  4. Aeon MultiSensor 6 missing motion capabilities in ZWaveJS entries
Edit: Fixed in re-spun 26328. (I just gave my old Ezlo Plus a new chance so it's running my z-wave devices in my garage, for evaluation, as my even older Vera Secure had issues reaching that far when some router nodes gave up). Bare metal latest-26328 Issue 1: Nodes don't update in Reactor after update from 26318. Issue 2: Also present in earlier builds, rooms don't add to DGC and throws error at start. Notice: No device mapping matches Intrusion Sensor. I don't know if you still support EzloController but seems like an easy fix? Let me know if you need more info! [latest-26328]2026-11-25T11:18:31.310Z <Controller:NOTICE> Controller HassController#hass is now online. [latest-26328]2026-11-25T11:18:31.313Z <EzloController:ERR> [TypeError] Cannot read properties of undefined (reading 'clear') [-] failed to process rooms: [undefined2] [latest-26328]2026-11-25T11:18:31.313Z <EzloController:CRIT> TypeError: Cannot read properties of undefined (reading 'clear') [-] TypeError: Cannot read properties of undefined (reading 'clear') at EzloController._process_hub_rooms (/home/homebridge/reactor/server/lib/EzloController.js:1558:153) at /home/homebridge/reactor/server/lib/EzloController.js:1388:48 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.314Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.452Z <wsapi:INFO> wsapi: connection from "192.168.1.2" [latest-26328]2026-11-25T11:18:31.585Z <EzloController:ERR> EzloController#ezlo error creating entity Switch#ezlo>device_6b02d1d9129e0715b720f005: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.585Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.588Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d41d129e0715b720f012: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.588Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.590Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d41e129e0715b720f01c") -- skipped [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo error creating entity SecuritySensor#ezlo>device_6b02d9d9129e0715b720f01f: [TypeError] _0xf38820[_0x376e98(...)].update is not a function [-] [latest-26328]2026-11-25T11:18:31.591Z <EzloController:CRIT> TypeError: _0xf38820[_0x376e98(...)].update is not a function [-] TypeError: _0xf38820[_0x376e98(...)].update is not a function at /home/homebridge/reactor/server/lib/EzloController.js:1649:58 at Array.forEach (<anonymous>) at EzloController._process_hub_devices (/home/homebridge/reactor/server/lib/EzloController.js:1597:226) at /home/homebridge/reactor/server/lib/EzloController.js:1418:54 at process.processTicksAndRejections (node:internal/process/task_queues:104:5) [latest-26328]2026-11-25T11:18:31.591Z <EzloController:ERR> EzloController#ezlo no device mapping matches Intrusion Sensor ("6b02d9da129e0715b720f029") -- skipped [latest-26328]2026-11-25T11:18:31.682Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 2159ms [latest-26328]2026-11-25T11:18:31.684Z <Controller:NOTICE> Controller EzloController#ezlo is now online.
Edit: Fixed in 26328. Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
4 Posts 2 Posters 1.1k Views 2 Watching
    Good morning,
    I'm going through my ruleset this morning, trying to get away from haas>blahblablah entries and completely migrate them all to zwavejs>xx-0 entries where possible.
    I have 3 Aeon MultiSensor 6 devices in my home, all USB powered.
    When using Haas entries, I see an entry for hass>binary_sensor_guest_bedroom_multisensor_home_security_motion_detection, and motion_sensor.state (primary)
    Under ZwaveJS, this entry appears to be missing.
