  4. Latest version (21267-a507fec) stopped working
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
11 Posts 5 Posters 1.4k Views 5 Watching
  • F Offline
    Hi Patrick @toggledbits !
    I have MSR running on my Odroid n+ (Home Assistant Blue), and always pulls the newest version of MSR in Portainer. I pull the docker: toggledbits/reactor:latest-raspbian-armv7l.
    In Portainer MSR has always had the state "Healty". But with the latest version (21267-a507fec) the state has changed to "Running". But... it's not running. When I open the web UI, I only get a error message (in swedish - since I'm living in Sweden):
    Don't know whats wrong - so I copy-pasted the log from Portainer:
    2021-09-25T09:55:00.449Z <app:INFO> Process ID 1; platform linux/arm #1 SMP PREEMPT Thu Sep 9 01:50:48 UTC 2021; locale (undefined)
    2021-09-25T09:55:00.449Z <app:INFO> Basedir /opt/reactor; data in /var/reactor/storage
    2021-09-25T09:55:00.450Z <app:INFO> NODE_PATH /opt/reactor
    2021-09-25T09:55:00.450Z <app:INFO> Configured locale [ "en-US", "UTF-8" ]
    2021-09-25T09:55:00.455Z <default:NOTICE> Unable to load locale data for en-US, trying en
    2021-09-25T09:55:00.456Z <default:WARN> Failed to load locale data for [undefined1]; reverting to system default en-US
    /opt/reactor/server/lib/i18n.js:186
        !_0x31a08d && (logger[_0x34da3b(0x9c)](_0x34da3b(0xbb)), _0x31a08d = util['loadData'](['common'], _0x34da3b(0x86), _0x3b261a)), localeData = _0x31a08d, localeData[_0x34da3b(0xed)] = localeData[_0x34da3b(0xed)] || {}, logger['debug'](0x5, _0x34da3b(0xe1), _0x31a08d[_0x34da3b(0xa4)], _0x47b224, _0x31a08d[_0x34da3b(0xc7)], _0x31a08d['format']);
    TypeError: Cannot read property 'strings' of undefined
        at Object.exports.<computed> [as loadLocale] (/opt/reactor/server/lib/i18n.js:186:197)
        at Object.<anonymous> (/opt/reactor/app.js:244:25)
        at Module._compile (internal/modules/cjs/loader.js:1068:30)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:1097:10)
        at Module.load (internal/modules/cjs/loader.js:933:32)
        at Function.Module._load (internal/modules/cjs/loader.js:774:14)
        at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:72:12)
        at internal/main/run_main_module.js:17:47
    basedir /opt/reactor
    confdir /var/reactor/config
    datadir /var/reactor/storage
    logsdir /var/reactor/logs
    plugindir /var/reactor/ext
    module.paths [ '/opt/reactor/node_modules', '/opt/node_modules', '/node_modules' ]
    2021-09-25T09:55:52.395Z <app:null> Reactor latest-21267-a507fec starting on v14.17.0
    2021-09-25T09:55:52.396Z <app:INFO> Process ID 1; platform linux/arm #1 SMP PREEMPT Thu Sep 9 01:50:48 UTC 2021; locale (undefined)
    2021-09-25T09:55:52.397Z <app:INFO> Basedir /opt/reactor; data in /var/reactor/storage
    2021-09-25T09:55:52.397Z <app:INFO> NODE_PATH /opt/reactor
    2021-09-25T09:55:52.398Z <app:INFO> Configured locale [ "en-US", "UTF-8" ]
    2021-09-25T09:55:52.402Z <default:NOTICE> Unable to load locale data for en-US, trying en
    2021-09-25T09:55:52.403Z <default:WARN> Failed to load locale data for [undefined1]; reverting to system default en-US
    I have downgraded with good results. I have both upgraded and downgraded multiple times and older versions is working - but latest doesn't. Can it be related to the new functions?
    Best regards,
    /Fanan
      I have the same problem on a bare metal Debian installation, after updating to this latest version of MSR, I am no longer able to access the MSR web GUI.
      I also reverted back to version 21258-6fb388e and MSR is running and accessible again.
        Sorry, guys. I respun the release and it's now available, 21267-f3f821b
        F CrilleC wmarcolinW 5 Replies Last reply
          @toggledbits Thanks for your swift correction! It's now working! 🙂
            @toggledbits After updating from 21243 to latest 21267, all my ezlo devices are missing the defined capabilities/entities like power_switch,dimming, motion_sensor and so on.
                @toggledbits I just checked it now and it already works, we can close the ticket.
                  • F Offline
                    I've also lost some of the available actions on my Ezlo Plus. My siren is no longer possible to turn on and off.
                      @toggledbits Great work! latest-21270-48528ec fixed all my issues.
                        Updated to 21270-48528ec MSR now loads again in the web browser (Chrome).
                        However the menu headings don't look right:
                        EDIT:
                        Restarted MSR again and now they look normal:
                          2.1k
                          3.9k
