  4. JS Zwave / Kwikset PIN codes
2 Posts 2 Posters 870 Views 2 Watching
  • C Offline
    C Offline
    cd12172
    Any tips are appreciated.
      You would likely need to use the x-hass.call-service action on the lock entity and your service ID would be zwave_js.set_lock_usercode. In the data portion you'd have to fill out the code_slot and code. Note that this will not work if your lock isn't securely included with your HASS controller.
        146.2k
