Hi everyone. Thanks for all your input recently on the topic of local notifications. I think we got some really interesting solutions Back to more prosaic matters. Most of you will know that I've been messing around with this stuff for some years. My last major change was when I migrated from Vera, which was something like 4-5 years ago. While my system has grown, it's not really altered very regularly, although I try to keep most of it kind of up to date. Current set up: Intel NUC that runs: Bare metal install of Debian Z-way server with Z-wave.me USB stick Openluup Altui Multi system reactor HA Bridge Mosquito Raspberry Pi Running Home Assistant About 40 varied Z-wave and Wifi devices I also have a Synology DS224+ which may inform some responses. Home Assistant recovery is pretty simple. I get a full backup of the system every night dumped onto my SAN and I know from experience that it would simply be a case of booting up a new install and feeding it the backup. The NUC on the other hand.... Coming from a commercial IT world, I am becoming more and more conscious that I don't really feel I have a suitable disaster recovery plan, and my core system is running on hardware heading for 10 years old. My initial thought, which I've kept putting off as it's awkward would be to grab a nice SSD, reboot the NUC into Mint or something similar and simply do a dd copy onto a new drive. I can get a replacement NUC on ebay simply enough, and keep it in a cupboard if anything other than the hard drive fails on the existing one, but this feels rather like a stop gap. However one immediate question: If I had to use the replacement NUC would all the Z-wave devices simply carry on talking to the stick, or would they all need to be re-paired? How easy would it be to move everything the NUC does (as a start) onto the NAS? Create a VM and clone the disc onto it? Should I move to Docker? Something else? What are the hive mind's thoughts? Apologies if we've done this before, but while it all just works... Cheers! C
67 Posts 3 Posters 35.6k Views 3 Watching
    OK that made me delete my answer but at least we know how to fire the restore!
    Where did your dump file come from, and how did you get it there?
    • parkercP Offline
      parkercP Offline
      parkerc
      It must have got there via the original restore process.
      Ok, I’ve now copied over an earlier dongle dump direct from the VeraPlus, and made that the zero/0 one.
      scp dongle.4.5.dump.4 root@192.168.1.145:/etc/cmh/dongle.4.5.dump.0
      Let’s try again
      • parkercP Offline
        parkercP Offline
        parkerc
        Hummmmm, same error..🤔
        Does it matter that this is a 4.5 dump file, and the Vera secure is on zwave version 6.1 ?
        02	09/19/21 20:42:35.508	ZWave::Start reset 0 use45:1 minor:1 model:37 port:/dev/ttyS0 nodes:1 using_prefer: 1 prefer 0.0  ports:/dev/ttyS0 - /dev/ttyS0 <0x77e96320>
        02	09/19/21 20:42:35.521	ZWave::Start restoring dongle firmware <0x77e96320>
        03	09/19/21 20:42:35.522	JobHandler_LuaUPnP::m_bReloadCriticalOnly_set now 1 <0x77e96320>
        01	09/19/21 20:42:35.549	ZWJob_BackupDongle::FixupBufferVersion not a valid 4.5 backup: 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff 0xff (<0x1b>[34;1m################<0x1b>[0m) <0x77e96320>
        01	09/19/21 20:42:35.550	ZWJob_BackupDongle::ZWJob_BackupDongle restore file invalid <0x77e96320>
        03	09/19/21 20:42:35.551	JobHandler_LuaUPnP::Reload: Dongle Restore Critical 1 m_bCriticalOnly 1 dirty data 1 running 0 <0x77e96320>
        04	09/19/21 20:42:35.735	<Job ID="1" Name="restore" Device="1" Created="2021-09-19 20:42:35" Started="2021-09-19 20:42:35" Completed="2021-09-19 20:42:35" Duration="0.212538000" Runtime="0.0" Status="Failed" LastNote="ERROR: Restore failed. Try again or contact tech support."/> <0x77e96320>
          So you're trying to shift from a Vera Plus to a Vera Secure running different zwave versions?
