reactor.yaml:
trusted_proxy: "192.168.1.12"
users.yaml:
- url: "/api/v1/log"
method: "GET"
source_ip: 172.18.0.0/24
allow: true
x_hass.domain="fan"
x_hass.source="esphome"
x_hass_attr.percentage=50
x_hass_attr.preset_mode=""
x_hass_attr.preset_modes=[]
primary_attribute_value: |
d = false;
d
Edit: Solved in latest-26221.
Bare-metal latest-26193
I have this group:
"OKforLarm":
name: OK för Larm
- include_controller: vera
Ezlo Secure - Onboard Siren not appearing in MSR
Posters
701
Views
Watching
Hi, I just got a new Ezlo Secure controller hub and it has an onboard siren.
I managed to connect the Ezlo Secure to MSR fine, but the siren device does not appear in Entities.
It's not mission critical, I just wanted to have a play about with it in some rules etc.
Looking in their Online API Tool for the siren device it has these properties.
DEVICE -
method: "hub.devices.list" result: devices: 0: _id: "63498f45c9efbc171a2ad4c1" batteryPowered: false category: "siren" deviceTypeId: "e550_siren" gatewayId: "63498f45000000171a2ad4c0" info: Object {} name: "Controller Siren" parentDeviceId: "" persistent: true reachable: true ready: true roomId: "" security: "high" status: "idle" subcategory: "" type: "siren"ITEMS -
method: "hub.items.list" result: items: 0: _id: "63498f45c9efbc171a2ad4c2" deviceId: "63498f45c9efbc171a2ad4c1" hasGetter: true hasSetter: true name: "sound_select" show: true value: 1 valueFormatted: "1" valueType: "int" 1: _id: "63498f45c9efbc171a2ad4c3" deviceId: "63498f45c9efbc171a2ad4c1" hasGetter: true hasSetter: true name: "switch" show: true value: false valueFormatted: "false" valueType: "bool" 2: _id: "63498f45c9efbc171a2ad4c4" deviceId: "63498f45c9efbc171a2ad4c1" hasGetter: true hasSetter: true name: "sound_volume" show: true value: 100 valueFormatted: "100" valueType: "int" 3: _id: "63498f45c9efbc171a2ad4c5" deviceId: "63498f45c9efbc171a2ad4c1" elementType: "sound_info" hasGetter: true hasSetter: false name: "sound_list" show: true value: Object {"1":{"duration":5,"name":"Default Siren"}} valueFormatted: "" valueType: "dictionary"Thanks
