  4. ZWaveJSController - open/close reversal
3 Posts 2 Posters 873 Views 2 Watching
    Noticed right away last night at closing time that the open/close had become inverted with the update to v23326.
    *Hubitat C-7 2.5.1.142
    Core 2026.7.4
    MSR: latest-26193-8dd8f854
      What capability?
        What capability?
        @toggledbits It seems that the blinds reversed direction. There's a setting in HA's ZWaveJS UI:
        This was set to No and the result was the blinds closing tilted up on the inside. After deploying 23326 they close tilted down on the inside. I needed to change this setting to yes for each blind in ZWave JS UI and also any Reactions that had partial open percentages from .8 to .2 (for instance) to have the blind open 20% from closed.
        I tested this thru MSR ZWaveJSController with cover.open and cover.close as well as position.set and the results were consistent: 180° opposite of what they were before 23326.
        Core 2026.7.4
          145.9k
