  4. [SOLVED] (no data) on trigger values
3 Posts 2 Posters 704 Views 2 Watching
  • 3 Offline
    3 Offline
    I don't know if this was a result of the 21256 update or 21257, but all of my constraints triggers are showing no data. Even if the device has a triggered change. In addition, it is not showing the Conditional match either. In my screenshot, the Front door - auto locks (Day Time) is all true, but it has to be true for 15 minutes. I am not seeing the timer counter either. I tried a couple of browsers and even my tablet. No Data is seen on every rule. The actions are still running though. My lock did auto lock after 15 minutes.
      Looks like a patch made one change it should not have (for later version of code). Build 21258 now up that corrects this.
      Those are triggers by the way, not constraints...
      3 1 Reply Last reply
        3 Offline
        3 Offline
        @toggledbits said in (no data) constraints:
        😊 Oops.
        Thanks for the immediate turn around. That resolved the issue.
          148.2k
