timer#rule-krq612qx
        2021-07-30T14:06:29.424Z <Rule:5:Rule.js:768> Rule#rule-krq612qx requesting eval; timer-trigger Timer#rule-krq612qx
        2021-07-30T14:06:29.425Z <Rule:5:Rule.js:962> Rule#rule-krq612qx (PS4 Waker Check) evaluate() acquiring mutex
        2021-07-30T14:06:29.426Z <Rule:5:Rule.js:966> Rule#rule-krq612qx._evaluate() mutex acquired, evaluating
        2021-07-30T14:06:29.427Z <Rule:5:Rule.js:970> Rule#rule-krq612qx update rate is 3/min limit 60/min
        2021-07-30T14:06:29.428Z <Rule:5:Rule.js:892> Rule#rule-krq612qx evaluateExpressions() with 1 expressions
        2021-07-30T14:06:29.429Z <Rule:5:Rule.js:1600> cond condbefy480 evaluation state true->false
        2021-07-30T14:06:29.430Z <Rule:5:Rule.js:1600> cond trig evaluation state true->false
        2021-07-30T14:06:29.431Z <Rule:5:Rule.js:982> Rule#rule-krq612qx._evaluate() trigger state now false (was true)
        2021-07-30T14:06:29.431Z <Rule:5:Rule.js:984> Rule#rule-krq612qx._evaluate() constraints state true
        2021-07-30T14:06:29.432Z <Rule:5:Rule.js:990> Rule#rule-krq612qx trigger conditions not met
        2021-07-30T14:06:29.433Z <Rule:5:Rule.js:991> Rule#rule-krq612qx rule state changed, was true now false
        2021-07-30T14:06:29.433Z <Rule:INFO> PS4 Waker Check (Rule#rule-krq612qx) RESET!
        2021-07-30T14:06:29.434Z <Rule:5:Rule.js:993> Rule#rule-krq612qx rule state now false, changed true
        2021-07-30T14:06:29.945Z <Engine:ERR> Engine#1 reaction PS4 Waker Check<SET> step 0 error executing shell `ps4-waker check': Error: Command failed: ps4-waker check
          Nothing really of substance. That's pretty much all the output from the command. If it just fails randomly and occasionally, it's probably a device communications issue.
            No this "ps4-waker check" command I cannot get working at all with MSR. It always shows an error.
            The other command "ps4-waker" does work most of the time.
              I have two different rulesets.
              This is the working one:
              However the other rule with "check" on the end of the command has never worked and errors.
              I always see these Alerts:
                Could it be that "check" returns a non-zero exit code depending on its result? Many utilities do this. A non-zero exit code would be interpreted as an error by MSR.
                  I'm not sure, when I run the check command in terminal it always outputs something like this:
                    "type": "device",
                    "statusLine": "620 Server Standby",
                    "statusCode": "620",
                    "status": "Standby",
                    "host-id": "C863F1400EF1",
                    "host-type": "PS4",
                    "host-name": "PS4-806",
                    "host-request-port": "997",
                    "device-discovery-protocol-version": "00020020",
                    "system-version": "08520011",
                    "address": "192.168.0.201"
                  statusline "620 Server Standby" means the PS4 is currently in sleep mode.
                  Think it says "200 OK" when the PS4 is turned on and running.
                  I was wondering if I could extract that device power status using MSR and then maybe send it to a virtual device in Vera / Home Remote etc.
                  Also that check command can tell you which app is currently opened on the PS4 and also possibly which game is currently being played.
                  But its not required I guess, I just wanted to see if it could be done somehow.
                  The main thing is the PS4 is turned on when the other MSR rule detects that my Harmony activity for the PS4 has started and that at the moment seems to be working OK.
                    Try running the command this way (yourself, in a shell, not in MSR):
                        ps4-waker check ; echo $?
