Hello,
Hello forum instigators.
Hello,
Many thanks 🙂
Hi folks,
Looking for a recommendation:
Kevin
Hey guys...
We need:
What technologi will be best?
[###BUILDVERSION###]2023-04-26T19:41:51.683Z <ZWaveJSController:NOTICE> ZWaveJSController#zwavejs added file logger to zwavejs.log [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_cfg, which is not consistent with the recommended naming [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_mfg_spec, which is not consistent with the recommended naming [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_ver, which is not consistent with the recommended naming [###BUILDVERSION###]2023-04-26T19:41:51.747Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_values, which is not consistent with the recommended naming [###BUILDVERSION###]2023-04-26T19:41:51.837Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs connecting to ws://192.168.0.10:3000 [###BUILDVERSION###]2023-04-26T19:41:51.874Z <ZWaveJSController:NOTICE> ZWaveJSController#zwavejs connected [###BUILDVERSION###]2023-04-26T19:41:51.874Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs sending connection initialization [###BUILDVERSION###]2023-04-26T19:41:51.931Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs greeting from server: [Object]{ "type": "version", "driverVersion": "10.16.0", "serverVersion": "1.28.0", "homeId": 3631280043, "minSchemaVersion": 0, "maxSchemaVersion": 28 } [###BUILDVERSION###]2023-04-26T19:41:51.932Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs performing initial inventory [###BUILDVERSION###]2023-04-26T19:41:52.325Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs manufacturer-specific data for 134 (AEON Labs) from package ver 22315.1 [###BUILDVERSION###]2023-04-26T19:41:52.328Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs configuring node 1 endpoint 0 (entity "1-0") [###BUILDVERSION###]2023-04-26T19:41:52.339Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs manufacturer-specific data for 543 (Elexa Consumer Products Inc.)I think this is going to be a problem. Is there a way in NodeBB to configure the default language for fenced code block markdown for the entire forum so that these display more as they did before the upgrade?
Many thanks in advance
ChatGPT samples:
Me:
It:
Me:
It:
It:
Me:
Me:
and
Me:
TIA for any guidance
Controller shift - How do you do it ?
Thanks @rafale77
I’m always conscious something’s going to fail when I do any firmware upgrade, and while I have two UZB1 sticks (one v4 the other v5) I was wondering if I could upgrade the v5 first and then copy the data over/clone from the v4 one ?
To do the latter part, I came across this zwave cloner tool in another forum, have you seen it before ?
Looks like you should be going to 5.26 and then 5.27. These are already 6.xx stack versions though.
Always upgrade bootloader before the firmware. I at times ended in a dead end and ended up having to use the linux tool to upgrades. The Z-way-server firmware upgrader doesn't always offer the "beta" versions which can be a necessary step to another official version. You can see more by inserting an "all" token but I prefer the lower level linux tool...
Note that you may need to go up all the way to do the backup/copy. You just need to get close enough in the SDK version.
Another Interesting observation - that recent bootloader upgrade has resulted in the z-wave dongle backup being reported as 4.38 rather that 4.5 when on the previous version ? -, see below extract of yesterdays and todays backups...
16383 Sep 20 19:48 dongle.4.38.dump.0 16383 Sep 19 20:37 dongle.4.5.dump.0
Next steps
touch /etc/cmh/dongle.restore.go -- on target VeraSecure scp dongle.4.38.dump.0 root@192.168.1.145:/etc/cmh/dongle.4.38.dump.0 -- on source VeraPlus
Perhaps not a surprise but the restore failed.
02 09/20/21 20:59:27.962 ZWave::Start reset 0 use45:1 minor:1 model:37 port:/dev/ttyS0 nodes:1 using_prefer: 1 prefer 0.0 ports:/dev/ttyS0 - /dev/ttyS0 <0x77ab6320> 02 09/20/21 20:59:27.963 ZWave::Start restoring dongle firmware <0x77ab6320> 03 09/20/21 20:59:27.963 JobHandler_LuaUPnP::m_bReloadCriticalOnly_set now 1 <0x77ab6320> 01 09/20/21 20:59:27.977 ZWJob_BackupDongle::FixupBufferVersion don't know version 4.38 <0x77ab6320> 01 09/20/21 20:59:27.977 ZWJob_BackupDongle::ZWJob_BackupDongle restore file invalid <0x77ab6320> 03 09/20/21 20:59:27.983 JobHandler_LuaUPnP::Reload: Dongle Restore Critical 1 m_bCriticalOnly 1 dirty data 1 running 0 <0x77ab6320> 04 09/20/21 20:59:28.319 <Job ID="1" Name="restore" Device="1" Created="2021-09-20 20:59:27" Started="2021-09-20 20:59:28" Completed="2021-09-20 20:59:28" Duration="0.354838000" Runtime="0.0" Status="Failed" LastNote="ERROR: Restore failed. Try again or contact tech support."/> <0x77ab6320>
@rafale77 - What do you recommend next on the UZB1 upgrade
I’m guessing i need to get to v6.01 ?
yep.. that's what I would do.
Any idea why the 5.7 (5.07) UZB1 firmware appears as 4.38 on Vera ?
Also what do you recommend we do next? Update the bootloader again or continue on as is just with firmware ?
What confuses me is that this link (https://z-wave.me/support/uzbrazberry-firmwares/) only goes to 5.36, no sight of 6.01?
Hold on,, I thought this was familiar - we back to where we were last year with another UZB1 I had
So unless you disagree I will follow your previous advice.
@rafale77 said in UZB/RaZberry Firmwares - Update:
I went to read the map myself and here are the steps I would take:
5.7 -> 5.7 40196 BL -> 5.27 ->5.36 ->5.39So yes Bootloader first in general but need to read the version.
You caught me there. I was probably smarter then than I am now.
My entire system has been working so well that I stopped tinkering or upgrading it save for only occasional additions or optimization of a scene here or there on openLuup. I lost a lot by not practicing.
