  4. Is there a search function (maybe a feature request)
2 Posts 2 Posters 402 Views 2 Watching
    Patrick,
    I've just imported a large set of rules from Vera, and I had already played with creating rules in MSR that are mixed throughout the existing Vera rules. Is there any sort of way to "find/replace" in MSR, so I can find all matches to the old rules and replace them with the new ones?
      I was asking for the same feature, but an easy thing in the meantime is to just get the storage folder, open it with VS Code and use "Find in files". It will help you to get the old entities and you'd even replace them with new ones. Just stop Reactor, edit/save the files, and copy them again. Be 100% sure to spell the device names correctly, or you'll break things. Be sure to have backups as well and good luck!
        160.0k
