  4. Is this possible? Store data from Asus Router ajax .asp page for Temperature data.
Edit: Fixed in re-spun 26328. (I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
77 Posts 3 Posters 42.5k Views 2 Watching
    Perfect thank you !
    I might even create a virtual device (multi-string plugin) on Vera and have MSR send these values to that also, so I can also have a tile in our Home Remote dashboard app showing this data.
      You can wrap that in a round() if you only want one decimal (for example)...
      round( int( RouterCPUTemp ) / 1000, 1 )
      cw-kidC 2 Replies Last reply
        #23
        @toggledbits said in Is this possible? Store data from Asus Router ajax .asp page for Temperature data.:
        Even better, you have made my day! Thank you.
        I have been worrying about my router getting too hot, now I will know if it does.
            Well that works ! Quickly added a custom tile in Home Remote dashboard
            And this is the Multi-String device in Vera.
            Think I can pull other temps off the router also, like the WIFI chips.
              Maybe I should also add a timeout to the ssh commands ?
              ssh -o ConnectTimeout=10 -i ~/.ssh/id_rsa admin@192.168.0.1 'cat /sys/class/thermal/thermal_zone0/temp'
                #27
                Think I just found a bug? try naming a local expression as "2.4GTempRaw" without the quotes in a rule and see what happens. I am stuck and cannot delete the expression or exist the rule. Had to refresh the browser to recover. Should of known not to put a dot in the name LOL.
                I might have just corrupted the rule now I cannot add an expression named "24GTempRaw"
                Or maybe its the numbers it doesn't like.
                OK that's better.
                  You can do Wifi chip temps as well! Wonder what other commands I can send to get data back..
                    #29
                    This is much more powerful than I imagined. Seems you can send any old linux command like "free" to see the memory usage. I haven't figured out how to extract and parse just a part of the returned data yet though, say just the "Used" memory value.
                    (string) " total used free shared buffers cached\nMem: 426020 303308 122712 3404 0 39212\n-/+ buffers/cache: 264096 161924\nSwap: 0 0 0\n"
                    "303308" is the used memory value, no idea how to extract just that part of the data to another local expression though as its not formatted like JSON data would be.
                    • cw-kidC cw-kid
                      #30
                      @cw-kid you're going to have to learn "regular expressions", which are patterns that can be matched in strings. It's another rabbit hole to go down, but here's a specific solution you might build on. Using your response string:
                      The match() function (refer to the docs) will match a pattern to a string. In this case, the pattern contains "regular expression groups", which are the parentheses and their contents. These groups contain \d+ patterns (you have to specify them as \\d+ as shown because of string escaping in the language)... the \d pattern matches a single digit 0-9, and the modifier + after it tells it to match one or more occurrences — so each \\d+ matches a number made of one or more consecutive digits. So this whole pattern basically finds the word Mem: in the string, then from there finds the six numbers that follow. The 3 in the last argument tells match() to return only the third matched item, which is the number 122712, the amount of free space (it's third in place in the string of numbers based on the header line above it).
                      You can Google around to find regular expression tutorials.
                        #31
                        Thanks I will take a look at the pattern matching.
                        I realised I need a Global Expression, for my second rule to trigger from. As I cannot use a local expression that is in one rule as a trigger in a different rule etc.
                        My second rule will be the one that triggers if the CPU Temp value is greater than 80 and it will notify me by repeated TTS announcements etc.
                        So I created two new Global Expressions.
                        The first rule I setup that gets the CPU Temp via the ssh command, now also sends that raw response value to the Global variable as well, that is named "RouterCPUTempRaw" that works fine OK.
                        However my second Global variable called "RouterCPUTemp" that changes it to "int" doesn't seem to evaluate.
                        When should it evaluate ?
                        If I restart MSR then it evaluates then and updates correctly.
                        Maybe? its because to test it and force the value to be 81 I sent in this URL to MSR.
                        http://192.168.1.40:8111/api/v1/variable/RouterCPUTempRaw/set?value=81495
                        EDIT: I guess as a work around I could delete the "RouterCPUTemp" global variable and just have my second rule trigger if the value in "RouterCPUTempRaw" global variable is greater than 80000
                        EDIT2: I just did that and that seems to work OK instead.
                          #32
                          I tried the pattern match in a new test rule, I think I did it correctly but I am just getting null in the expression for some reason.
                          I don't get any alerts or errors in the notifications area either.
                            Local expressions are only evaluated when the parent rule is evaluated. The changing of the rawResponse local variable does not cause an evaluation of the other variables. These would need to be global.
                              @toggledbits OK thanks I will change them to global variables and a see.
                              My comment before the last one, both of those expressions were global, yet one of them didn't seem to be evaluating and I wasn't sure why..
                                #35
                                OK I changed all three expressions to be global ones instead.
                                I waited a while, but a similar thing as yet they have not been evaluated.
                                I then press Play on them but still nothing.
                                I then ran the action in the rule that pulls down the Free Memory data, but they still say (has not been evaluated)
                                Edit: I am on build, latest-23196-40ef07f4, just checked I am up to date it seems.
                                Restarting MSR also doesn't help. I don't understand why these global variables don't seem to be evaluating.
                                  #36
                                  Not showing enough work here. What sets RouterMemoryRaw? Need details
                                  Edit: also, did you hard refresh after restarting MSR?
                                    A rule that I just set to run every hour.
                                    Yes I did.
                                    Its been several days and these global expression still say (has not been evaluated)
                                      Works fine for me. Restart MSR if you have not, and hard refresh. They will be evaluated at restart. If they still show not evaluated, you need to dig deeper.
                                        Just tried that and still not evaluated. I did look in the log but couldn't see anything obvious that stuck out.
                                          I just deleted all 3 Global Expressions and recreated them, then restarted MSR and they still don't evaluate.
                                            165.3k
