  4. Having an Echo device play mp3?
Scheduled Pinned Locked Moved Unsolved Multi-System Reactor
2 Posts 2 Posters 797 Views 2 Watching
  • F Offline
    Hi!
    I tried to find an answer in both the forum and by myself, without any luck. I'm trying to make my Echo device play a mp3 file. The same mp3 file is easy to play with other smart speakers (Sonos, Google/Nest) - that it no problem. Same approch do not work with Echo devices. The mp3 files I want to use is located on my HA installation (config/www/audio), running on ver. 2023.5.4. I have MSR ver 23114.
    Is there a way to do this easily?
    /Fanan
      Does the Echo media player entity in HA support playback of local files? If so you may just need to add the capability for the echo device in your reactor config file. See here in docs to do so
        160.0k
