  4. Virtual Entities (value or string) can auto update based on a Global variables?
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
8 Posts 2 Posters 1.8k Views 2 Watching
  • N Offline
    N Offline
    Hi, I tried with my skills and no luck, so I want understand if it is possible.
    if I create a Global variable, for example to have a Thom Index value
    xB1_Thom_Index_ID = round( float( xB1_Temp_01_ID ) - (0.55-0.0055 *  float( xB1_Humidity_01_ID )) * ( float( xB1_Temp_01_ID ) - 14.5) , 1)
    and then I create a Virtual Entity that show the updated value also on the dashboard every time xB1_Thom_Index_ID changes
    seems that this is not the right way
              name: TestA Dynamic Vec Value
              capabilities:
                value_sensor:
                  attributes:
                    value:
                      expr: xB1_Thom_Index_ID
    nothing
              capabilities:
                value_sensor:
                  attributes:
                    value:
                      expr: round( float( xB1_Temp_01_ID ) - (0.55-0.0055 *  float( xB1_Humidity_01_ID )) * ( float( xB1_Temp_01_ID ) - 14.5) , 1)
    I get the value updated only when MSR restart. Is this way totally wrong?
    -Docker on Synology NAS
    -HASS Docker 2026.8.1
    -ZWaveJS-UI 11.22.3
    -Update 16/08/2026
    • N noelab
                capabilities:
                  value_sensor:
                    attributes:
                      value:
      nothing
                capabilities:
                  value_sensor:
                    attributes:
                      value:
      @noelab said in Virtual Entities (value or string) can auto update based on a Global variables?:
      That actually is the right way. You may have found a bug. I'd like to see the rest of the expressions involved, though. I need to see all of the global variables mentioned in your expression (and any they mention).
      N 1 Reply Last reply
        N Offline
        N Offline
        Reactor (Multi-hub) latest-23338-170ea0c7
        Docker - Synology NAS
        Global expression
        xB1_Temp_01_ID = getEntity( "ezlo>device_626d5f9f129e2912444634a4" ).attributes.temperature_sensor.value
        xB1_Humidity_01_ID = getEntity( "ezlo>device_626d5f9f129e2912444634a0" ).attributes.humidity_sensor.value
        in reactor.yaml
                  capabilities:
                    value_sensor:
                      attributes:
                        value:
        in dashboard
        -ZWaveJS-UI 11.22.3
        -Update 16/08/2026
        • N Offline
          N Offline
          or
          glabal expression
          xB1_IndiceThom_ID = round( float( xB1_Temp_01_ID ) - (0.55-0.0055 *  float( xB1_Humidity_01_ID )) * ( float( xB1_Temp_01_ID ) - 14.5) , 1)
          reactor.yaml
                    capabilities:
                      value_sensor:
                        attributes:
                          value:
                            expr: xB1_IndiceThom_ID
          dashboard
          -ZWaveJS-UI 11.22.3
          -Update 16/08/2026
            Great. Thank you. Two things going on here. One you can fix, one I have to fix.
            First, you have to help the dashboard figure out how to display your entity. For that, you need to make two additional entries in your config for your virtual entity. Add the two lines I show at the end here:
                      capabilities:
                        value_sensor:
                          attributes:
                            value:
                      primary_attribute: value_sensor.value
                      type: ValueSensor
            Setting primary_attribute helps the dashboard figure out which attribute to display. The type determines the widget type, which can be:
            • Switch — an on/off switch;
            • Light — a dimmable light or multi-level switch;
            • Valve — a water valve;
            • Lock — a door lock;
            • BinarySensor — a binary sensor;
            • SecuritySensor — a security sensor (special case of binary sensor for door, window, glass break, etc.);
            • Button — a pushbutton (entity must have button capability);
            • Script — a script (like a Vera scene, Hass automation or script, etc.);
            • MediaPlayer — a media player (has media_player and other related capabilities);
            • Camera — a camera;
            • Weather — weather entity (implements wx capability);
            • Cover — window covering, garage door, etc.
            Now, that said, there is indeed a bug in handling attribute changes. It appears VirtualEntityController is aware the variable has changed, but it's consistently getting the previous value rather than the new value for the expression, and I know what's causing that. It will take a couple of days for me to fix and get out a new build.
            • N Offline
              N Offline
              Thanks to you!!!
              Lines are added
              another idea for the future:
              a gauge range applied to ValueSensor or Weather in simple text color:
              RED text for value out of range min/max
              -ZWaveJS-UI 11.22.3
              -Update 16/08/2026
                Can you tell me what your Reactor install is? Docker? What architecture?
                These things are supposed to be in your original post, per the posting guidelines. Please re-read the posting guidelines for this category so that your future posts contain the information requested for every post.
                • N Offline
                  N Offline
                  ops, soorry! now it is in signature too.
                  -ZWaveJS-UI 11.22.3
                  -Update 16/08/2026
                    163.0k
