  4. Disabled groups in reactions
5 Posts 2 Posters 1.7k Views 2 Watching
    MSR tooltip says that "disabled groups are ignored, as if they did not exist (conditions don't run)".
    Just want to clarify if it's by design that actions beneath disabled groups should run? They do run, but intuitively I was expecting them to be disabled as well.
    Running the latest build under Docker.
      @toggledbits can you comment?
        Screen shots are nice.
          I’ll take those shots, although not sure how relevant they are in this case. I’m just asking how disabled groups in reactions should work
          a) only group conditions are disabled (this is now the case - not sure if intended)
          b) also actions in/beneath these groups are disabled (was expecting this behaviour)
            It's A, not B. This is consistent with the use of condition groups elsewhere, like in rule triggers and, most specifically, constraints (conditions on a group are constraints).
