authtrack:
max_attempts: 4
EDIT: some logs
reactor.yaml:
trusted_proxy: "192.168.1.12"
users.yaml:
- url: "/api/v1/log"
method: "GET"
source_ip: 172.18.0.0/24
allow: true
x_hass.domain="fan"
x_hass.source="esphome"
x_hass_attr.percentage=50
x_hass_attr.preset_mode=""
x_hass_attr.preset_modes=[]
primary_attribute_value: |
d = false;
d
Edit: Solved in latest-26221.
Bare-metal latest-26193
I have this group:
"OKforLarm":
name: OK för Larm
- include_controller: vera
Feature Request: Sublevel in Rulesets
Hi @toggledbits
Would you please consider adding an extra sublevel in the rulesets?
I have grouped my rules in rooms/ areas. This works great for me, but I would also like to group rules for the same functionality (in a room). This would make the rules easier to find and name.
Please let me know if this is an option. Thanks!
