  4. Interface Adjustment!
4 Posts 2 Posters 1.1k Views 2 Watching
  • wmarcolinW Offline
    Hi @toggledbits
    I see that you have been making several adjustments in the interface, and I already have some time to comment on this situation. Below are two examples where the first selectors are cut, because the data field is big.
    In my opinion, the selectors should have their size preserved, and the fields with data then should be compacted to the limit of the line.
      Got 'em.
      wmarcolinW 1 Reply Last reply
        Got 'em.
        Solved!
        • wmarcolinW wmarcolin
          Solved!
          @wmarcolin noice!