    From the Entities page:
    battery_power.level=1
    battery_power.since=1721910337433
    binary_sensor.state=false
    humidity_sensor.units="%"
    humidity_sensor.value=46
    light_sensor.units="Lux"
    light_sensor.value=5
    tamper.state=false
    temperature_sensor.units="°F"
    temperature_sensor.value=73.8
    x_debug.dt={}
    x_zwave_values.Basic_currentValue=0
    x_zwave_values.Battery_isLow=false
    x_zwave_values.Battery_level=100
    x_zwave_values.Binary_Sensor_Any=false
    x_zwave_values.Configuration_Automatic_Report_Group_1_Battery_1=1
    x_zwave_values.Configuration_Automatic_Report_Group_1_Humidity_64=1
    x_zwave_values.Configuration_Automatic_Report_Group_1_Luminance_128=1
    x_zwave_values.Configuration_Automatic_Report_Group_1_Temperature_32=1
    x_zwave_values.Configuration_Automatic_Report_Group_1_Ultraviolet_16=1
    x_zwave_values.Configuration_Automatic_Report_Group_2_Battery_1=0
    x_zwave_values.Configuration_Automatic_Report_Group_2_Humidity_64=0
    x_zwave_values.Configuration_Automatic_Report_Group_2_Luminance_128=0
    x_zwave_values.Configuration_Automatic_Report_Group_2_Temperature_32=0
    x_zwave_values.Configuration_Automatic_Report_Group_2_Ultraviolet_16=0
    x_zwave_values.Configuration_Automatic_Report_Group_3_Battery_1=0
    x_zwave_values.Configuration_Automatic_Report_Group_3_Humidity_64=0
    x_zwave_values.Configuration_Automatic_Report_Group_3_Luminance_128=0
    x_zwave_values.Configuration_Automatic_Report_Group_3_Temperature_32=0
    x_zwave_values.Configuration_Automatic_Report_Group_3_Ultraviolet_16=0
    x_zwave_values.Configuration_Automatic_Reporting_Interval_Group_1=3600
    x_zwave_values.Configuration_Automatic_Reporting_Interval_Group_2=3600
    x_zwave_values.Configuration_Automatic_Reporting_Interval_Group_3=3600
    x_zwave_values.Configuration_Automatic_Temperature_Reporting_Unit=2
    x_zwave_values.Configuration_Battery_Level_Threshold=10
    x_zwave_values.Configuration_Current_Power_Mode_65280=0
    x_zwave_values.Configuration_Humidity_Above_Lower_Limit_32=0
    x_zwave_values.Configuration_Humidity_Below_Lower_Limit_2=0
    x_zwave_values.Configuration_Humidity_Change_Threshold=10
    x_zwave_values.Configuration_Humidity_Recover_Limit=5
    x_zwave_values.Configuration_Humidity_Sensor_Calibration=0
    x_zwave_values.Configuration_LED_Blinking=0
    x_zwave_values.Configuration_Lighting_Recover_Limit=10
    x_zwave_values.Configuration_Lock_Configuration=0
    x_zwave_values.Configuration_Low_Battery_Threshold=20
    x_zwave_values.Configuration_Low_Temperature_Alarm_15_C=0
    x_zwave_values.Configuration_Lower_Humidity_Limit=50
    x_zwave_values.Configuration_Lower_Lighting_Limit=100
    x_zwave_values.Configuration_Lower_Temperature_Limit_4294901760=320
    x_zwave_values.Configuration_Lower_Temperature_Limit_Unit_3840=2
    x_zwave_values.Configuration_Lower_Ultraviolet_Limit=4
    x_zwave_values.Configuration_Luminance_Above_Lower_Limit_64=0
    x_zwave_values.Configuration_Luminance_Below_Lower_Limit_4=0
    x_zwave_values.Configuration_Luminance_Change_Threshold=100
    x_zwave_values.Configuration_Luminance_Sensor_Calibration=0
    x_zwave_values.Configuration_Motion_Sensor_Report_Type_to_Send=2
    x_zwave_values.Configuration_PIR_Sensitivity=3
    x_zwave_values.Configuration_PIR_Sensor_Timeout=20
    x_zwave_values.Configuration_Recover_Limit_Temperature_Unit_255=2
    x_zwave_values.Configuration_Report_Above_Humidity_Threshold_32=0
    x_zwave_values.Configuration_Report_Above_Luminance_Threshold_64=0
    x_zwave_values.Configuration_Report_Above_Temperature_Threshold_16=0
    x_zwave_values.Configuration_Report_Above_Ultraviolet_Threshold_128=0
    x_zwave_values.Configuration_Report_Below_Humidity_Threshold_2=0
