  4. [MSR] reactor-mqtt-contrib package for additional MQTT templates
Edit: Fixed in re-spun 26328. (I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
46 Posts 4 Posters 22.4k Views 4 Watching
    I believe @toggledbits has it (unsurprisingly)
      Yes, your configuration of prefix and topic don't make a string that matches what is being received. Based on what it is coming in and how those fields template configuration are used, prefix should be msrmqtt and topic should be just iphone8.
      Conspicuous give-away: your test_iphone value doesn't appear in the topic or payload of what you're receiving.
      @therealdb this may need a bit more documentation, since the relevance of prefix and topic aren't immediately clear (at least, not to me) without looking at the template itself and seeing how they are used, and likely the phone configuration as well (i.e. describe how configuration fields on the phone may appear in the final event topic).
      @toggledbits I was just updating prefix when your response came in. Here's where I am now:
            entities:
              owntracks_iphone8: #entity ID - must be unique
                name: "iPhone8 location" # friendly name
                prefix: "msrmqtt"
                topic: "iphone8"
                uses_template: "owntracks_sensor"
                homeRegionName: "Home"
      My template is in reactor/config/mqtt_templates which is where @therealdb directs. Do I need to modify the uses_template:?
        I think the template is in the correct place. Let's see what happens when you restart Reactor
          @gwp1 Are you getting an error that the template owntracks_sensor doesn't exist?
            @toggledbits I am not receiving any errors.
            Just not seeing anything populate the entity.
            Is it something to do with the entity name by any random chance?
              @gwp1 said in [MSR] reactor-mqtt-contrib package for additional MQTT templates:
              Then there's nothing wrong with uses_template.
              I'll make the same comment/question to you that I made to @CatmanV2 earlier in this same thread: you're on the latest MQTTController, right?
                @toggledbits MQTTController-22326 (double-checked the CHANGELOG.md)
                EDIT: ...which I now see is a version behind. You snuck one in on me. Updating to MQTTController-22340.
                EDIT2: Nailed it.
                G CatmanV2C 2 Replies Last reply
                  EDIT2: Nailed it.
                  @toggledbits @therealdb @CatmanV2 Thank you all for your help here, this is a big step in my system. Really appreciate it!
                    @therealdb what are your updates set to on the iPhone app? The data is going to be useful, but on 'Significant' I appear to be only getting updates on
                    string and region which makes sense.
                    I'm assuming that battery_power.level won't update more frequently unless the app is configured to 'Move'
                    Has anyone done that? Does it kill the iPhone battery?
                    Cheers
                      EDIT2: Nailed it.
                      @gwp1 how did you get the Driving Flag?
                      Cheers
                        Cheers
                        @catmanv2 move translates to any movement your phone is making - increases accuracy but kills battery life. significant is defined by OwnTracks as "traveling a distance of at least 500 meters in 5 minutes" which lets the app nap and is much easier on the battery.
                        Driving Flag is a virtual switch I created based on distance from Home. I believe I currently have it set to .1 mile so it trips as soon as I pull out of the neighborhood. I use it as a safety to the GPS reporting for when I'm not home. I have a second one called Driving Flag - Far Away that kicks in at two miles. This is for use when I'm obviously not just puttering about the neighborhood but going to be gone while. Can be used to trigger HVAC, etc.
                          Cool, ta
                            @toggledbits said in [MSR] reactor-mqtt-contrib package for additional MQTT templates:
                            It’s in the readme. Maybe, when you’ll build an UI, we could provide descriptive text for parameters.
                              #34
                              Version 22350 released.
                              What's new:
                              • shelly_button1: for Shelly Button 1 (battery powered button) - all the button modes (short, long, double, triple) are supported.
                              • fullykiosk: to handle messages coming from FullyKiosk. You'll have battery and charging status, screen brightness and current app.
