  4. Run 'Set Reaction' or 'Reset Reaction' from LAN (HTTP)
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
5 Posts 3 Posters 1.2k Views 3 Watching
  • C Offline
    C Offline
    cd12172
    Hi - hoping someone can share the url syntax to force MSR to run a specific set or reset action of a Rule.
    Use case=
    -use MSR actions to set a scene
    -fire the reaction from a homebridge system on same LAN to manage voice commands
    I have done this in Vera, can't find the correct syntax for MSR.
    The command I tried from research is:
    http://192.168.1.243:8111/api/v1/reaction/re-lq8bnkvf/run
    I received "Not Found" using chrome No log entry - so I must be off on the URL.
    Reactor = latest-23063-c464b685
    MSR and Hass run on same ip addr
    Reactor port =8111
    HASS port=8123 (I tried this too)
    screen shot attached
    • CrilleC Online
      CrilleC Online
      The command you tried only works for global Reactions, I don’t think you can run Rule Reactions from the http api. Create a global Reaction with desired action and call it from Homebridge
      • C Offline
        C Offline
        cd12172
        Great- thanks, it works
          I use a global variable that I set via http/mqtt, and it’s used to trigger normal rules. That’s very useful if you want normal triggers to still work and a way to invoke the same reaction on demand.
          • C Offline
            C Offline
            cd12172
            Nice- very flexible.
              162.3k
              1.3k
