  4. Need assistance in combining rules to use the reset reaction
Edit: Fixed in re-spun 26328. (I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
reset reaction
6 Posts 4 Posters 1.4k Views 4 Watching
    Patrick, I'm sorry if I'm bringing up something that has likely already been posted, but I'm just not finding it i the forum. Probably not using the right combination of keywords.
    My rules are for the most part all migrated from luup Reactor on Vera, and are pretty much still written as such. I have numerous rules to turn on and off lights, and they were influenced by a video you posted on how to do it 3 or 4 years ago. In essence, there is a rule to turn on the lights when there is motion, and then another rule to turn the lights off after there is no motion for a specified period of time.
    With the introduction of the reset reaction, is there a more elegant way to do this in one rule? This would have a great effect of cleaning up my rule base by simplifying and reducing the number of rules.
    Example On rule:
    Corresponding Off rule:
    Running reactor-latest-22293
    Home Assistant 2022.10.4
    HAAS OS 9.2
      The Reset reaction is analogous to the "is FALSE" activities in Reactor for Vera, and would be used the same way. They have the same applications and side-effects (e.g. preempting of contra-actions, etc.).
      In practice, I have very few Reset reactions in my rules. Usually my "off" conditions are a good bit more complex than my "on" conditions, including different condition options/delays and constraints, and this all lends itself to separate rules, per the other discussion. I have so few, in fact, that I can't even think of where I might have used one.
        Okay, thanks for the insight. Just thought I would ask if there might be a better way of doing things
          @toggledbits this is a timely response as I'm investigating an issue with ONE SINGLE BLIND resetting itself at exactly 00:01:50 each night. My current belief is that it's in response to a gap somewhere letting a reset reaction be incorrectly utilized. I may review places where I'm using reset reactions based on this response.
            Remember that the log file logs all entity actions performed on all devices, so if you are looking for activity around a specific device, search the log file for its ID. Then examine the entries before it and you may see what rule/reaction is running, to more quickly lead you to the point.
              You could in your reset action add a delay then have the light turn off after said delay. But if you want the light to turn off specifically when there is exclusively no motion detected, you can add a group in your reset reaction like the screenshot below and it will only turn off the light if there is no motion detected. @toggledbits can confirm if that is the correct approach.
                165.8k