                              What's fixed:
                              • query for all shelly template
                              • owntracks: trying to better handle null values/spurious messages.
                              How to update: just replace the files and restart Reactor.
                              G 2 Replies Last reply
                                What's new:
                                What's fixed:
                                @therealdb I grabbed the latest owntracks_sensor and dropped it on top of the existing. (Yes, being late and I'm exhausted I failed to backup the original template.)
                                        owntracks_iphone14p: #entity ID - must be unique
                                          name: "iPhone14p J2A" # friendly name
                                          prefix: "msrmqtt"
                                          topic: "iphone14p-j2a"
                                          prefix: "msrmqtt"
                                          topic: "iphone8-j2a"
                                        owntracks_iphone14jay: #entity ID - must be unique
                                          name: "iPhone14max Jay" # friendly name
                                          prefix: "msrmqtt"
                                          topic: "iphone14max-jay"
                                          homeRegionName: "CoralBerry"
                                        owntracks_iphone14jen: #entity ID - must be unique
                                          name: "iPhone14 Jen" # friendly name
                                          prefix: "msrmqtt"
                                          topic: "iphone14-jen"
                                        owntracks_iphone14addie: #entity ID - must be unique
                                          name: "iPhone14 Addie" # friendly name
                                          prefix: "msrmqtt"
                                          topic: "iphone14-addie"
                                        owntracks_iphone14bella: #entity ID - must be unique
                                          name: "iPhone14 Bella" # friendly name
                                          prefix: "msrmqtt"
                                          topic: "iphone14-bella"
                                That's my config... and this is my log since replacing/restarting:
                                     ... le" content="{&quot;groups&quot;: [], &quot;environmentKey&quot; ...
                                [latest-22349]2022-12-19T04:51:40.735Z <MQTTController:CRIT> YAMLException: end of the stream or a document separator is expected at line 21, column 66:
                                    at generateError (/home/reactor/Documents/reactor/node_modules/js-yaml/lib/js-yaml/loader.js:167:10)
                                    at throwError (/home/reactor/Documents/reactor/node_modules/js-yaml/lib/js-yaml/loader.js:173:9)
                                    at readDocument (/home/reactor/Documents/reactor/node_modules/js-yaml/lib/js-yaml/loader.js:1545:5)
                                    at loadDocuments (/home/reactor/Documents/reactor/node_modules/js-yaml/lib/js-yaml/loader.js:1588:5)
                                    at load (/home/reactor/Documents/reactor/node_modules/js-yaml/lib/js-yaml/loader.js:1614:19)
                                    at Object.safeLoad (/home/reactor/Documents/reactor/node_modules/js-yaml/lib/js-yaml/loader.js:1637:10)
                                    at MQTTController._load_implementation (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:753:38)
                                    at async MQTTController.start (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:81:13)
                                [latest-22349]2022-12-19T04:51:40.744Z <MQTTController:ERR> MQTTController#mqtt2 can't read/load templates from /home/reactor/Documents/reactor/config/mqtt_templates/owntracks_sensor.yaml: [YAMLException] end of the stream or a document separator is expected at line 21, column 66:
                                [latest-22349]2022-12-19T04:51:40.754Z <MQTTController:CRIT> YAMLException: end of the stream or a document separator is expected at line 21, column 66:
                                [latest-22349]2022-12-19T04:51:40.759Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.1.198:8123/api/websocket
                                [latest-22349]2022-12-19T04:51:40.766Z <MQTTController:INFO> MQTTController#mqtt instance topic ident is mqtt
                                [latest-22349]2022-12-19T04:51:40.767Z <Controller:INFO> MQTTController#mqtt 0 dead entities older than 86400000s purged
                                [latest-22349]2022-12-19T04:51:40.769Z <MQTTController:NOTICE> MQTTController#mqtt connecting to broker at mqtt://192.168.1.198:1883/
                                [latest-22349]2022-12-19T04:51:40.843Z <MQTTController:INFO> MQTTController#mqtt2 instance topic ident is mqtt2
                                [latest-22349]2022-12-19T04:51:40.844Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14p uses_template=owntracks_sensor, template not defined