    x_zwave_values.Configuration_Report_Below_Luminance_Threshold_4=0
    x_zwave_values.Configuration_Report_Below_Temperature_Threshold_1=0
    x_zwave_values.Configuration_Report_Below_Ultraviolet_Threshold_8=0
    x_zwave_values.Configuration_Reset_Parameters_101_103_to_Default_Values=null
    x_zwave_values.Configuration_Reset_Parameters_111_113_to_Default_Values=null
    x_zwave_values.Configuration_Reset_to_Factory_Default_Setting=null
    x_zwave_values.Configuration_Selective_Reporting=0
    x_zwave_values.Configuration_Sleep_State_255=2
    x_zwave_values.Configuration_Temperature_Above_Lower_Limit_16=0
    x_zwave_values.Configuration_Temperature_Below_Lower_Limit_1=0
    x_zwave_values.Configuration_Temperature_Calibration_Offset_65280=0
    x_zwave_values.Configuration_Temperature_Calibration_Unit_255=2
    x_zwave_values.Configuration_Temperature_Change_Threshold_4294901760=20
    x_zwave_values.Configuration_Temperature_Recover_Limit_65280=20
    x_zwave_values.Configuration_Temperature_Threshold_Unit_3840=2
    x_zwave_values.Configuration_Ultraviolet_Above_Lower_Limit_128=0
    x_zwave_values.Configuration_Ultraviolet_Below_Lower_Limit_8=0
    x_zwave_values.Configuration_Ultraviolet_Change_Threshold=2
    x_zwave_values.Configuration_Ultraviolet_Recover_Limit=2
    x_zwave_values.Configuration_Ultraviolet_Sensor_Calibration=0
    x_zwave_values.Configuration_Upper_Humidity_Limit=60
    x_zwave_values.Configuration_Upper_Lighting_Limit=1000
    x_zwave_values.Configuration_Upper_Temperature_Limit_4294901760=824
    x_zwave_values.Configuration_Upper_Temperature_Limit_Unit_3840=2
    x_zwave_values.Configuration_Upper_Ultraviolet_Limit=8
    x_zwave_values.Configuration_Wake_Device_for_10_minutes_After_Power_On=1
    x_zwave_values.Configuration_Wake_Up_Timeout=15
    x_zwave_values.Manufacturer_Specific_manufacturerId=134
    x_zwave_values.Manufacturer_Specific_productId=100
    x_zwave_values.Manufacturer_Specific_productType=258
    x_zwave_values.Multilevel_Sensor_Air_temperature=73.8
    x_zwave_values.Multilevel_Sensor_Humidity=46
    x_zwave_values.Multilevel_Sensor_Illuminance=5
    x_zwave_values.Multilevel_Sensor_Ultraviolet=0
    x_zwave_values.Notification_Home_Security_Cover_status=0
    x_zwave_values.Notification_Home_Security_Motion_sensor_status=0
    x_zwave_values.Notification_alarmLevel=0
    x_zwave_values.Notification_alarmType=0
    x_zwave_values.Version_firmwareVersions=["1.17"]
    x_zwave_values.Version_hardwareVersion=100
    x_zwave_values.Version_libraryType=3
    x_zwave_values.Version_protocolVersion="4.54"
    x_zwave_values.Wake_Up_controllerNodeId=1
    x_zwave_values.Wake_Up_wakeUpInterval=3600
    zwave_device.capabilities=[32,48,49,112,113,114,128,132,134]
    zwave_device.endpoint=0
    zwave_device.failed=false
    zwave_device.generic_class="Multilevel Sensor"
    zwave_device.impl_sig="23326:1:22315:1"
    zwave_device.is_beaming=false
    zwave_device.is_listening=true
    zwave_device.is_routing=true
    zwave_device.is_secure=false
    zwave_device.manufacturer_info=[134,258,100]
    zwave_device.node_id=53
    zwave_device.specific_class="Routing Multilevel Sensor"
    zwave_device.status=4
    zwave_device.status_text="alive"
    zwave_device.version_info=[null,"1.17"]
    zwave_device.wakeup_interval=3600
    I'm running:
    Reactor latest-24190-bd310acc, Bare-metal on Fedora
    WaveJSController [0.1.23326]
    Home Assistant: 2024.7.0
      Note, I think it is actually the Binary Sensor.. Could this be changed/renamed in anyway?
        Try downloading the latest zwavejs_data.zip from the download server; put it in your config directory (do not unzip it, just put the ZIP file in there whole) and restart.
          That did the trick, thanks!
            165.4k
