  4. Migration of House Modes
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
5 Posts 3 Posters 1.4k Views 3 Watching
    Patrick,
    Yesterday I migrated a large luup Reactor group over from Vera to MSR, following the directions to importing it from Vera in the documentation. One of the odd things in the migration was the conditional rules for House Modes. Many of my rules had conditions such as "House Mode is any of Home, Night, or changes to Away.
    The way the import did it was changes from 1,3 to null. This importation did not seem to trigger rules correctly.
    I was able to fix all the instances by creating multiple triggers in a group:
    Entity Attribute: House Mode (vera>housemode) x_vera_housemode.mode contains home
    OR Entity Attribute: House Mode (vera>housemode) x_vera_housemode.mode contains night
    Is this what you are expecting in importation?
      No, probably a bug. I'll look into it, although, you're the first person that I'm aware of to use the importer in over a year...
        Okay, sounds good. Let me know if there are any logs or anything you need from me.
          Overall, it worked pretty well. A few oddities, but better than recreating my whole ruleset!
            I had this same issue when I imported my Vera Reactor rules earlier this month
              164.0k