          I honestly have no idea if that's going to work or not. Unless you have 100s of devices I'd probably start from scratch at this point, or wait for one of the experts!
          parkercP 1 Reply Last reply
            parkercP Offline
            parkercP Offline
            parkerc
            @catmanv2 said in Controller shift - How do you do it ?:
            Yep, although I’m assuming it wouldn’t much different to someone upgrading from a vera3 or Vera lite to the newer plus or secures as they were different zwave versions..
            Why are things never as straightforward as you want them to be 🤣
              Sorry, just came back and am trying to catch up with all the posts... It looks like you manage to trigger the restore. The vera firmware is a bit idiotic in the sense that it will choose the target of the network restore as the one you have set in the UI when the vera UI starts (LuaUPnP). I don't think it works when downgrading from one stack version to a lower stack version but it does when going up. You should actually see a converted database file show up in the etc folder when it has to do a conversion. I have not tried upgrading from major versions however as my upgrades were always within stack version 6.x.
              • parkercP Offline
                parkercP Offline
                parkerc
                Hi @rafale77
                The usb dongle I have in is the VeraPlus is a UZB1 , running by the looks of it v4.05 (see attached) and the VeraSecure I’ve trying to move the zwave network too is on v6.01
                Do you think upgrading the UZB1 to v6 would help ? The zwave.me upgrade path is confusing nightmare ! 😄
                  Hahaha... yeah it does take some time to figure out. Try to get it to the same level as the vera so that it doesn't need to do a conversion.
                  • parkercP Offline
                    parkercP Offline
                    parkerc
                    Sounds like a plan, 😫
                    By any chance - do you know if there is an easier (idiots) step by step guide that can take me from v4 to v6 - rather than that spaghetti mess of a web of connections.. 😄
                      Yeah the only way I know of is for me to figure out the spaghetti for you…
                      • parkercP Offline
                        parkercP Offline
                        parkerc
                        #36
                        Thanks @rafale77
                        I’m always conscious something’s going to fail when I do any firmware upgrade, and while I have two UZB1 sticks (one v4 the other v5) I was wondering if I could upgrade the v5 first and then copy the data over/clone from the v4 one ?
                        To do the latter part, I came across this zwave cloner tool in another forum, have you seen it before ?
                        https://domotic-hobby.com/download/uzb1-cloner
                        • parkercP Offline
                          parkercP Offline
                          parkerc
                          Here's where I am on the v5 UZB1 stick
                            Looks like you should be going to 5.26 and then 5.27. These are already 6.xx stack versions though.
                            UZB/RaZberry Firmwares
                            • parkercP Offline
                              parkercP Offline
                              parkerc
                              Thanks - I upgraded that UZB1 stick as requested and it now reports it's on the latest version (does that sound right to you ?)
                              • parkercP Offline
                                parkercP Offline
                                parkerc
                                @rafale77
                                Looking at the UZB1 in the Vera, that was reporting 4.01 that is showing the following ?
                                What path is best for that one..
                                  #41
                                  Always upgrade bootloader before the firmware. I at times ended in a dead end and ended up having to use the linux tool to upgrades. The Z-way-server firmware upgrader doesn't always offer the "beta" versions which can be a necessary step to another official version. You can see more by inserting an "all" token but I prefer the lower level linux tool...
                                  Note that you may need to go up all the way to do the backup/copy. You just need to get close enough in the SDK version.
                                  • parkercP Offline
                                    parkercP Offline
                                    parkerc
                                    #42
                                    Thanks,
                                    Ok I did the bootloader update and then the 5.06 to 5.07 upgrade.
                                    I just had the new bootloader originally, but using the 'all' token it added a few more,
                                    I assume I update the bootloader again ? (even though it is dated after the other upgrades).
                                      Before you keep on upgrading, I would recommend to try the vera migration. 29304 is the bootloader I am currently on. So I am not sure what the new bootloader does. It doesn't look like I went down this upgrade path...
                                      • parkercP Offline
                                        parkercP Offline
                                        parkerc
                                        #44
                                        OK, putting the UZB1 back into the VeraPlus, it’s moved from 4.01 to 4.38 - do we think that’s enough, when the VeraSecure is reporting 6.01
                                          This is weird... It should be above 6. Not sure what this 4.38 corresponds to. It looks like you need to keep going... Or try it to see if it migrates. You never know.
                                            162.4k