                                [latest-22349]2022-12-19T04:51:40.853Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone8 uses_template=owntracks_sensor, template not defined
                                [latest-22349]2022-12-19T04:51:40.890Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jay uses_template=owntracks_sensor, template not defined
                                [latest-22349]2022-12-19T04:51:40.901Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jen uses_template=owntracks_sensor, template not defined
                                [latest-22349]2022-12-19T04:51:40.914Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14addie uses_template=owntracks_sensor, template not defined
                                [latest-22349]2022-12-19T04:51:40.923Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14bella uses_template=owntracks_sensor, template not defined
                                [latest-22349]2022-12-19T04:51:40.944Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14addie no longer available, marking BinarySensor#mqtt2>owntracks_iphone14addie for removal
                                [latest-22349]2022-12-19T04:51:40.952Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14bella no longer available, marking BinarySensor#mqtt2>owntracks_iphone14bella for removal
                                [latest-22349]2022-12-19T04:51:40.960Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jay no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jay for removal
                                [latest-22349]2022-12-19T04:51:40.967Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jen no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jen for removal
                                [latest-22349]2022-12-19T04:51:40.974Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14p no longer available, marking BinarySensor#mqtt2>owntracks_iphone14p for removal
                                [latest-22349]2022-12-19T04:51:40.980Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone8 no longer available, marking BinarySensor#mqtt2>owntracks_iphone8 for removal
                                [latest-22349]2022-12-19T04:51:40.987Z <Controller:INFO> MQTTController#mqtt2 0 dead entities older than 86400000s purged
                                [latest-22349]2022-12-19T04:51:40.988Z <MQTTController:NOTICE> MQTTController#mqtt2 connecting to broker at mqtts://7ef71f0117fe40d28c2df12205c4a0d0.s2.eu.hivemq.cloud:8883
                                  What's new:
                                  What's fixed:
                                  @therealdb Stand down - I refetched the template file and replaced and everything is fine.
                                  Bad download, perhaps?
                                    Maybe. I'll start packing them in zip files very soon, since MQTTController has the ability to get them from a compressed zip file. I'll do a proper release and things should be easier going on.
                                      @therealdb Many thanks to you and @toggledbits for the combined efforts on this specific app.
                                      I've convinced a friend to join us here in the world of MSR. I'd originally written up a reactor.yaml that included his Hubitat and VeraSecure controllers so he could just drop it in and go. I updated that file with multiple entities for each member of his family, had him install MQTTController, and drop the updated version of the config file into his MSR.
                                      Created an accompanying install doc for the iOS app customized to their setup and it's working brilliantly. His phone is connected to my HiveMQ cluster which connects his household and mine together so we can do shared presence automations across homes.
                                      Love this stuff!
                                      EDIT: took it a step further and offloaded my OwnTracks config file, edited a couple details (UserID, etc) and sent it to all members of his family. He added it to OwnTracks and everyone is identical in setup as far as Regions goes and everything is working smashingly.
                                      STILL love this stuff 😉
                                        #39
                                        I've pushed a new version of my templates, with small fixes everywhere, plus notHomeRegionName to configure the "not home" state (ie: be consistent with Home Assistant, that's using "not_home", if you want) and better handling in general of events. Thanks to @CatmanV2 for the samples!
                                          I've just updated a bunch of templates, and added:
                                          • shelly_relay_simple: you know, a simple template for a shelly relay
                                          • shelly_scenecontroller: to map Shellies as scene controllers/buttons
                                          • shelly_uni_adc: to map Shelly Uni's capabilities to measure ADC.
                                          GitHub - dbochicchio/reactor-mqtt-contrib: Contrib MQTT templates for Reactor
                                            165.6k
