  4. [ZWaveJS] Venetian blind tilt for Fibaro Roller Shutters 2 (FGR222)
    Hi @toggledbits ,
    I'm slowly moving my ZWave network from Vera to ZWaveJS. I successfully cloned my ZWave network using a spare Vera Edge (a new post for the community later when I'll be fully back from vacation) and I'm testing a couple of things before moving everything to ZWaveJS.
    In the meanwhile, I have a couple of venetian blinds connected to Fibaro Roller Shutters 2 (FGR222) and I'm using some proprietary ZWave commands to control the tilt position, that right now I'm sending via Vera (with some code from the old place, messing with this):
    The ZWaveJS values are reported via this:
    x_zwave_values.Manufacturer_Proprietary_fibaro_venetianBlindsPosition=0
    x_zwave_values.Manufacturer_Proprietary_fibaro_venetianBlindsTilt=0
    I hope there's a way to expose a separate device to control the tilt position directly, without doing the mess I'm doing now. Let me know if you need some files. Thanks.
      I'm on my way to a conference but will look at this when I get back (Sunday)
        Thanks. It's public holiday tomorrow and then I'm out to watch a soccer match. It's perfectly fine. I've also managed to import device names into Zwavejs via mqtt. On my way to do the same for the endpoints on the controller side.
          In the meanwhile, I found a way to call it from Reactor:
          zwavedata is just the requested position, 0...99
          • therealdbT therealdb referenced this topic on
            For tilt, the ZWave standard command class (which Fibaro does not implement) uses 50 to represent open (the slats of the blind are flat/horizontal), and values 0 and 99 to indicate the two versions of closed (fully tilted up, or fully tilted down). What do the tilt values 0-99 represent on this device?
              0 closed, 99 open (so, horizontal). 50 is 50% open. But maybe my device is specific, I've never been able to open more than flat/horizontal.
                154.4k