                    This will display the exit status of the command after it runs. You may need to run this repeatedly, under various different expectations of status, including testing when the device is disconnected/powered off, to get a complete feel for what shell exit status ps4-waker is returning under various conditions. Anything other than 0 is going to be a problem (it looks like an error). Using non-zero exit codes is a very common way for some utilities to return their status quickly so that shell scripts can make quick decisions without having to parse other data (like your output), so it's very likely that under some condition this script is working fine but returning non-zero. If that's the case, you're going to need a wrapper script to "deaden" the exit code.
                    I've also just pushed up a new build to latest that has additional logging for this action, so you can try that as well and see if it gives any new information. I would not upgrade to latest in lieu of doing the above, as I cannot display the exit code (at least, not that I've found, as yet), so the above test is still a necessary important step. This will simply add stderr output to the logging (although I suspect the prior error messages already contain all the relevant output -- this is a safety/assurance that we're seeing it).
                      When the Playstation is in sleep mode:
                      When the Playstation is turned on and running:
                      Your right the MSR rule is working and returning data only when the Playstation is turned on:
                      I thought it wasn't working when turned on but clearly it now is.
                      So because the exit code is a 1 when the Playstation is turned off that is why the MSR rule then does not return any data?
                        That's correct. Any non-zero is an error. I will add a checkbox to the action to (optionally) ignore the exit code, and make that available in a build later today.
                          That's great thank you.
                          Next problem how to extract the data from the in rule expression and split out the PS4's power status out in to another expression ?
                          I guess either "statusLine" or "statusCode" could be used.
                          (string) "{\n \"type\": \"device\",\n \"statusLine\": \"200 Ok\",\n \"statusCode\": \"200\",\n \"status\": \"Ok\",\n \"host-id\": \"C863F1400EF1\",\n \"host-type\": \"PS4\",\n \"host-name\": \"PS4-806\",\n \"host-request-port\": \"997\",\n \"device-discovery-protocol-version\": \"00020020\",\n \"system-version\": \"08520011\",\n \"running-app-name\": \"Concrete Genie\",\n \"running-app-titleid\": \"CUSA11875\",\n \"address\": \"192.168.0.201\"\n}\n"
                          And you can see there is also a "running-app-name" Concrete Genie is the game being played currently.
                            Use another expression to put that string through the parseJSON() function and it will turn it into an object you can then pick the data out of.
                              parseJSON()
                              Like this ?
                              Contents of the expression "ps4wakerparse"
                              Last value:(object) {"type":"device","statusLine":"200 Ok","statusCode":"200","status":"Ok","host-id":"C863F1400EF1","host-type":"PS4","host-name":"PS4-806","host-request-port":"997","device-discovery-protocol-version":"00020020","system-version":"08520011","running-app-name":"Concrete Genie","running-app-titleid":"CUSA11875","address":"192.168.0.201"}
                                I don't know what the first expression is/was, but the second one is correct and has parsed the value correctly. You can now refer to data in the object via ps4wakerparse.statusCode for example. For names that contain special characters, like host-id, you need to use the alternate (quoted identifier) syntax ps4wakerparse["host-id"]
                                  Seems to be working and pulling out the required data:
                                  The first expression named "ps4wakercheck" is the inital output of the shell command "ps4-waker check".
                                    OK. I see that it's not consistently clearing the error from some prior usage on ps4wakercheck, that's what's confusing/odd, so I've fixed that for today's build as well (PR 0000235).
                                      By the way, it's much more efficient to use expressions in ps4powerstatus and ps4runningapp than it is to use Set Variable actions to set them. That's kind of doing it the hard way.
                                      cw-kidC 2 Replies Last reply
                                        For the value in the expression "ps4powerstatus" its either going to be:
                                        200 = ON
                                        620 = OFF
                                        How can I have another expression that will translate those code numbers in to human text that I can then send to Vera / Home Remote ?
                                          Understood I have changed it and removed the set variable actions:
                                          EDIT:
                                          Don't think it likes that, I get these error when I press the "Reset" button on the rule.
                                            3.5k
                                            3.1k
                                            483
                                          • Self test
