  4. Need guidance on local MQTT capabilities
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
5 Posts 3 Posters 1.9k Views 3 Watching
    I'm trying to replicate this
    wallbox_set_number.PNG into a MQTT entity where I could set a number with a min and max value.
    I can't find a standard capability that fits or any documentation on local MQTT capabilities and the only post on the forum mentioning local MQTT capabilities is this post, is it even possible in current release?
    My trial and error work in local_mqtt_capabilities.yaml isn't much to show as it's just a copy of mqtt_capabilities.yaml with changed names and then I got stuck.
    Any guidance, examples, documentation, future feature request or denial would be much appreciated, thanks!
    Reactor 24057-e9add9f5 bare metal
    MQTTController 24050
    • CrilleC Crille
      @Crille said in Need guidance on local MQTT capabilities:
      Why? Up front, I don't understand why you would replicate something that exists, or why you'd want to add min/max values to it. This sounds like an X-Y Problem. Can you give some background on what problem you are trying to solve, and why you think doing what you are trying to do seems like a path to solving it?
        I've rooted my Wallbox and installed a MQTT bridge on it and would like to minimize the points of failure/number of hops, i.e bypass Home Assistant in case of unexpected outage. I sure could just publish set commands in a rule but thought it would be nice to have it in one entity along with other capabilities, and learn something on the way.
        The charger won't accept lower than 6 amps or higher than what the physical current switch inside it is set to, so to rule out mistakes a min/max value is preferred.
        If it's not possible, it's not possible. There are as said other ways and Home Assistant only gave up on me once so far and that was kind of my own fault anyway (but it initiated my quest to a backup plan).
        • CrilleC Crille
          @Crille look at the template in my signature and feel free to modify it. I have one for my wallbox/ev charger that will simply ignore out of range values, so no need to set min/max.
          I'm controlling the solar excess via msr since day 1 with great results.
            Ah, if I only known what to search for or had a really good memory I would have found ev_charger announced here but not listed in Standard Capabilities 🙂
            My charger seems to ignore out of range values as well so ev_charger was the missing piece in my quest, thank you @therealdb.
              163.6k
