  4. What notification system is best?
(I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
16 Posts 9 Posters 4.0k Views 9 Watching
    I use Pushover. I'm a fan. I've never missed a message. I additionally use email, as my wife is a hawk for her email accounts and give me good assurance that if Pushover ever misses, a SpouseNet notification is not far behind.
    • A Andr
      Hi everyone
      I'm about to set up notifications from MSR and would like input on what works best.
      Quick and reliable delivery to Android devices is the goal.
      (Tried to set up pushover last night, but probably missed something because it doesn't work. Succeed thru homeassistant, but not with MSR.)
      Is pushover worth its money?
      what do you use and why?
      Greatly appreciate your thoughts 🙂
      @andr Telegram. No regrets
        Telegram here as well. I’ve deeply customized with a bot, pushing videos from my cams and accepting commands with wizards as well.
          Andr
          @therealdb said in What notification system is best?:
          Do you mean a "chatbot" that you can respond to? That sounds cool, could you give som example of what you use it for?
          Right now I struggle with Pushover. Can't find out why it doesn't work.😖
          From reactor.log:
          default:null Module NotifyPushover v21195
          Engine:ERR Engine#1 reaction re-kud4t99t step 0 notification (Pushover) failed: Error: Pushover user and token could not be determined
          From notification.yaml
            # Pushover
            Pushover:
              profiles:
                default:
                  description: Andre
                  # user - (required) user key from Pushover. Refer to the Reactor docs for
                  #        the Notify action for info on how to get your user key.
                  #user: u4cXXXXXXXXXXXXXXXXXXXXXtkv1d
                  # token - (required) token from Pushover site. Again, see the Reactor docs
                  #         for info. This is the default token used for this profile if a
                  #         token is not specified in the notification parameters.
                  #token: amwXXXXXXXXXXXXXXXXXXXXXn7if
                  # default_device - (optional) name of the default device to receive not-
                  #                  ifications. You can leave this blank, and the default
                  #                  device will be whatever the Pushover API determines. If
                  #                  set here, it's the default for this profile, when no
                  #                  device is specified in the Notify action itself.
                  #default_device: ""
                  # default_title - (optional) default notification title to use for this
                  #                 profile. It will be used when no title is specified in
                  #                 the Notify action. If no title is specified at all, the
                  #                 system default title "Reactor" will be used.
                  #default_title: "Reactor Notification"
          The Reaction
          I have tried to put user id & token between citation marks " "
          Same user id & token work from pushover site and when sending notification from Homeassistant.
          • A Andr
            From reactor.log:
              # Pushover
              Pushover:
                profiles:
                  default:
                    description: Andre
                    #default_device: ""
            The Reaction
            CrilleC Online
            CrilleC Online
            @andr Remove the “#” in front of user id and token
              Andr
              @crille
              THANKS!!🙏🏼
              Now Pushover works.
              Time to take a look at that Telegrambot 🙂
              • CrilleC Online
                CrilleC Online
                I use pushover for all my notifications and have been doing so since 2013. A really good and stable service. Started using it before it became a subscription service so was upgraded to “free for life” when they introduced that.
                Telegram is looking very interesting though 🙂
                Edit: I see it’s a one-time fee per platform now, not a subscription.
                  Andr
                  @crille
                  Yes, 5usd per platform. Not much to discuss if it is a good service.
                  Will use the 30-day trial period for now to test it.
                  But the telegram bot seems intresting, I got it up and running but i dont think i can manage to make good use of it.
                  Me: Hey bot, heat up my car so its ready 07:45
                  Bot: After consulting with MSR i found the outside temperature is -5 degrees, so I start the heater at 07:00.
                  Thanks everyone for your thoughts, very helpful!
                  • wmarcolinW Offline
                    Telegram 🙂
                    • A Andr
                      @crille
                      @andr interactive bot might be a bit too much for starters, but Telegram is excellent in providing different status messages set up in MSR
                        The chat bot is used to control lights and run scenes, if necessary. I’m still on my Vera but it’s decoupled, so this is the only way to interact when outside the house.
                        I’ve also integrated my ECOVAC deebots, and opensprinkler. But we’re mainly using it to open doors and garage doors, since everything else is automated and we rarely mess with this stuff. But it was fun. It’s not parsing natural language, but it’s doable (part of my job is dedicated to this stuff, so this was a sort of research project for me back in the days).
                        PablaP 1 Reply Last reply
                          Dipped my toe with Prowl, saw Pushover and haven't looked back. I like the ability to "personalize" the notifications both textually and audibly.
                            Telegram. Zero maintenance.
                              This chat bot sounds interesting, if I am reading this correctly in the Telegram group chat you can basically tell the bot to do certain things that are preconfigured?
                                @pabla yep. It’s not a product, but very specific to my needs, so I’ve not released it. I’ll see if I could post some screenshot to be of inspiration to others. AFAIK home assistant has something like this built in (or, maybe, it’s open hab)
                                  164.6k
