  4. Can a rule be used to disable other rules?
6 Posts 5 Posters 1.4k Views 5 Watching
  • B Offline
    B Offline
    basai
    Howdy,
    My goal is to have a rule that when triggered will disable other certain pre-defined rule sets, but I can't seem to find a way to do it in MSR. Is it possible?
    In the MSR UI, rule sets are toggled manually to be enabled (green) and disabled (red). I would like to do this from within a rule.
    Running MSR version latest-22274-24dfd72c
    TIA,
    -bh
    PablaP therealdbT 2 Replies Last reply
    • B basai
      Howdy,
      TIA,
      -bh
      @basai to my knowledge that isn’t possible at the moment. However you could work out a way around this, post your rules and actions and let’s see.
      • B basai
        Howdy,
        TIA,
        -bh
        @basai that's achievable with a global variable, that you'll use as a constraint to prevent the execution of your rulesets.
        That's what I'm doing with party, mute or winter variables, used to prevent rules from running under certain circumstances.
          You could also just use another rule, tested by a Rule State condition, or a virtual switch or binary sensor, etc.
          • B Offline
            B Offline
            basai
            Thank you all for your responses, you are an awesome bunch in this group and I have what I was looking for.
            Essentially toggling a rule as active or inactive can only be done manually, so I wasn't going crazy because this was something I could do in the Vera Reactor to another Reactor 🙂
            I have been using toggles in HAAS to toggle a state which I include as a 'constraint' within multiple MSR rules which works.
            What I was looking for is more of a 'kill switch’ to completely disable a rule or set of rules for reasons that come up from time to time where I manually disable them so there is no chance of them running. Not a show stopper by any means.
            Thanks again,
            -b
            • B basai
              Thanks again,
              -b
              @basai My approach to this has been to set a rule to determine a "thing" or "state". I then "turn on/off" other rules by looking at the status of that rule.
              Example:
              Ruleset: is temp below 40º? True for <40º, False for >40º
              Ruleset: do this thing if ruleset "is temp below 40º" is true (or false.)
                160.0k
