  4. [CONFIRMED] Upcoming HubitatController z-wave polling feature
Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
5 Posts 2 Posters 1.7k Views 2 Watching
  • 3 Offline
    3 Offline
    Super excited to see in the upcoming release notes about MSR being able to poll HE z-wave devices. I've attempted to use the native HE poller and in less than an hour after installing it, I was removing it. I only have a small number of devices that give me trouble, but I wanted to verify that I'm pre-building my YAML file correctly.
    poll_frequency: 60000  # poll a device at most every 60000ms (60 seconds)
    poll_entities:
         - id: 110  # Hallway Light
           interval: 300  # 300 seconds = 5 minutes
         - id: 111  # Kitchen Light
           interval: 900  # 900 seconds = 15 minutes
         - id: 112  # Disco Light
         - id: 113  # Ballroom Light
    Am I correct in my thoughts? Based on the above snippet, the default polling will be every minute for the Disco and Ballroom lights? But because the Kitchen and Hallway light have a defined interval, they will be polled at those intervals instead? Or does there need to be an "interval:" definition following every id:?
      The Disco Light and Ballroom Light will be polled at the default interval of 10 minutes (600 seconds). You only need to specify an interval if you want something other than this default.
      The poll_frequency is not a default for the polling interval. The poll_frequency instead is the minimum time between device polls that the poller is allowed, to limit its ability to saturate your Z-Wave mesh. At the default frequency of 60000 (milliseconds = 60 seconds = 1 minute), one device per minute will be polled, regardless of how many devices are due to be polled. In effect, the interval becomes the minimum time between polls of a single device, and the actual interval depends on how busy the poller becomes. If you have a large number of devices being polled, or are polled frequently, then it's possible that polling will, at least for some devices, become chronically late. The next device to be polled is always the tardiest (i.e. the one that has been waiting longest), so every one will get polled.
      • 3 Offline
        3 Offline
        Thank you. So if I have 10 devices, all with the interval set at 60 seconds, essentially it will poll one device at minute 1, the second device at minute 2.
        In other words, one device polled per minute, or based on the poll frequency.
        If I'm understanding this correctly, I'm better off upgrading my z-wave to z-wave plus devices and only poll those that are critical, and not upgraded, yet.
        • 3 3rdStng
          @3rdstng I think that's right. If an automation relies on the crisp response of a device that doesn't have it, polling is a poor solution and the device should be replaced.
          A counter-example from my own home, though... I have a few old switches and dimmers controlling a guest bathroom in our basement, policing that neither the fan nor light are left on unsupervised for hours at a time. It's sufficient (in my view) to poll every 10 minutes, and the time delay of the auto-off automation is OK being delayed that much. As long as the lights aren't on for hours (or days) unoccupied, I'm satisfied.
          3 1 Reply Last reply
            3 Offline
            3 Offline
            @toggledbits said in Upcoming HubitatController z-wave polling feature:
            It is correct. My polling config left the default frequency at 60000ms (1 minute) and I did not include the interval settings on my devices, of which I am polling 3 until I can get around to replacing them. Upon reactor startup, the first device in the list is polled, one minute later the second device, another minute later, the third device. Seven minutes from there, or ten minutes from the initial poll, device 1 is polled again.
            Thank you @toggledbits for adding this feature.
              164.2k
