  4. TypeError on build 21270-48528ec
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
9 Posts 3 Posters 1.2k Views 3 Watching
    Since updating I am getting flooded with these new notifications:
    Reaction task "1" failed due to an exception. Please see the log.
    TypeError: _0x19cf4f[_0x4d0fc6(...)] is not a function"
    From the log:
    2021-09-28T10:02:05.639Z <Engine:5:Engine.js:1359> _process_reaction_queue() wake-up!
    2021-09-28T10:02:05.643Z <Engine:5:Engine.js:1320> _process_reaction_queue() running task 1 { "tid": 1, "id": "rule-krq612qx:S", "rule": "rule-krq612qx", "__reaction": [RuleReaction#rule-krq612qx:S], "next_step": 3, "status": 0, "ts": 1632823320033, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise], "attempts": 2 }
    2021-09-28T10:02:05.644Z <Engine:NOTICE> Resuming reaction PS4 Waker Check<SET> (rule-krq612qx:S) from step 3
    2021-09-28T10:02:05.646Z <Engine:5:Engine.js:1421> Engine#1 reaction rule-krq612qx:S step 4 perform { "entity": "vera>device_748", "action": "x_vera_device.set_variable", "args": { "service": "urn:upnp-org:serviceId:VContainer1", "variable": "Variable1", "value": "${{ PS4PowerStatus ?? \"Unknown\" }}" } }
    2021-09-28T10:02:05.655Z <Engine:ERR> Reaction execution task 1 failed for reaction rule-krq612qx:S at step 5: TypeError: _0x19cf4f[_0x4d0fc6(...)] is not a function
    2021-09-28T10:02:05.656Z <Engine:CRIT> TypeError: _0x19cf4f[_0x4d0fc6(...)] is not a function
        at Object._0x4e8c1b [as deref] (/home/stuart/reactor/server/lib/util.js:296:91)
        at /home/stuart/reactor/server/lib/VeraController.js:1124:86
        at VeraController.performOnEntity (/home/stuart/reactor/server/lib/VeraController.js:1108:325)
        at Entity.perform (/home/stuart/reactor/server/lib/Entity.js:502:54)
        at Engine._resume_reaction (/home/stuart/reactor/server/lib/Engine.js:1426:52)
        at Engine._process_reaction_queue (/home/stuart/reactor/server/lib/Engine.js:1324:100)
    2021-09-28T10:02:05.664Z <Engine:NOTICE> Engine#1 entry 1 reaction rule-krq612qx:S: TypeError: _0x19cf4f[_0x4d0fc6(...)] is not a function
    2021-09-28T10:02:05.665Z <Engine:CRIT> TypeError: _0x19cf4f[_0x4d0fc6(...)] is not a function
    2021-09-28T10:02:05.666Z <Engine:5:Engine.js:1359> _process_reaction_queue ending with 0 in queue; none delayed/ready; waiting
    Seems to be related to my Playstation 4 PSWaker rule.
    4b0bb053-bee2-49b6-bad4-a4faa1595145-image.png 3a50cda1-fb59-46db-bc2d-97538f408905-image.png
    This is the ps4-wrapper.sh script the rule is running:
    #!/bin/sh
    while true; do
        # Run command and capture its output and exit status
        output=`ps4-waker $*`
        status=$?
        # If output was produced, stop looping.
        if [ -n "$output" ]; then
            break;
        fi
        sleep 1 # slow retries down a little
    done
    # Echo back the command output and exit with its exit status.
    echo "$output"
    exit $status
    These are the global variables, this particular rule outputs to the variable named "PS4WakerCheck".
      In the log output it says step 5.
      I think this is step 5:
      It is slightly different to the others as it using "None" rather than "Unknown" for what is to be displayed in the Vera multi-string device when no game / application is running on the PS4. This was working OK previously.
      ${{ PS4WakerParse?["running-app-name"] ?? "None" }}
      However changing this step to this instead, makes no difference I still get the TypeErrors:
      ${{ PS4WakerParse?["running-app-name"] ?? "Unknown" }}
      So its not this. but something it doesn't now like with step 5 ?
      This is the multi-string device in Vera:
        I temporarily disabled this rule by turning it off, however I am still getting lots of these errors in the notifications area.
          OK. I've got this (thanks for logs and details, really helps!). Rather than spin a build for it right now, I can give you an easy workaround... you're bare metal install right? If so...
          1. Edit the file server/lib/vera_devices.yaml
          2. You will find 3 occurrences of the word deref in that file; change that word only to expr
          3. Save the file and restart MSR.
          For general reference for others, this bug occurs when using the SetVariable action. You do not need to make these changes if you are not using that action.
          I will, of course, have this properly fixed in the next build.
            @toggledbits said in TypeError on build 21270-48528ec:
            expr
            Thanks, I think that has fixed it, not had any notifications since.
            • 3 Offline
              3 Offline
              Following - Getting the same issue, but within a Docker and don't see the vera yaml file.
              EDIT: Consoled into the docker and updated the yaml file. Restarted the docker and tested OK. Thanks.
                OK. I've updated the docker images as well.
                3 1 Reply Last reply
                  3 Offline
                  3 Offline
                  Just double checking that the deref lines should still be there after the docker update to 21270-46679ac.
                  I did run one of my rules that set variables, and there is no task error in MSR. So I'm assuming the expr change was a work around and you fixed it elsewhere?
                  • 3 3rdStng
                    @3rdstng said in TypeError on build 21270-48528ec:
                    That's correct!
                    • Next Release?
