  4. [RESOLVED] Troubleshooting assistance/ideas needed
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
2 Posts 1 Posters 683 Views 1 Watching
  • 3 Offline
    3 Offline
    Running MSR latest-23344-ca53d088 within a Docker.
    My Hubitat (HE) hub suffered almost a 4 day outage from a corrupt backup that failed to restore. During this time I had my MSR docker stopped. Well, I didn't stop it until the the hub had been down for 24 hours. Anyway, I finally got the hub back online this morning and am fixing my MSR rules for everything that was lost. Support needed to purge out the Apps section of the backup.
    So my issue. So far everything I have fixed is working as expected, with the exception of my motion controllers. I can see them go "Active" within my HE, but the Entity within MSR never changes from false to true. I ran through a slew of rooms that have motion sensors and only 1 out of 6 changed to true.
    I removed the sensor I'm testing with from Maker API, restarted MSR, re-added it, restarted MSR, but no difference. I then Deleted it from MSR and restarted MSR. It was re-added, but again no change. How can I go about testing this further to find out why/what is going on?
    • 3 Offline
      3 Offline
      I love it when solutions come to you in your dreams. It dawned on me that my Hub Security on the hub was reset but I still had it enabled on MSR. As soon as I enabled it on my hub and restarted MSR, and literally had a kid walk through the entire house, every motion sensor was tripping back and forth from inactive to active back to inactive.
        163.9k
